Hi, as above and why I don't know. So turning the TV fully off and then back on again brings the back light back up but only for a second or two before turning off again, my guess is something gets to a certain temperature and stops working, maybe a dry joint??. This may be relevant, it's how the back light turns off, it's not a sudden off, it's more of a dimming over a second or two before turning fully off, it might give a clue as to what's going on I don't know so if you have any ideas on what might cause this I'm all ears, thanks, Andy.
LG LED back light turns off after about 10 minutes?
Re: LG LED back light turns off after about 10 minutes?
So I've now removed the back and had the Tv on for about one hour and as yet it hasn't tripped, usually it would be after about 10 minutes so I've turned the back light up to maximum and it's been like this for about three quarters of the hour, still no change, I'll leave it on and see what happens next....Comment
Just turned it off now, it didn't trip again but I have noticed two components getting very hot so there's a strong possibility of it being an over heating issue, I'll put a photo up later of what they are, one looks very similar to this:
http://www.ebay.co.uk/itm/1-x-TS6P03...item2597cb563e.Comment
Normally Bridge rectifiers short, causing the main fuse to blow. Cant go by picture. They have rating for surge and output current. Spacing between the pins is important also. Get the part number and get the same part or one with higher current capacity that will fit the holes and pin spacing.
What is the other part that is getting hot?Comment
by PNI E.hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
by RinxxHello guys. So, I bought this "dead battery" Macbook Air 2015 A1465 hoping to make it good enough for personal use.
When I got home, it turned on right away but indeed, battery was stuck at 1%. But after around 5 minutes it died and wont turn on again, no lights on charger.
Opened the laptop, lots of ants inside, cleaned it up with isopropyl alcohol. Found that PPDCIN_G3H_INRUSH capacitor was shorted, so replaced it and re-assemble it.
Laptop turns on fine for about 15 mins, did a reset and while reinstalling Macos, the laptop became intermittent, charger... -
by usbdeviceHi all
There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
https://www.badcaps.net/forum/showthread.php?t=50657
https://www.badcaps.net/forum/showthread.php?t=40512
The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
It's my dad's old monitor. He...-
by Titus6Hello everyone,
I bought an OLED65C1 refurbished TV back in 2022 from a shop. The TV is awesome, this is my first OLED and I really love it.
However I have an issue with the TV since the end of last year. I noticed when my TV is in Stand-By, sometimes the LED goes off then comes back on. When do so it seem periodical. It only goes away for 1-2 seconds, than comes back on. The TV NEVER turnes off, while it's on, so it's not overheating issue or electrical power issue.
I bought a service remote (MKJ39170828) and checked the menu 3. Power On/Off Status. I took...1 Photo -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... - Loading...
