Backlight issue LG 50ln5600
  • 7thkey
    • Jun 2015
    • 16
    • usa
    I have an issue with 3 backlight strings not lighting. I turn TV on top 2 strings light, bottom string lights. Middle 3 do not. Then all backlights turn off due to protect . I tried switching out different working stings to result in always the same result. This model has the led drivers built into power supply. I replaced power supply also same result. I do have picture and sound via flashlight test.
    From top to bottom led+ 108 to 78, led- 40, led+ 170 then slowly drops,led- 61.
    I have not replaced or tried a bypass jump of main board. I have not replaced the led strip connector board (66371-0021A) it shows no sign of distress or problems.
    I've seen similar models have bad LEDs and diodes have been used in place. My problem is not open LEDs as mine all work and check out.
    Any help would be appreciated thank you.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Backlight issue LG 50ln5600
    Leds don't fail open they fail like incandescent light bulbs and just plain don't light due to the whisker inside of them snapping. The leds strips will be wired in series so if one diode fails the rest of the strip wont light. Can you take photos of the inside of the screen and of the strips please.
      If they failed open, you would expect the rest of the strip to fail.
      If they failed SHORT, then the strip would work but that LED would be out.
      • 7thkey
        • Jun 2015
        • 16
        • usa
        I'll get a picture up tomorrow. Each led strip is made up of 2 strips. They are in 6 rows top to bottom. No matter what set of LEDs I swap in. Only the same 3 rows light up then shut off. If I swap the lighting 3 with the non lighting 3 the same three rows continue to light . At first I believed 3 rows of LEDs were bad and needed replaced. I swapped those rows with the working LEDs and they would not light. The LEDs open or shorted does not seem to be the issue. The issue is what would make 3 entire middle rows not light up if the LEDs on those rows are all in working order?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Ahh right ok and how are they connected, as in what type of connectors go to the leds ?
          • 7thkey
            • Jun 2015
            • 16
            • usa
            They have a plastic plug in type connector.
            This is the direct replacement parts for it.. Each LED string is 2 pieces that attach to one another forming 6 long strings that connect to that board by the same plug in.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Hmm ok, in the past I have had issues with them plastic plugs corroding and not making a proper connection to the strips. Do you have a multimeter so you can see if there is continuity between the connections to see if the connection is being made and working ?
              • 7thkey
                • Jun 2015
                • 16
                • usa
                The LED strips do have a + - test points. I believe I can test them in diode mode. I'll try that tomorrow and get some readings. I really don't think its a contact though as I can switch out different strips and they light up in the working rows.
                • 7thkey
                  • Jun 2015
                  • 16
                  • usa
                  Pictures of LED setup.
                  Second picture shows one set lit 3 sets light up and then go out fast . I have swapped out all LED strips and no LEDs are out.
                  In the last picture I labeled them 1-6 to show voltage (red x indicates does not light up on start up) the red x LED strips do work though if I swap them.
                  1) 63v
                  2) 170-78v
                  3) 146-55v
                  4) 50-0v
                  5) 110v-78v
                  6) 86v-55v
                  The first voltage is power on voltage.
                  The second voltage is the constant it ticks down to and stops at.
                  Well it won't let me upload the photos. I'll try later I guess
                  • 7thkey
                    • Jun 2015
                    • 16
                    • usa
                    3rd pic upside down not sure why sorry.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Wait so when you swap the strips into the others position they light ?
                      • 7thkey
                        • Jun 2015
                        • 16
                        • usa
                        Ya if I put the non lighting LED strings in the 3 spots that light they light up. Clearly position 4 is where the voltage stops. I have tested that strip and nothing it lights up fine in the top spot. So what would cause one string to get no voltage on power up? The green connection board is 6637L-0021A. The power supply EAX64905501 v2.2 was swapped out for another same version I was told was tested and working properly. I guess it is possible I got a bad board but to both have the same LED string out is unlikely. Is it possible the motherboard could be not sending the signal to the LED drivers on the power supply? Is there a way to run the power supply not connected to the motherboard (jumper maybe)?
