Samsung BN44-00194A power supply dead
  • london-freddie
    • May 2015
    • 472
    helping a friend with a dead Samsung PS42Q96HDX/XEU plasma tv
    Dead no sign of life at all
    Apparently just went off whilst watching tv
    Power board is BN44-00194A
    checked 4 fuses on power board all ok
    no voltages on any of the boards outputs
    Anyone had dealings with these power boards, or where do I start checking
    I know I can get a used board off ebay however I would like to have a go at fixing this board myself, with your help of course
  • ammarben
    • May 2013
    • 63
    • algeria
    Re: Samsung BN44-00194A power supply dead
    first you have to check STD_5V delivred by VIPER22A
    ICB801S and component around
    • ammarben
      • May 2013
      • 63
      • algeria
      check for short diode DB401 SB560 and dont forget caps
      • london-freddie
        • May 2015
        • 472
        DB401 seems to be ok no short, what where is SB560 can not find it
        • ammarben
          • May 2013
          • 63
          • algeria
          DB401 is SB560
          • london-freddie
            • May 2015
            • 472
            got that db401 is ok all caps look ok, 2 glass fuses in centre of board are good but no power at those fuses when power applied to board
            • ammarben
              • May 2013
              • 63
              • algeria
              • sordids999
                • May 2013
                • 2149
                https://www.badcaps.net/forum/showthread.php?t=46606
                might help you along the way
                • london-freddie
                  • May 2015
                  • 472
                  no 5v
                  • sordids999
                    • May 2013
                    • 2149
                    checked for cold solder joints ?
                      What DCV do you get between the cap CB801?
                      Notes: the SCHEMATIC may not be 100% correct.
                      • victor_cj
                        • May 2015
                        • 90
                        • Romania
                        Check or replace RB806, ZDB803. I had this zener diode faulty.
                        The art of fighting without fighting
                        • london-freddie
                          • May 2015
                          • 472
                          replaced power board with a used board tv powers up fine now, I call it fixed, however don't know what is wrong with original power board, thanks for the help guys
                            Thanks for the follow-up.
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                            • Andreas_de
                              Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                              by Andreas_de
                              Hello!
                              i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                              Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                              Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                              04-12-2025, 10:38 AM
                            • kevin_allein
                              Samsung QE 75 Q 7 FGMTZG Power Supply dead
                              by kevin_allein
                              Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
                              In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
                              Does anyone have schematics for that board ?
                              Any good tip, what could be the issue ?
                              02-27-2025, 12:15 PM
                              by sam_sam_sam
                              07-01-2024, 06:34 AM
