Vizio regulator IC question
Re: Vizio regulator IC question
Lack of schematic is always a problem with these things... makes it hard to do...
There are 2 things I can think of doing right now.
1) Make sure the PSU is OK. To do that you would need to manually jumper it on. Disconnect the output cable from the mainboard (important!), and then use a 1k ohm resistor to jumper 5.6vSB to PSON.
That should bring up the 12v output. If that works we know it's the mainboard at fault here.
2) Start looking at the mainboard for ideas... post good clear photos of it here. We need to find any fuses that may be on it, and start checking those for a start. Also that regulator you started with may provide some clues. We need to find out of it is powered from the 12v rail or somewhere else.
EDIT: also it's possible your EEPROM is bad. This is a known problem and the set not coming out of standby is one symptom of that. You can get new EEPROMs online, but it would pay to check the more basic stuff first.Last edited by Agent24; 06-12-2015, 04:41 PM."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
IF the PSU already has a resistor to limit current in that part of the circuit, then maybe.. but since we don't know, you should use a resistor as it's safer. Otherwise you risk destroying something and then you make the problem even worse."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
OK I'll see if I have any but I doubt it. I have another vizio but different model so I tried putting that PSU in to see if it would work but the same problem. I know that PSU works because the other visio turns on. It has a different issue I'll probably post in another thread after I figure out what's wrong with this one.
Anyway here's a picture of the main board with the regulator in question circled.Comment
Well first thing would be to check the fuses on the mainboard right next to the power input. Check parts F1 and F2 there for continuity."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
Does it have 'F?' designator printed next to it? It does not look like fuse to me.Never stop learning
SJ sells EEPROM if you have problems as shown below:
http://www.shopjimmy.com/catalogsear...q=Vizio+e320vl
IMPORTANT:
These main boards can have multiple failures, in addition to the EEPROM.
If EEPROM replacement does not repair your board, there are likely additional problems.
From SJ:
Symptoms EEPROM replacement CAN fix:
- Display is frozen on VIZIO logo screen*
- TV won't power on with remote/buttons when plugged-in (VIZIO is lit in orange, but won't turn to white)
- TV turns on when first plugged-in, but it won't turn back on after 30 minutes of being off
- TV shuts off and goes back to standby mode (orange VIZIO lit) after you turn it on
Symptoms EEPROM replacement CAN NOT Fix:
- TV turns on but has NO backlight
- TV turns on AND backlights are on, but has no video display at all
- HDMI issues
- Audio issues
And BTW, those 2 fuses on the main board are for the 5VSTBY and for the switched 12V.Last edited by budm; 06-12-2015, 09:33 PM.Never stop learning
Is there anyway to test the EEPROM? I guess that's what my first question should have been. I've done a ton of research on these piece of **** tvs and EEPROM is a big one. Every I know who has had a Vizio has had problems. People need to get the word out on how crappy these tvs are.Comment
I think the only way to (somewhat) test an EEPROM is to read it and compare with a known good copy of the data.
Since I'm assuming you probably don't have the equipment to do that, or a known good copy of the file, the easiest solution may be to just replace it with a new one.
At this point you could also check all the voltage regulators that run from the 5.6v standby rail (finding which ones these are would be fun without a schematic) and ensure they are working.
Since your model has a known EEPROM problem and your fault symptom is consistent with a bad EEPROM, it may be worth trying that."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
Since your model has a known EEPROM problem and your fault symptom is consistent with a bad EEPROM, it may be worth trying that.Comment
1 more question. Do you know if any of those pins can be bridged on the EEPROM? I just have a soldering gun and it's easier if I can bridge some of the pins. The last IC I soldered had pins that were able to bridge and made it much easier then soldering each individual pin.Comment
With a lot of extra flux and a careful application of the soldering gun you might be able to pull it off, BUT I would not recommend a soldering gun on such a delicate multilayer board anyway.
I would strongly advise you get a 25-30 watt pencil iron with a medium-small chisel tip and use that. Even a cheap one should do. With care, you can solder individual pins at a time, although you may find it easier to use a drag soldering or flood-and-suck method. You can find videos for these things on YouTube.
But in any case, with SMD parts, lots of flux and very little solder is key to avoid bridges when soldering by hand."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
Okay I got the EEPROM. The guy also suggested replacing the memory capacitors to prevent the problem from happening again. In the picture am I correct on the EEPROM chip and the memory capacitors? The capacitors that are on the board are larger than the ones I ordered.Comment
I think you are correct on the EEPROM (check IC part number to be sure)
No idea about the capacitors. If he suggested it, you should probably ask him which ones he's talking about. Did he send you those new capacitors too?"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
Assuming...7 Photos -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by caspianDear Members,
I have an old analog voltmeter that can correctly measure DC voltage between 0v to 3v. The voltmeter is made by Toyokeiki depicted in the photos. It does not need any battery. It works using a coil and a magnet as any other analog voltmeters.
I am going to convert this voltmeter into a DC ammeter that can measure DC current between 0A to 15A.
To do this, I use a 0.2 Ohm resistor for current sensing in the circuit. Then, I use the setup depicted in the photo to measure current.
For example, if the power be 12v and the load be 8 ohms, the voltmeter shows... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by disorderhello,
i have a hp display 2311 to repair, totaly dead
on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
thank you-
- Loading...
