Vizio regulator IC question
  • danman
    • Jun 2015
    • 26
    I have a Vizio e320vl that does not turn on. When plugged in the vizio lights up amber but nothing happens when I hit the power button. I'm about 99% sure it is not the power supply because the voltages are correct. I don't get a reading on the 12 volt pins however so it leads me to believe that the main board is at fault. I don't have a digital voltmeter but when testing the regulators with my analog voltmeter the readings seem accurate except one regulator. When I try to test it the needle on my voltmeter doesn't budge. I'm assuming this is the regulator causing the problem. My question is what regulator is this? I've searched online to see what kind it is but I get no results. I edited a picture in the attachments to show you exactly what the regulator looks like. Any help would be much appreciated.
    The first 2 1s could be ls but I'm not sure. It's really hard to see even though I have great eyesight its too faint to tell exactly what it is.
    Re: Vizio regulator IC question
    1.8V fixed regulator.
    Are you getting any DCV at the input pin of the regulator. Some of the regulator ICs on the board may not have any input Voltage until the 12VDC is present.
    The 12VDC power supply is turned on by the PS-ON signal generated by the main board when power switch is activated.
    You should post TV questions in the TV section.
    • danman
      • Jun 2015
      • 26
      turns out I was way off. I didn't know my phone was capable of this kind of picture but I got an excellent shot of the chip, so here it is.
      • danman
        • Jun 2015
        • 26
        Sorry about that. I'm new here. If someone wants to move this thread feel free. I'm not getting a reading on any of the pins on that chip. The other regulators have readings that seem normal but as I said I don't have a digital voltmeter right now so I can't say for sure.
          You have to find out at least if you do have input Voltage, no input Voltage = No output Voltage.
          So look up the spec sheet to get the pinout of the IC and go from there.
          You should also read this:
          https://www.badcaps.net/forum/showth...999#post300999
          • danman
            • Jun 2015
            • 26
            Input voltage; that's the pin on the right correct? If so I checked it and got no reading. Would that indicate that the chip is bad? All the other regulators have readings on the input pins. If it is that the chip just isn't getting power because the power supply isn't on where do I go from there?
            • danman
              • Jun 2015
              • 26
              Also I'm new to testing regulators and all that. I've done low level surface mounts in the past on ICs but I don't know how I would go about finding the pinout of the IC in question.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4953
                • New Zealand
                The same way you find out the pinout for any IC.
                Find out the IC part number and look up the datasheet. The datasheet should have a picture showing the pins and their names\functions etc.
                In this case it may not be obvious, but as already mentioned what you have is a generic 1117 type regulator IC. It's a low-dropout linear regulator and they are very common in many products. They come in many options with various output voltages and also adjustable versions too. Like any very common IC, they are made by many many companies, but are all ultimately the same, including the pinout. So, find yourself the datasheet for a 1117 regulator and look at it
                In your case it's a 1.8v regulator - that's what the "18" on the package means.
                Alternatively to the datasheet, the board designers have very nicely silk-screened the pinout on the board next to it as well! (NOTE: Sometimes silk-screens can be wrong! In this case it is correct, but bear that in mind!)
                Refer to the link budm already posted to see how to actually check the regulator...
                -David VanHorn
                • danman
                  • Jun 2015
                  • 26
                  Thank you guys for your help. Either way I'm not getting any kind of reading on this chip so either it doesn't get a load until the power supply has been turned on or the chip is no good. What would be my next step in diagnosing the problem with this tv?
                    No input Voltage = No output Voltage.
                    The next thing we need will be be the good clear pictures of the whole back side of the TV so we can see how all the boards are connected, and the good clear pictures of the power supply board so we can see all the pin labels of all the connectors.
                    Then we will need the DCV readings of all the connectors when TV is plugged in and when power switch is activated, you MUST provide all the pin names next to each readings.
                    • mariushm
                      • May 2011
                      • 3799
                      It's probably a 1117 1.8v linear regulator, but don't take my word for it. Most likely SOT223, but could be SOT89 ...
