Samsung UN46D6000SFXZA Standby Light Flashing
  • BrunoHJD
    • May 2015
    • 5
    I picked up a Samsung UN46D6000SFXZA recently, I did so knowing it didn't work and needed to be diagnosed and repaired.
    When the TV is plugged in the standby light does a double flash 5 times then goes solid for a few seconds and the cycle repeats. If I put my ear close to the power supply board I can hear what sounds like 5 clicks. The clicks happen while the standby light is solid red and the clicking stops while the light is flashing.
    I did a bit of research and have taken the TV apart and performed some of the tests in this document. http://www.toms-service-manuals.com/...df&mfg=Samsung
    When I disconnect the cable from the power supply board to the mainboard the back lighting does NOT light up. It acts in the exact same manner with the cable plugged in or unplugged.
    I figured I would start by testing the two 5v pins. When I tested pin 4 of the power supply I had an intermittent reading. It would sit around 0.1v then spike to 3.1v and it seems as though the spikes were in time with the clicking sound coming from the power supply but its hard to say for sure because of how fast the readings were changing. So I went down the list and tested some of the low voltage pins too
    Pin 1 shows no power
    Pin 2 rests at .012v and spikes to 0.3v
    Pin 3 shows no power
    Pin 7 rests at 0.1v and spikes to 2.9v
    Pin 9 rests at 0.6v and spikes to 1v
    Pin 10 rested at 0.6v and would spike to 1v
    I also tried disconnecting the T-con board and still had the same clicking sound and flashing standby light but I didn't check the power supply pin voltages at the time.
    All the components on the board physically appear to be in OK condition, no discoloration or ballooned out capacitors. While I know this doesn't mean those components aren't bad, I just figured I would point it out. The model number on the power supply board is BN44-00423A.
    Any help would be greatly appreciated and please let me know of any additional information I should provide.
    -Harry
  • sordids999
    • May 2013
    • 2152
    Re: Samsung UN46D6000SFXZA Standby Light Flashing
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
      Without the connector designator number and no pin names for each pin then the Voltage readings report does not help since we have no ideas what each pin of the connector are for.
      • BrunoHJD
        • May 2015
        • 5
        I took some photos with the back panel off and got in for a close shot on each board. I can take more zoomed in shots if they are needed.
        The connector I am testing is designated CN201. In The file I hyperlinked there is a "Power-Up Sequence" section on page 2. it lists the following for connector CN201
        Power-Up Sequence (CN201):
        1.Standby Voltage: Pin 4 (5Vdc)
        2.Power-ON:Pin 2 (Low-Hi voltage transition)
        3.Low Voltages:Pin 1, 3, 7, 9, 11, 12, 13
        4.Backlight On:Pin 10 (5Vdc)
        The results I listed are the readings I obtained from checking those pins.
          So right now your standby Voltage is not stable "It would sit around 0.1v then spike to 3.1v"
          And if you disconnect the cable between power supply and main board, is the standby Voltage stable?
          At this point, it looks like you do have problem with the power supply/LED driver board.
          There is repair kit for this board.
          http://www.shopjimmy.com/catalogsear...?q=BN44-00423A
          • BrunoHJD
            • May 2015
            • 5
            I just tried unplugging the cable from the mainboard to the power supply and the clicking becomes constant. The voltage is now continuously bouncing between 3.3v and 3.8v on pin 4. If I reconnect the cable it returns to a cycle of 5 clicks and the voltage returns to 0.1v constant with a 3.1v spike while its clicking.
            Do you think that repair kit would fix this particular problem or should I just go for a new power supply board?
              "Do you think that repair kit would fix this particular problem or should I just go for a new power supply board?" I have no idea, you need to look at the parts in the kit to see what section of the board is being repaired. We do not have the diagram for the board so you will have to trace out the connections on the board, get the spec sheet of the parts so you can start checking the Voltage feeding each section of the board. I hope you are good at drawing up diagram after tracing out the board, I would look at the standby power supply section first.
              • BrunoHJD
                • May 2015
                • 5
                I just wanted to post a quick follow up for anyone that owns this model and is experiencing the same issue with similar test results. I replaced the power supply board and the TV powered up and is working without any issues.
                • 7ony
                  Samsung plasma - flashing standby light
                  by 7ony
                  The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
                  Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
                  Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
                  No visible...
                  08-31-2020, 05:18 PM
                • Bloopeta
                  Samsung UE43KU6400U Flashing Red Standby Light
                  by Bloopeta
                  Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
                  Power button does nothing
                  Have unplugged the mainboard, and backlights illuminate.
                  Have tried removing panel ribbon cables one at a time, and that makes no change.
                  With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
                  Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
                  09-11-2023, 02:34 AM
                • fuxxy
                  Samsung UN55D6000FXZA - Won't stay on, standby light flashing rapidly
                  by fuxxy
                  This is a set I posted about a few years ago. Replaced LED strips and worked fine until now.
                  Plug the set in, and it will turn on and functions with no issues.
                  After a while, (sometimes hours, sometimes minutes, sometimes immediately) the tv shuts off. When I approach the TV I notice the standby light is flashing rapidly, but the pulse of each flash is not long enough to notice from afar.
                  Other than the standby light, the unit is completely unresponsive until the power is removed and reapplied, then the cycle starts over. It does appear that the time it takes...
                  08-02-2022, 09:44 AM
                • ChristianBr01
                  LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                  by ChristianBr01
                  I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                  The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                  What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                  04-23-2025, 01:48 AM
                • esqmooo
                  HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                  by esqmooo
                  Hello everyone.
                  This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                  Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                  Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                  I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                  03-11-2025, 03:57 PM
