VIZIO E470VA Dead
+ More Options
Posts
  • bwilliams60
    • Aug 2014
    • 109
    Re: VIZIO E470VA Dead
    Good idea. I am going to knock off for the night. I will post back tomorrow after I have replaced it and tested. Thank you very much for your help. Very much appreciated and thanks to budm for your help. Good forum to belong to!
      Glad to hear that the hair dryer trick works for you (I was going to tell you to check the DCV on that cap but I think it was too dangerous for you to be working in the primary side based on how you were measuring the Voltage on the primary side in post 1, and I do not want you to get hurt or cause more damage if something bad happens). So you fixed the TV with 50 cents part and save lots of money and the TV from the landfill.
      • retiredcaps
        • Apr 2010
        • 9271
        I haven't looked at capacitor datasheets in probably 2 years now and was a bit surprised to find that the Panasonic FC 10uF 50V cap has the following characteristics.
        Ripple = 125 mA
        Impedance = 1.300 Ohm
        Endurance = 1000 hours at 105C
        The 1000 hours is pretty low. For every 10C decrease, endurance doubles. Thus,
        1000 @ 105C
        2000 @ 95C
        4000 @ 85C
        8000 @ 75C
        16000 @ 65C
        32000 @ 55C
        64000 @ 45C
        Now, my guess is that the average TV runs in the 55C range when ON. It might be 25C when in standby mode? If correct, that is roughly 5 to 6 years? The Vizio TV set you have might be 5 years old?
        So I did a quick search for Rubycon and found
        https://cdn.badcaps-static.com/pdfs/...4d451e9517.pdf
        The Rubycon XJY has
        Ripple = 100 mA
        Impedance = 1.5 Ohm
        Endurance = 5000 hours at 105C
        meaning
        5000 @ 105C
        10000 @ 95C
        20000 @ 85C
        40000 @ 75C
        80000 @ 65C
        160000 @ 55C
        320000 @ 45C
        Now the ripple on the YXJ is slightly worse and impedance is slightly higher than the FC, but it might be on par or better than the original capacitor? What is the brand and series of the original? Samwha?
        YXJ is slightly cheaper too (36 cents CDN at digikey.ca or 2 cents USD with current exchange rate - hahaha)!
        Anyway, now that I'm aware of this, my future orders will probably go with YXJ.
        PS. United Chemi-con KY series has exact same characteristics as Rubycon YXJ for 35 cents CDN at digikey.ca.
        --- begin sig file ---
        --- end sig file ---
        • bwilliams60
          • Aug 2014
          • 109
          Thank you for worrying. Is there a post on here somewhere that details the best way to test the primary side of an SMPS? I know I should use an isolation transformer which I haven't got yet, but what else might I need to know? Thank you in advance for your help.
          • bwilliams60
            • Aug 2014
            • 109
            And so, TV repair #1 is now under my belt thanks to budm and retiredcaps. You guys have provided excellent mentoring and the $0.50 cap ($0.10 US, lol) did the trick. Much obliged for the lessons and looking forward to some more down the road.
            Now back to my own Samsung display that also appears to be dead and at a dead end on another thread.
            Thanks for the help!
            • bwilliams60
              • Aug 2014
              • 109
              I'm back. Perhaps I spoke too soon or perhaps I am just doing something wrong. So I plug the set in and a nice crisp screen comes up with the Vizio logo and I can pull up the menu (no remote) by pushing the buttons but I don't get any channels? I try to do an autochannel select and as soon as I go to start, it says it is done. Still no channels. I guess I should hook up another source (DVD ?) and see if it plays?
              Question 2. When I do get this working, can I program a Universal remote to work with this set? Thank you in advance.
                The universal remote should work. Are you on cable or you trying to pick up the signal over the air?
                • bwilliams60
                  • Aug 2014
                  • 109
                  I am on cable and I checked my cable with another TV and it works fine. When I go to autochannel to program the channels, it goes from 0% to 100% instantly and says done and there is no sign of any channels.
                  • bwilliams60
                    • Aug 2014
                    • 109
                    UPDATE:
                    Okay we are back on track. Apparently if you don't have a set top box and are just using normal cable, you need to set it to antenna. Did that and all good. Beautiful picture on this set.
                    Imagine, reading an owner's manual can help you solve some of life's smallest problems
                      Good.
