Sony KDL32EX302 picture problem
  • gurug
    • Mar 2015
    • 27
    • Slovenia
    Hello to all!
    I have a problem with my Sony KDL32EX302, you can see it in attached picture and also in this video:
    https://www.youtube.com/watch?v=je0q...ature=youtu.be
    What is culprit for this, bad panel, mainboard? Any suggestion where to look for fault?
    Thanks!
  • gurug
    • Mar 2015
    • 27
    • Slovenia
    Re: Sony KDL32EX302 picture problem
    Originally posted by gurug
    Hello to all!
    Thanks!
    Anyone, please any ideas ....
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Would say bad panel on this one sorry mate, sony seem to be ok tvs but use crappy panels.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Hate this. I had a Samsung 32" doing the same thing a while back. Was sorry to part with a good set. Ah well...sometimes we have to let go...
        • gurug
          • Mar 2015
          • 27
          • Slovenia
          Thanks for clearing this up to me ... Regards!
          • senndogg
            • Dec 2011
            • 383
            • Albania
            Hi, sorry to revive this old post, but this was just to clarify same problem.
            Totally fault of the samsung lcd.
            cheers.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4544
              • Italy - Milan
              I think this fault can be fixed with a simple fix but not sure on the lasting of the repair...
              • retrorepair
                SONY KDL-40P3600 Picture Problem
                by retrorepair
                Hello gurus, hope you can assist me...
                I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
                I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
                Thanks in advance.
                10-11-2024, 05:12 PM
              • Chrissygizmo
                Sony KD-55XG9505 lines on screen problem
                by Chrissygizmo
                Hello again everyone,
                This is my latest mission, to try getting this Sony tv back to normal working order…
                I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                02-19-2025, 11:31 AM
              • iglitare
                by iglitare
                09-04-2025, 07:13 AM
              • tree5656
                diagnosing sony XBR-75X900H. NO PICTURE
                by tree5656
                This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
                11-09-2023, 04:55 PM
              • crackedprint
                Sony HCD-HX80R Amplifier Volume Control Problem
                by crackedprint
                I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                I have tried a Cold Reset as per the service manual.
                I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                I have looked all the way through the service manual and tried many online...
                01-21-2025, 12:18 PM
