Samsung UN32EH4003FXZA, backlight on, sound but no picture
  • beginner1
    • Jul 2015
    • 7
    Hello. I am trying to fix a Samsung UN32EH4003FXZA television. It has sound but no picture. I can see that the backlight LED lights up but there is no image on the screen at all. Using the remote, I can change the volume and the inputs just fine. I also don't see any image using a flashlight and a very dark room. Al of the cables seem to be seated fine.
    I have tried resetting the picture with the remote and I replaced the power supply board but it still has no picture.
    Any ideas what the problem is?
    Thanks!
    Re: Samsung UN32EH4003FXZA, backlight on, sound but no picture
    Pictures, pictures, and pictures of the whole backside of the TV and the boards.
    More likely the T-CON is not getting the Voltage from the main board for the T-CON to run, but we really do not know for sure of what you have in your TV since we do not have the TV in front of us to see.
    • beginner1
      • Jul 2015
      • 7
      Here's the pics I took. Thoughts? Thanks.
      • beginner1
        • Jul 2015
        • 7
        Here's another one.
        • beginner1
          • Jul 2015
          • 7
          And here's the main board
          • beginner1
            • Jul 2015
            • 7
            I also just noticed that I can turn on the tv with the button on the bottom but if I try to turn it off that way, the red light blinks and the tv stays on.
              This TV has integrated T-CON into the panel, so the only that you can do is to check the connector with that big black that goes to the panel and see if you do have 5V (or 12V) for the T-CON to run. This is not going to be easy because there is no label for the pins of the connector, you just have to trace out the connection to see which one is/are the power pin/pins.
              • hienton2
                • Sep 2009
                • 183
                I have same tv , same problem Can not turn off tv. tv has no picture..It has 12v on the address board fuse.
                Did you fix the tv.?
                • Ierwin
                  by Ierwin
                  05-13-2025, 03:31 PM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • gl4709
                  Samsung un55cu7000d with backlight and sound No Video / Picture
                  by gl4709
                  I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                  01-23-2025, 06:21 PM
                • LaPCon_IT
                  Samsung UE50TU7099U no picture no sound, backlight present
                  by LaPCon_IT
                  TV has one combo board (VTT55UH160). Symptoms are like this.
                  When part of the screen is disconnected (white part), it looks like this
                  Resistance and voltages (I don't know if they are good or not). The inductor with 0ohm/0V seems to be connected to GND.
                  I haven't noticed any shorts on rails listed below:
                  VGH - 30V
                  VGL- -9V
                  VAA - 14V
                  VCOM - 5.6V
                  STV - 11.95V
                  LC1, LC2 - +30/-12V
                  All CKV lines (no shorts between them) looks the same:
                  I've tried to cover some lines with...
                  12-15-2023, 03:55 AM