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Right I know you may have done this already but, carefully check all the strips and use a pen or something to mark off the strips so that you know they are definalty good. I dont think that the mobo is at fault possibly the boost converter but sounds like a tricky one.
                          • 7thkey
                            • Jun 2015
                            • 16
                            • usa
                            All strips are good. I have done the diode to ground test and each one separate . Every led lights then fades properly as the remaining voltage is drained. So boost converter? On what board is that as I already replaced the power supply/LED driver board?
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5084
                              • New Zealand
                              It sounds to me like that Green board on the end that all the LED strips connect to is bad at some places. Maybe some of the connectors are bad or there are broken traces or cracked solder joints. That would fit with the strips lighting or not lighting depending on which position you plug them into.
                              Have you checked for continuity between the plug from the PSU and the outputs to each of the LED strings?
                              -David VanHorn
                              • 7thkey
                                • Jun 2015
                                • 16
                                • usa
                                I did in the start of the post . I measured the 2 led+ and 2 led-. I have not replaced the thin green board yet. That's my next step unless someone chimes in on what would cause one string to get no voltage. I've tried 2 different power supply's.
                                • 7thkey
                                  • Jun 2015
                                  • 16
                                  • usa
                                  So today I measured the voltage on the 4 points on the plug that connects to the thin green led board. Before they enter board they are 78,0,78,0 that seems up to spec. I'm thinking at this point replace all LED strips and that green board. The LED strips may light up fine but if one is triggering the protection shut off.
                                  • Hamie
                                    • Apr 2014
                                    • 1383
                                    Maybe it's just not making a connection, what about dabbing a bit of solder on the Led strings so it fits tighter into the harness.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      I agree with Hamie add some fresh solder to the points. If that fails pull off the plastic connector thats at the end of each strip and bridge the gap with solder and some wire.
                                      • Hamie
                                        • Apr 2014
                                        • 1383
                                        You may not actually need to desolder the connector, most led strips have a + and - points, you could simply connect those points with a bit of wire to the board.
                                        • edugimeno
                                          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                          by edugimeno
                                          Hi There!
                                          I'm trying to help my friend who owns a restaurant be just bought.
                                          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                          It's stuck using, I guess, the 2 sided tape that comes with the strip
                                          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                          09-05-2024, 09:34 AM
                                        • Robin21
                                          Ubiquiti US-48-500W – No LAN Port LEDs, Possible 12V Issue?
                                          by Robin21
                                          I’ve got a Ubiquiti switch (model US-48-500W, motherboard: USW48P_BCM) on my bench. The switch powers on, but none of the LEDs next to the LAN ports light up.
                                          I’ve measured voltages across the board and suspect a problem with the 12V rail. At the coils where I’d expect 12V, I’m seeing around 6.3V. One coil shows a stable 6.378V, while the other fluctuates between 6.270V and 6.310V.
                                          All other voltages seem fine — 1V, 3.3V, and 5V are present and match the expected values.
                                          I've replaces both buck regulators already (AOZ1212)...
                                          09-25-2025, 03:24 AM
                                        • thetonywarren
                                          TCL 43S435 NO BACKLIGHT ISSUE, LEDS TEST OK
                                          by thetonywarren
                                          I have a TCL 43S435 with no backlights. I contacted ShopJimmy and they said power supply. I got replacement power supply, but still doesnt work. I have confirmed that there is an image with flashlight test. I have also verified that the led strips work when I probe them with LED tester. Any ideas would be helpful. I am also geting a double blink on the status led when trying to turn it on......Nothing on the power supply looks suspect, and caps look ok. Where should I start to test......Thanks!...
                                          04-23-2025, 10:48 AM
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          🛠 Original Issue
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
