panasonic plasma tc-p50s2 red light 10 blinks
  • kphobden
    • Jun 2015
    • 4
    I have a Panasonic plasma tv that the power light blinks 10 times. Upon reading other threads, I decided to replace the power supply board. Unfortunately this did not solve the problem. I read that you need to isolate the SS and SC board but was not sure how to do this.
  • kphobden
    • Jun 2015
    • 4
    Re: panasonic plasma tc-p50s2 red light 10 blinks
    Additional info - I disconnected the SS board and still 10 blinks. I then disconnected the SC board and then 7 blinks.
    • iFixStuff
      • Oct 2015
      • 18
      Hello, did you ever resolve your issues?
      • Chungalin
        • Jul 2014
        • 423
        • Spain
        You'll get more help if you ask a moderator to move this thread to the proper subforum.
        • tw2005
          • Oct 2011
          • 6458
          A well aged thread but for anyone reading with what the original OP has written it's sounding like it's another SC board failure.
          If you disconnect sc2, ss11,p35, the 3 white ribbons attached to the A-board and the TV on , it should with no error.
          No error means it's not the A or P boards and if it still 10 blinks then A or P.
          don't reconnect sc2,ss11 or p35 until then is no residual voltage present on those.
          • Fordman
            • Dec 2017
            • 28
            Just got the 10 blink code today have questions
            • crt man
              • Mar 2013
              • 106
              • England
              Ask your questions, and please post good clear pictures of the boards and layout in the back of the set.
              Alan
              • Fordman
                • Dec 2017
                • 28
                I just got the 10 blink code today. I found a flow chart to help trouble shoot issue. I unplugged s11 and s33 still get 10 blink. Then they say unplug sc2 and c20 now I get 6 blinks so think sc board or sd or su board bad. But the chart stopped there.
                • Fordman
                  • Dec 2017
                  • 28
                  [/URL][/IMG]
                  • Fordman
                    • Dec 2017
                    • 28
                    Found another site and figured it's the sc board. Checked the su and sd boards for shorts and all was good. So now to find a sc board but have found repair kits. What kit and what transistors need changed.
                    https://www.justanswer.com/tv-repair...continues.html
                    • Alicat
                      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                      by Alicat
                      Stopped by this site trying to fix my parents Panasonic Plasma TV.
                      Model number is TH-50PZ85U
                      Power comes on and the red power light stays on solid.
                      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                      I also hear a few clicks.
                      I also think my parents said there was a thunderstorm and the TV failed after that.
                      Section 6 in the service manual talks about power and no screen,...
                      10-30-2024, 10:09 AM
                    • jm1234
                      Panasonic plasma TX-P42ST50 - 6 blinks
                      by jm1234
                      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                      I checked that board for any obvious faults...
                      05-22-2024, 06:59 AM
                    • Elecfronicsssss
                      DA0NJJMBAG0 charging light blinks
                      by Elecfronicsssss
                      Laptop motherboard DA0NJJMBAG0
                      PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                      CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                      GUIDE ME WITH THE PROBLEM..
                      SUMMARY-
                      1.NO 1.8VOLTS ON BIOS PIN NO 8.
                      2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                      05-12-2025, 02:32 AM
                    • stecos
                      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                      by stecos
                      Hi everyone!
                      For my passion for technology I'm now collecting several...
                      11-28-2022, 11:39 AM
                    • Biruslapio
                      Panasonic P58V11B 8 and 12 blinks error "fix"
                      by Biruslapio
                      Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                      Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                      04-13-2021, 07:13 AM