                      See for example : http://www.digikey.com/product-searc...=0&pageSize=25
                      Something that may be the right part: http://www.digikey.com/product-detai...ICT-ND/4505204
                      Read the datasheet linked on the page.
                      • danman
                        • Jun 2015
                        • 26
                        In order from left to right I'm getting roughly 5.6v on the first three pins then 0 after that. When I try to turn on the TV I get nothing on the 12 volt pins.
                          "Then we will need the DCV readings of all the connectors when TV is plugged in and when power switch is activated, you MUST provide all the pin names next to each readings."
                          So try again. Without the names how we tell what are missing?
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4953
                            • New Zealand
                            From the silkscreen it looks like from the left, the first 3 are 5.2v standby, next 4 are GND, the next 3 are 12v, although the colours are inconsistent - looks like they just used rainbow cable! We need to see the bottom of the board to see if the pins are actually connected together or if the silkscreen is just wrong.
                            Last 4 pins with thinner wires are probably the control lines instead of power, last one is DIM anyway... Are there any names silkscreened to say what those pins do? Might be they tell you on the other end of the cable at the mainboard??
                            Looks like:
                            Pin 1 - 5.2vSB
                            Pin 2 - 5.2vSB
                            Pin 3 - 5.2vSB
                            Pin 4 - GND
                            Pin 5 - GND
                            Pin 6 - GND
                            Pin 7 - GND
                            Pin 8 - 12v
                            Pin 9 - 12v
                            Pin 10 -12v
                            Pin 11 - ??
                            Pin 12 - ??
                            Pin 13 - ??
                            Pin 14 - DIM
                            -David VanHorn
                              The picture that I marked, there are pin names to the right of the connector.
                              • danman
                                • Jun 2015
                                • 26
                                Sorry about that. I'm a newb. Here's a pic with the names.
                                The colours of the wires from left to right are
                                Black
                                Brown
                                Red
                                Orange
                                Yellow
                                Green
                                Blue
                                Purple
                                Grey
                                White
                                Black
                                Brown
                                Red
                                Orange
                                Not sure if that helps about the colours.
                                • danman
                                  • Jun 2015
                                  • 26
                                  Again the readings don't change when I hit power. The main board isn't turning on the ps.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4953
                                    • New Zealand
                                    The colours don't really matter, I only mentioned it because *usually* the wires which carry the same power rail are the same colour, but they are obviously just cost-cutting here...
                                    So there is no PSON signal at Pin 11? (The white wire)
                                    -David VanHorn
                                    • danman
                                      • Jun 2015
                                      • 26
                                      Pin 11 is the small black wire, but I checked the white one(pin 10) anyway and pin 11 and when i hit the power button the voltmeter doesn't read anything on either of them. I'm about 90% sure it's a problem with the main board.
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4953
                                        • New Zealand
                                        Sorry! I meant to write "The thin black wire next to the white wire"
                                        Anyway, if you got no voltage at Pin 11 \ PSON signal then that is a problem. It should be at least a couple of volts to tell the PSU to come up out of standby and into full power mode.
                                        Sounds like the mainboard may not be sending the PSON signal.
                                        -David VanHorn
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • caspian
                                          Conversion of Anolog Voltmeter into Ammeter
                                          by caspian
                                          Dear Members,
                                          I have an old analog voltmeter that can correctly measure DC voltage between 0v to 3v. The voltmeter is made by Toyokeiki depicted in the photos. It does not need any battery. It works using a coil and a magnet as any other analog voltmeters.
                                          I am going to convert this voltmeter into a DC ammeter that can measure DC current between 0A to 15A.
                                          To do this, I use a 0.2 Ohm resistor for current sensing in the circuit. Then, I use the setup depicted in the photo to measure current.
                                          For example, if the power be 12v and the load be 8 ohms, the voltmeter shows...
                                          06-25-2022, 07:13 AM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • disorder
                                          HP 2311 display, 3.3v regulator fried, need help to replace
                                          by disorder
                                          hello,
                                          i have a hp display 2311 to repair, totaly dead
                                          on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
                                          i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
                                          thank you
                                          07-27-2025, 04:34 AM