                      • bwilliams60
                        • Aug 2014
                        • 109
                        Thanks again budm for checking in. Appreciate the help.
                        • bwilliams60
                          • Aug 2014
                          • 109
                          I guess I did speak too soon. I have been turning this one on and off at random and now the same thing is going on.I turn it on, Vizio light may or may not come on and then nothing. Voltage on main caps is around 370VDC for a bit and then falls down to 162VDC. At this point, it won't turn on. If I heat up the area that we replaced the cap in, unit will come on and work. There is something there labelled FB108. Does anybody know what this is? Right side of power supply board in 5V section. Seems discolored.
                            FB108 is more likely to be Ferrite Bead inductor, it should have <1 Ohms of resistance.
                            • bwilliams60
                              • Aug 2014
                              • 109
                              I placed my ohmmeter across it and it does indeed have less than 1 ohm across it. In fact I can't even get a measurement on it it is so low but there is definitely continuity. Budm is there anything else in that section that may cause this and how can I test for it.
                              I have tested all the diodes cold and they are all okay (.522). I am ssuming because I am in the 5V section I can put my meter to chassis ground. Can I measure voltages to the VIPER KB2105 chip or the KT2222A/KTN2907A transistors or the three Everlight BC115 chips. I know when I warm that area for less than 1 minute, the TV will work fine afterwards.
                              • jetadm123
                                • 2169
                                #35
                                Since the problem is heat related, maybe a bad solder joint? Try touching up the joints in the 5V section budm outlined earlier.
                                • bwilliams60
                                  • Aug 2014
                                  • 109
                                  I removed the board and inspected again. I still don't see any bad joints and I am posting pics. Perhaps someone else can see it.
                                  • bwilliams60
                                    • Aug 2014
                                    • 109
                                    Bump
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5084
                                      • New Zealand
                                      #38
                                      Look again. There are some joints which look cracked - you can see a slight ring next to the arrows I have added.
                                      Use your iron on all the through-hole component joints in that area an add a touch more solder to reflow all the joints.
                                      Also try to upload JPG files as they can be previewed more easily.
                                      -David VanHorn
                                      • bwilliams60
                                        • Aug 2014
                                        • 109
                                        Good eye. I will reflow all the joints in that area and get back to you. One other thing I did was check the optocouplers and the one in the middle gave me readings on both sides in both directions where the two outside ones did not. When I say that, I mean both directions on the diode side and both directions on the transistor side. Would this be because it is in the circuit or should all three read the same?
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 5084
                                          • New Zealand
                                          #40
                                          If they are all identical parts they should all have the same readings, but yes, in-circuit readings may be affected by other connected components so to test properly you'd need to remove and compare all of them out-of-circuit.
                                          -David VanHorn
                                          • Iain P
                                            Vizio E65-F0 really dead
                                            by Iain P
                                            Hi everybody!
                                            I've got a Vizio E65-F0 smart tv that is good and dead. It shows no signs of life when I press the power button on the back. The power LED in the lower right corner doesn't light, there is no backlight and no picture.
                                            So I took the back off and started poking around figuring one or more of the caps had dried out. My esr meter says all the caps on the power supply board and the mainboard are less than 1 ohm.
                                            I decided to check the voltages coming off the power supply they are as follows:
                                            connector CN201
                                            pin 1 (18vsb1)...
                                            02-23-2023, 11:32 AM
                                          • flibidy
                                            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                            by flibidy
                                            I have here a Magnum IA.100 which belongs to my parents.
                                            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                            What Ive done........
                                            01-01-2025, 01:26 PM
                                          • catnapped
                                            Dead Vizio D40u-D1
                                            by catnapped
                                            Recently had my bedroom Vizio D40u-D1 apparently die while it wasn't being used. Noticed the power LED flashing, figuring maybe a software upgrade, but attempting to turn it on proved that wasn't the case. When powered on, the power LED will flash a bunch of times after about 2 minutes then turn off again. Definitely is no picture even with a flashlight on the screen. Had the opportunity to open it up over the weekend. Doesn't apper to be anything out of the ordinary visibly inside, nor any odd smells of escaped magic smoke. Readings from the connector in the corner of the power supply board...
                                            04-02-2024, 08:55 AM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead: PSU or Main Board?
                                            by fharris1977
                                            Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
                                            03-12-2024, 12:22 PM
