Hisense LCD37V88P not powering
  • s_henya
    • Jan 2011
    • 480
    • Israel
    Hi guys,
    Got this set, with not powering issue.
    I have a red light on the front panel (maybe standby) on and on the touch buttons.
    I have 24vdc on the inverter - but with no backlight.
    on touching the touch buttons i can hear beeps.
    i got 409vdc on main filter cap.
    on touching the power button i can't seem to power it off/ on i have steady 24vdc on the inverter.
    tried the flashlight trick but got nothing.
    i want to force start the psu and the inverter alone to isolate logic card fault.
    need your help with this one, the connector legend isn't clear.
    Re: Hisense LCD37V88P not powering
    The power supply is woprking and it is getting the PS-ON to turn on the PFC Voltage booster circuit to produce the 409VDC on the main cap and the 24VDC for the Inverter board.
    For the backlights to be on you have to have the BL-ON (>2.5VDC = ON, >1VDC = OFF), and the DIM control signal.
    If you do have the control signals but still no backlights then you have ineverter board problem. So look at the labels on the inverter board connector to find those required signals.
    I can see the ON/OFF (BL-ON) pin 12 but I cannot read the rest of the labels, pictures are way too out of focus.
    The fuse on the inverter board is OK, right?
    https://www.badcaps.net/forum/attach...5&d=1437243126
    • s_henya
      • Jan 2011
      • 480
      • Israel
      Thanks for replying budm,
      how do you suggest turning on the backlights?
      and what in your opinion the reason for not being able to turning the tv on/off?
      what voltages should i get on the connector on the inverter from the psu?
      (im not sure its lcd, maybe led) only 2 transformers and anly 2 wires to the backlight.
      (and YES the fuse is good- it was the first thing i checked :-) )
        "and what in your opinion the reason for not being able to turning the tv on/off?" That is the indcation of the main board problem and may be that is why it is not sending the ON/OF signal to the inverter board ON/OFF pin that you need to check.
        "what voltages should i get on the connector on the inverter from the psu?"
        Reply on post #2 "If you do have the control signals but still no backlights then you have ineverter board problem. So look at the labels on the inverter board connector to find those required signals.
        So check the DCV on that ON/OFF pin when TV is turned on.
        Your TV uses CCFL not LEDs for backlights. the LCD panle lookS to be made by LG, you can see LG printed on the inverter board.
        • s_henya
          • Jan 2011
          • 480
          • Israel
          ON CN1 (inverter board):
          PINS 1-5 : 24.79VDC (VIN)
          PINS 6-10: 0VDC (GND)
          PI 11: 0VDC (NC)
          PIN 12: 0.07VDC (ON/OFF)
          PIN 13: 0.037VDC (VBR_B) (maybe brightness?)
          PIN 14: 0.004VDC (STATUS)
          this means that the logic board isn't sending the on signal to the inverter right?
          could i simulate this signal by 1k resistor to GND OR 5V?
          i don't know if its active on LOW or HIGH.
          • s_henya
            • Jan 2011
            • 480
            • Israel
            what do you think?
            • CapLeaker
              Leaking Member
              • 8152
              Your BLon signal isn't there.
              • s_henya
                • Jan 2011
                • 480
                • Israel
                so this means i have a bad mainboard?
                what do think, this one might suit? RSAG7.820.1621 (the original was RSAG7.820.1856)
                http://www.ebay.com/itm/Hisense-Sign.../221829433473?
                • CapLeaker
                  Leaking Member
                  • 8152
                  make double sure that the BLon signal is not getting sent at the main board, before do anything. As far as the other main board goes, make sure it is compatible to the original one. It doesn't have to be the exact same, but it has to be compatible. I am not sure if that board on ebay is compatible or not. You would have to figure out in what TV that board was in.
                  • s_henya
                    • Jan 2011
                    • 480
                    • Israel
                    just ordered a mainboard from http://world.taobao.com/item/4262474...?fromSite=main
                    hope it will solve the problem.
