Backlight issue LG 50ln5600
  • Steve L
    • Oct 2015
    • 4
    Re: Firmware eeprom LG 50ln5600
    Well, for 50LN5600, LG.com support has no software upgrades available, either. It means if no upgrades, then no software file available there.
    Seems strange that data pins are grounded on this samsung:
    I would just find a used bd on ebay or something. Just saw one for $28. /free ship.
    • Shane711
      • 493
      Re: Backlight issue LG 50ln5600
      Yes, you are right, no software available for the 50LN5600. I even contacted LG and they couldn't help. Of course the TV is working now because I bought a used board but I have another board here that is no good without a new EEPROM. For the time being it is on the back burner. One day when my knowledge increases it will be fixed. I am guessing the EEPROM is not the normal IC and may even be located in the Main IC.
      • Steve L
        • Oct 2015
        • 4
        Ya. Doh, doh. I was not up to speed on this still. On my Samsung schem, the data pins--p1,2,3(A0,1,2) are really logic inputs--not data inputs-- for like chip enab, output enab, write enable-- so SDA is serial data input and SCL is the clock for that--all that's needed for read/write.
        So--eeprom IC IS normal (24c256)-- but you can either replace IC, get upgrade firmware from LG, or find .rar file on internet. Sometimes repair kits with eeprom are available on internet/ebay. I doubt there's memory for this file in CPU on board.
        A bad eeprom is not all that common, though--especially on stuff not made in very cheap places.
        I usually replace main board for 25-$125. because time is money--but interesting all the same.
        Best of luck! What is symptom with this TV? You probably googled it to death already.
        • Shane711
          • 493
          The TV would turn on and be stuck on the LG logo, after about 1-2 minutes the TV would turn off.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5009
            • New Zealand
            #45
            IC100 is apparently the EEPROM, a 24C256. Why they marked it with the cryptic code of "4HA7" I have no idea. All other SMD EEPROMS I have ever seen have the standard part number on them.
            If you're feeling keen you could try copying the data from the working board's EEPROM to the bad one and see if it fixes it.
            -David VanHorn
            • edugimeno
              Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
              by edugimeno
              Hi There!
              I'm trying to help my friend who owns a restaurant be just bought.
              He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
              It's stuck using, I guess, the 2 sided tape that comes with the strip
              The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
              09-05-2024, 09:34 AM
            • thetonywarren
              TCL 43S435 NO BACKLIGHT ISSUE, LEDS TEST OK
              by thetonywarren
              I have a TCL 43S435 with no backlights. I contacted ShopJimmy and they said power supply. I got replacement power supply, but still doesnt work. I have confirmed that there is an image with flashlight test. I have also verified that the led strips work when I probe them with LED tester. Any ideas would be helpful. I am also geting a double blink on the status led when trying to turn it on......Nothing on the power supply looks suspect, and caps look ok. Where should I start to test......Thanks!...
              04-23-2025, 10:48 AM
            • rounin
              MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
              by rounin
              🛠 Original Issue
              ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
              04-19-2025, 01:18 AM
            • x_orange90_x
              Backlight Reflector Modification
              by x_orange90_x
              I am writing this because I came looking for the same information but couldn't find anything. There are certain model tvs that will have 2 or more different backlight strip configurations and there is often no way to tell exactly what you have without disassembling the panel. Twice now I have run into this issue and ended up ordering the wrong sets BOTH times. The previous TV I reordered the correct ones and went on my way. The second one I had no patience for returns or reorders, let alone peeling the brand new strips back out and risk damaging them.
              The number of LEDs per pair is...
              03-12-2024, 08:32 AM
