Repairing a Hitachi 55HDS69 plasma - no picture, or sound
  • khnitz
    • Dec 2012
    • 17
    I got this TV from a friend who said the original problem was that it had no picture, but sound, and would take several tries to power up until it finally stopped powering on at all. The TV sat in storage from some years (it's a 2006 model) until now - since they are moving to a new home, they didn't want to bring this with.
    So, having repaired a bunch of home electronics items over the years, I thought I'd take a gamble on this one.
    The TV completes its power-up cycle with no error LEDs lit. The front LEDs will complete the power up cycle and show a solid Blue LED, before eventually showing only an Orange LED for no signal. I tried feeding a signal into the TV and cycling through the inputs (there's no display, so I have to make a best guess of it), but no luck on getting a picture or sound.
    None of the 'lytics looked stressed, but I replaced the 2 main ones on the Power Supply board (390uF, 450V), just in case. This made no difference. Also, unplugging the power supply board to check at the connector for Va, Vs and Vcc showed no voltage there, either - I checked this when the Blue status LED was solid on the front of the TV. Again, none of the error LEDs are lit after they complete their power-up cycle.
    So, I'm rolling the dice on a new power supply board. I'll post my results when it arrives and I test it out (maybe by the end of this week). I'm posting my efforts and findings here, to hopefully help someone else down the road, too.
  • Hamie
    • Apr 2014
    • 1383
    Re: Repairing a Hitachi 55HDS69 plasma - no picture, or sound
    I wouldn't buy a power supply.
    Sounds more like a sustain board problem, control board or even mainboard.
    You'll need to upload pictures of all the boards.
    • khnitz
      • Dec 2012
      • 17
      Some more detail, when I unplugged the connector circled in red in the attached image, there was no voltage (0.2V or less) on any of the pins of the connector on the power supply board. This was measured after the power-up routine was completed (no error LEDs lit on the control board, and solid Blue status LED on the front of the TV).
      • R_J
        • 9624
        I would suspect the buffer boards and possibly the ysus also, try unpluging the buffer boards from the ysus and see if the vs stays on.
        I have worked on a 55hdt79 with the same symtom, the upper buffer and the ysus were bad.
        • Treydogg77
          Treydogg77
          • Mar 2013
          • 99
          • US
          RJ,
          Would you send me a copy of the service manual that your attachment above came out of?
          Thank you,
          • R_J
            • 9624
            That was a Hitachi service bulletin, not from the manual. You can download the manual from here
            • Treydogg77
              Treydogg77
              • Mar 2013
              • 99
              • US
              Thanks RJ!
              Trey W
              Boone, NC
              • khnitz
                • Dec 2012
                • 17
                So, as was pointed out here, the new power supply board did not resolve the issue with this TV.
                So, on to the buffer boards, as was suggested.
                I removed the lower one, first, and powered the TV on - the upper 1/2 of the screen lit up!
                So, the next step will be to find a buffer board (or a repair service) and install that and see if I can get this all fixed
                • khnitz
                  • Dec 2012
                  • 17
                  Also, in checking the buffer IC caps on that lower board, 3 of them read shorts across, them. The board is now being sent off for repair.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    More than likely the top buffer Ic is short its normally the top one that blows as its the first one to be addressed, over time it fatigues due to heat and age and eventually shorts. As the bottom half of the screen works the Ysus is probably ok as it addresses the buffers sequentially so if the Ysus was short it would have blown the bottom buffer as it would load the bottom set next if the top buffer isnt present. Replace the top buffer and enjoy the tv
                    • khnitz
                      • Dec 2012
                      • 17
                      I removed the upper buffer board to check for any shorts across the buffer IC caps, and there were none.
                      Again, to clarify my symptoms: there was no video or audio when the TV was turned on - I would get the solid blue LED on the front. With the lower buffer board removed, the upper half of the screen would come on. And, on the lower buffer board, 3 of the buffer IC caps measured shorts across them. So, my lower buffer board (ND60200-0034) is out for repair, and I'll post how things are working when I get it back and installed.
                      Given that it seems to be a time+heat issue with these failing, I'm wondering if I should install a couple of small PC fans inside the TV and mount them atop the buffer IC boards to help with cooling. Thoughts?
                      • khnitz
                        • Dec 2012
                        • 17
                        I received the lower Y-buffer board back and installed it - and I now have picture and sound! But...
                        There are horizontal lines missing (evenly spaced across the whole height of the screen):
                        Thoughts? Would this mean the Y-SUS board also needs repair?
                        • khnitz
                          • Dec 2012
                          • 17
                          To keep the repairs aligned with the symptoms for future users searching for solutions, I decided to create a new thread to cover this "missing lines behavior" here:
                          https://www.badcaps.net/forum/showth...418#post585418
                          • khnitz
                            • Dec 2012
                            • 17
                            Tinypic swapped the images on the original link. Here is a picture of the missing lines:
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Checked that all cables are in ? Are the pixels that are in the blank rows illuminated at all ? Sounds to me like a control board issue.
                              • khnitz
                                • Dec 2012
                                • 17
                                I did go back and re-check all the connections to the y-buffer-IC boards and the Y-Sus board - those seem good.
                                It's weird how the missing lines are so evenly spaced, too. Yeah, it seems like something in the addressing is off.
                                • Vengeance
                                  • Feb 2015
                                  • 7
                                  Did you ever get it fixed? This is exactly what just happened to mine. Picture went out while watching tv but there was still sound. I knew not to waste money on a power board if the sound still works. Did the test with just upper buffer in and then lower buffer in to find the lower was bad. Replaced the lower buffer and there were the evenly spaced black lines through the whole screen. The weird thing is there weren't evenly spaced black lines when it was working with just the top buffer in, now after installing the replacement bottom board the evenly spaced black lines are still there with just the top board in. After a while of double and triple checking everything, the ICs on the bottom board burned out again. My guess would be it's the Y sustain burning it out. Can anyone confirm or give me a better guess? Could the Y sustain also be causing the evenly spaced black lines?
                                  • khnitz
                                    • Dec 2012
                                    • 17
                                    Unfortunately, no, I didn't get it fixed (never resolved the horizontal lines). Shortly after my last post in this thread I took a new job out of state and in preparing for the move I sold this TV to someone else to try and repair.
                                    • nicholas1110
                                      • Aug 2012
                                      • 127
                                      • usa
                                      The buffer boards fail on this model due to caps on the power supply. I think they are 3300uf if memory Serves correct. They will be buldged Alittle bit. Hope this helps.
                                      • Vengeance
                                        • Feb 2015
                                        • 7
                                        There aren't any bulging caps. That's the first thing I check. The caps are 450v 390uf, and 100v 2400uf. I would think the boards burn up from too much power, and that bad caps supply less power, not more. I don't have an esr meter but was thinking of making a diy one. How do you know what the esr reading should be?
                                        • KYBOSH
                                          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                          by KYBOSH
                                          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                          No picture but you hear the TV static (white noise) playing loud and clear.
                                          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                          But it seems they didn't get too far and just left it.
                                          When I first took a look I was amazed at how pristine the inside looked.
                                          Its as if the TV had been in a time capsule.
                                          Caps looked like they were just pulled off the self.
                                          Copper coils had no sign of corrosion on...
                                          02-01-2023, 11:10 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
