Samsung ln40a530p1fxza (white screen)
  • Tfsjake
    • Jul 2015
    • 14
    Hey guys! I have done a little research and I haven't quite figured out what's going on with my TV.
    I have read that the older Samsungs have fuse problems on the T con board. I am just dangerous enough with a multimeter to mess something up, so I can take some readings if need be.
    When I turn the TV on it is either super, super white and/or a negative image (not solarization). I unplugged the t-con board completely and reinstalled it to have the image come in completely fine for <60 seconds and then go back to white. Attached are pictures of the screen and T-con board.
    Re: Samsung ln40a530p1fxza (white screen)
    This board is known for having bad AS-15 GAMMA ref Voltage IC problem that causes washed out pictures, see if that IC gets very hot to touch.
    • Tfsjake
      • Jul 2015
      • 14
      Well holy crap. I've never been on a forum where the first answer was appropriate, concise, and accurate. That chip gets painfully hot after about 2 seconds of the TV being on.
      I own a soldering station and have minimal skill with that. I know that these require hot air to remove/replace, usually. So...what's my next step?
        Order the IC and carefully remove and install the new IC, those traces lifted off very easily so take your time doing the repair, if you are not good with soldering and do not have proper tools to do SMD rework, then have some one else with proper tool (hot air station) to do it for you.
        • Tfsjake
          • Jul 2015
          • 14
          Thank you! Are there any services that will do this that I can mail the board to? I see that shopjimmy has a repair service but for $80 which is a good percentage of what I consider the TV to be worth to me.
          At that point would I be better to buy the entire board from eBay or somewhere similar? I thoroughly appreciate the help.
          • Hamie
            • Apr 2014
            • 1383
            A local repair shop, or computer repair shop should fit the chip for you for far less than $80.
            • Tfsjake
              • Jul 2015
              • 14
              For some reason I thought the TV repair places would just swap boards/etc. Called a semi local one up (all the local ones had crappy reviews) and the guy said they can do it for ~20-30 if they supply the chip, and less if I supply it.
              Thanks guys, I'll up date this thread with the results!
              • Tfsjake
                • Jul 2015
                • 14
                So I finally got around to ordering the part and I installed it tonight. The problem is fixed! Or is it? It came back up after leaving the TV on for a few hours, and then it went away on its own... any other ideas? I'm right at the $$$ amount that a new TV seems like it'll be a better option.
                  Did you put the pink thermal pad back on top of that IC?
                  • Tfsjake
                    • Jul 2015
                    • 14
                    This is the exact part I installed. It was said to have been pulled from a working TV.
                    I guess it's possible that this one is bad too?
                    • Tfsjake
                      • Jul 2015
                      • 14
                      Bump, any other ideas?
                      • Glitcher
                        • Mar 2013
                        • 673
                        • USa
                        If it came back and went away on its own, I would recheck your soldering and see if theres any lose connections. Reflowing would be a good idea also.
                        • Tfsjake
                          • Jul 2015
                          • 14
                          The new-to-me board was installed and ever since then the picture improves for about an hour, and then starts to looking super saturated and then goes to being washed out. For a few minutes it went to looking negative again.
                          Thinking about returning this board and calling it quits with this TV unless anyone else has something I should try.
                          • Tfsjake
                            • Jul 2015
                            • 14
                            I replaced the entire t-con board with a 'new to me' board from eBay that was pulled from a damaged panel TV. My soldering skills are not up to the task of replacing the component.
                            • Glitcher
                              • Mar 2013
                              • 673
                              • USa
                              I would mostly say probably you got a bad tcon from them.
                              • Tfsjake
                                • Jul 2015
                                • 14
                                That's good to know. I will return this one, eat the shipping cost, and try one more time. Thank you.
                                • jetadm123
                                  • 2169
                                  Did you try cleaning the tcon ribbon cables and re-seating them?
                                  • harp
                                    White screen repairs
                                    by harp
                                    To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                    Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                    On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                    05-13-2024, 03:43 AM
                                  • Chrissygizmo
                                    samsung galaxy ao2s very temperamental after screen replaced
                                    by Chrissygizmo
                                    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                    Ive eventually managed to get it on and working but it's very temperamental...
                                    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                    05-26-2024, 12:05 AM
                                  • Kiberge
                                    Samsung LH82QENELGC/EN Help needed - Static line on screen
                                    by Kiberge
                                    HI guys!
                                    I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                    I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                    the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                    This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                    04-22-2024, 11:28 AM
                                  • Ryan.man
                                    by Ryan.man
                                    02-04-2025, 12:23 PM
                                  • kotel studios
                                    Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                                    by kotel studios
                                    Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                                    In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                                    Today, 02:07 AM
