Oppo BDP-83 Tray stuck in open
  • withalligators
    • Jun 2013
    • 267
    Hey folks,
    Oppo BDP-83. I got it with the tray stuck open. When you plug it in and turn it on you can hear it trying, and the motor pushes it out a few milimeters and then retracts it back a few milimeters. The gives an Oppo Blu-Ray splash screen.
    I tried updating the firmware with a USB stick which worked. It read the contents of the USB stick and performed the update flawlessly. It didn't change anything in the tray status though.
    Any ideas on where to start? Only other tray loader I've ever attempted was a Sega CD when I was 15 and that didn't end with a working Sega CD. I would really like to fix this one and feed it to my projector.
    Cheers,
    Alex
  • withalligators
    • Jun 2013
    • 267
    Re: Oppo BDP-83 Tray stuck in open
    Nothing, guys? Should I just open it up and see if there is anything immediately obviously wrong with the motor or something?
    • drussell
      • Nov 2014
      • 144
      That would be a good start...
      Sounds like a mostly mechanical problem. Look for something stuck in the mechanism or out of place or perhaps a faulty limit switch or something that tells it the position of the tray.
      • withalligators
        • Jun 2013
        • 267
        Well, I finally sat down to open this up and give it a shot. Holy moly, has it been modded by the previous user. Not sure what the mods are for but I'd bet it's a regional unlock, high quality stereo output, and better power deliver. But, I'm not sure. If I can get it running I'll post pics to see what you guys think.
        About the tray stuck issue, it is indeed mechanical. After puzzling how to reset it to full close, and finally getting it, I find out the tray isn't fully opening or under the power of the motor. Power wasn't transferring from the motor to the step up gear on the belt. Taking it off, I find out it's got a enough teeth ground down in one area to create a dead spot.
        I tried opening up a SATA dvd drive in a junk computer but the gear was not compatible. Any idea where I can find a replacement? I'd hate to scrap such a wonderful machine on a 10 cent piece.
        Cheers
        Alex
        • withalligators
          • Jun 2013
          • 267
          Well, I sort of fixed it. I cut a small amount off the small, cogged end and shimmed it down with some thin washers from the top. There seemed to be enough teeth left down there for solid geared contact.
          Anyway, now it's got a new weird problem. The magnet that is in the center of the disk holder (?), spindle (?), or whatever, that connects to the teflon/plastic covered thing on top of the drive when the tray is closed is so strong that when the tray is told to open it can't break free of the magnet. It tries for a few seconds and then it gives up and shuts again.
          I put a small piece of electrical tape over the magnet to lessen the force needed to break contact. This mostly works but not always, but it also causes the drive to not always read disks. and you have to flip the player upside down to get it to make contact. Any ideas? I thought a tighter rubber band / belt driving the door open might help but it seems pretty tight already.
          At this point I may look for a new drive entirely for the player but I also can't find that.
          Also, check out this modding, and tell me what you think it's for... Those switches especially.
          • ibgm
            • Oct 2013
            • 63
            • usa
            Try one of these....
            http://www.ebay.com/itm/NEW-MECHANIS...item541fd2233a
            They sell the replacement on E-Bay. Must be a really good unit, they go for big $$
              • 31293
              shops for model makers sell gears.
              so do some big electronics suppliers
              • withalligators
                • Jun 2013
                • 267
                Actually, Oppo said they'd send me one.
                I already have that drive saved in my watch list in case I can't do better. I'd like the whole drive with opening mechanism as well, but I doubt that will happen. It also doesn't won't spool up sometimes when you put a disk in it sometimes. and it randomly dropped sound once last night over HDMI. Weird. Think a new laser unit will solve that or think it's just bunked?
                  • 31293
                  hard to tell from that description.
                  what does the disc do when the tray closes - presuming you can see it?
                  • bogosort
                    Sony DVD player stuck tray (DVP-SR310P)
                    by bogosort
                    I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
                    Anyone knows why?
                    Thank you....
                    05-11-2024, 04:29 PM
                  • nervous_capybara
                    Repairing the Hitachi DA-6000 CD player
                    by nervous_capybara
                    Hello everyone !
                    I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
                    Feel free to share your experience if you ran into other issues.
                    DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
                    CD tray would not come out of the player
                    I could hear a motor spinning inside the player but the CD tray would not come out.
                    Turned out that the issue was the CD tray belt that aged poorly and began to...
                    11-05-2025, 03:11 AM
                  • Stunt
                    Hp Laptop Stuck on Hp protected by hp sure start screen
                    by Stunt
                    Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                    I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                    I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                    Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                    screen that's it and stuck there. I left it until the following day and i still...
                    09-02-2025, 01:51 PM
                  • stormanimal83
                    Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                    by stormanimal83
                    Hey....
                    Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                    my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                    01-18-2024, 02:15 PM
                  • ekozeko333
                    by ekozeko333
                    🧠 What I’ve Done So Far
                    Flashed...
                    06-21-2025, 02:48 AM