                    I will update as soon as i will get it.
                    • s_henya
                      • Jan 2011
                      • 480
                      • Israel
                      Some progress:
                      I got the mainboard from china, got a little mad for being fooled by the Taobao agent:
                      'Taobeo Focus'- don't buy from him. he overweight your package so the shipping fee would be much higher.
                      this mainboard weighs 350grams. and the whole package weighs 1.15kg.
                      800gr of cardbox in cardbox in cardbox. instead of 5-10$ for delivery i payed 35$ for delivery only!
                      Back to the Tv:
                      now i can get it to power. the thing is that this mainboard was designed to work on a 42" instaed of 37". the control panel (touch buttons connector is 3 pins instead of 4)
                      i replaced the connector but still no luck. i can see that in my failed board i have an extra resistor which doesn't exist on my new board. i will try to transfer it carefully as it is very small.
                      i dont have the original remote. so maybe buying a universal remote would do.
                      any help on that too would be great!
                      • CapLeaker
                        Leaking Member
                        • 8152
                        Some main boards allow you change the screen size (37 vs 42") but that has to be done in service mode of the main board.
                        • s_henya
                          • Jan 2011
                          • 480
                          • Israel
                          I took the resistor from the failed board, showed almost 0 ohms.
                          So i just replaced it with a short. i have lights on the touch buttons and i can hear beeps upon touching. but only the power button gives something->opens the menu. :-(
                          i tried setting the cable company remote to work on the TV, it semi works,
                          by pressing the numbers i can power, and visit the menu. and source as well.
                          i have a perfect picture on hdmi1 but no sound. i can't set the volume scale.
                          i have to get a remote for this tv. anyone knows a good universal remote for Hisense?
                          • CapLeaker
                            Leaking Member
                            • 8152
                            Acoustic Research, Logitech... those can learn codes too
                            • s_henya
                              • Jan 2011
                              • 480
                              • Israel
                              I tried another remote,
                              now i can power, source, vol +-
                              I still got a perfect picture but no sound (tried SCART & HDMI).
                              maybe i recieved a faulty mainboard.
                              i can transfer parts from the old mainboard, but i never fixed a 'no sound issue' before
                              • CapLeaker
                                Leaking Member
                                • 8152
                                Do you get any sound at all? Try the TV channels. If not, check if the sound IC is getting proper voltage or for shorts?
                                • s_henya
                                  • Jan 2011
                                  • 480
                                  • Israel
                                  No sound at all.
                                  i found one smd cap broken missing on the back of the board, trasfered it from the faulty board but still no luck.
                                  cant seem to find the audio ic. maybe it's behind the metal bezel
                                  • CapLeaker
                                    Leaking Member
                                    • 8152
                                    must be underneath that metal shield that's where the traces go anyway.
                                    • Wolf1977
                                      is there power inverter from 24vdc to 48vac ?
                                      by Wolf1977
                                      hi i am looking for a power supply like the title and i canoot find
                                      i found only from 24vdc to 220vac ?
                                      08-06-2023, 12:25 PM
                                    • x_orange90_x
                                      by x_orange90_x
                                      01-29-2025, 09:24 PM
                                    • Coolgoodman
                                      Faulty Hisense 85Q6NAU TV
                                      by Coolgoodman
                                      85” Hisense TV
                                      Greetings,
                                      Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                                      Dear TV technicians of forum, I hope this message finds you well.
                                      I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                                      I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                                      07-24-2025, 03:02 AM
                                    • Gentian
                                      APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                      by Gentian
                                      I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                      It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                      03-06-2023, 07:07 AM
                                    • ShahZaib Ghumman
                                      Can I Swap Screens Between Two Hisense 75” QLED TVs?
                                      by ShahZaib Ghumman
                                      Hey folks,
                                      I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                                      A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                                      So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                                      03-25-2025, 10:59 PM
