Sony with double image on half of screen, bad panel or something else?
  • douellette88
    • Jun 2015
    • 61
    Hello, have a Sony KDL-46V3000 LCD tv. When it is on there is a slightly darker area in the middle of the screen and then a double image on the right side. Left side displays just fine. I have replaced every single board on the back with supposed good boards, except for the power board, the right inverter/backlight board, and the tv tuner board. At this point I am suspecting a bad panel What do you guys think? I've attached a pic below of what it looks like.
    https://goo.gl/photos/bqDiQiq1ut1Aq7R98
    Re: Sony with double image on half of screen, bad panel or something else?
    Its the panel, Bad tab bonding.
    https://www.badcaps.net/forum/showthread.php?t=37887
    • douellette88
      • Jun 2015
      • 61
      Damn it , was hoping I could repair it. luckily I only paid like $12 for the tv haha. I have another tv I will be posting about as well.
      • steviewonder
        • Dec 2013
        • 183
        • england
        You possibly could "repair it", I have had some success with tab bonding bodges in the past,have a go,plenty of info about it,using wedges,etc..After all,you have nothing to lose,apart from a bit of time !
        • douellette88
          • Jun 2015
          • 61
          yeah I was looking into the tab bonding thing where you can temporarily fix it, so I may give it a try
          • Formaster
            Sony KD75XE9005 Bottom half double image
            by Formaster
            Hi guys,
            I'm tyred from these sympthom, if anyone helps me really big thx.
            When i open the connection and play with these ribbon cables, i can get back the image problem free. BUT after turn off and ON, the bottom half is ghosted/doubled again. Did'nt from touch, only reboot the TV. I have changed the ribbons from the other side, but the same. Anyone any idea please?...
            08-10-2021, 06:57 AM
          • viewfindr
            Samsung UN46D6500VF - no display, odd lines and double image on half of display
            by viewfindr
            Hi there, I'm seeing some tips/advice on how to pinpoint what might be going on with my TV. This is a continued discussion from this thread, as users suggested I should start a new topic to discuss my problem. In summary:
            Before I took the set apart, I started to see a double image come on after the set is powered on for a few minutes. (attachment #1).
            I came across this YouTube video, which seemed to describe a very similar phenomenon from what I was seeing. (In summary, the video suggests unplugging one cable, and using a small clear piece of tape to cover various...
            05-02-2020, 03:27 PM
          • howardc64
            TCL 49S405 double image
            by howardc64
            LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
            This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
            06-23-2025, 03:20 PM
          • bubbajoey
            Sony Bravia KDL-65W850C red tinge and double image
            by bubbajoey
            Long time lurker first time post.
            I was recently gifted a KDL-65W850C that had a faulty backlight LED, replaced the strip and it now has a functioning backlight.
            The issues now are that skin tones are red and also I'm getting double images
            and "ghosting"? on right hand side. I have attached pics.
            Also the "tab" on top right of panel is hot to the touch, when I do touch it does affect the picture slightly. The other tabs are cool to the touch. Pic also attached...finger in (pic because camera wouldn't focus)...
            03-25-2021, 11:56 PM
          • domix
            Sony KD - 65XF9005 - No image, sound OK
            by domix
            at tv KD - 65XF9005 i have a problem.
            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
            is this a common problem for this tv?
            i attached pictures of inside. Supply board looks okey, no blowed caps....
            07-21-2025, 06:37 AM
