SANSUI HDLCD3210 negative washed out picture
  • MisterD
    • Oct 2012
    • 668
    This was given to me, a 32" Sansui LCD TV Model HDLCD3210, it has a negative looking washed out picture, the AS15-G IC on the T-Con board gets very hot as soon as I power on the TV. I'm betting this IC is the problem.
    I haven't taken any voltage measurements yet. please chime in with comments.
    I have attached some pictures. Thanks.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: SANSUI HDLCD3210 negative washed out picture
    Yes possibly correct the AS15 IC is defective.....Replace the T-CON Board....If I may suggest, ShopJimmy is the best place to purchase these boards...
      Yep, another failed AS15 GAMMA REF Voltage IC.
      • MisterD
        • Oct 2012
        • 668
        Thanks Bud, where's a good place to purchase a replacement AS15 ?
        • newtothis
          • Mar 2013
          • 1556
          • england
          eBay
          Need to have decent soldering skills to replace the IC... Multi fine pitch
          • saddle_au
            Waste Warrior
            • 121
            If you are going to try to swap the chip off, be careful about removing pads when you are removing the chip, they're very small. Use something like QuikChip to get it off, or blob solder all of the legs together on each side and stanley blade cut the chip off them, then remove the legs with a soldering iron. Sometimes they have soldered the thermal pad under the chip to the board (rare) and you have to either use a heat gun or get physical using the above blob method.
            After you have soldered it on, be careful about shorts, you can destroy the tab bond chips in the panel if you have shorts (been there, done that). I have not seen any TCON that uses an AS15 where any two adjacent legs are shorted together on the board. Not to say they haven't, but I've not seen it on LG, Samsung, Philips, Benq or Sony. The closest shorts have been two legs apart and usually power supply pins. Use plenty of flux and if you don't/cannot solder the thermal pad underneath, at least use some silica paste to thermally ground it to the board.
            Good luck.
            • mecha1166
              Un70nu6900 taped lvds, how to fix washed out 1/2 picture?
              by mecha1166
              I am getting these 70 inch Samsungs daily. Dead set light comes on goes off, dark screen. Tried taping the problem lvds cable pins 13 to ? pin, used about 9 mm scotch tape. Picture comes on, no distortion lines, looks good, but 1/2 of screen is washed out. Problem seems to always be the last little strip on the bottom. Has anyone found what is actually the problem? Possibly one of three diodes there? I have a pic but it is washed out on 1/2. Anyony had success in fully restoring the picture? Thanks.
              07-03-2024, 05:03 PM
            • Tr0ll
              by Tr0ll
              Original T-con:
              First replacement T-con:
              10-07-2023, 07:48 PM
            • JJAAMM
              by JJAAMM
              Problem
              07-06-2023, 06:01 AM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • MikeRWK
              Sharp LC-32D40U Negative picture unless the contrast is almost 0
              by MikeRWK
              This only affects the picture but not the tv menus. Selecting any of the default picture settings gives a negative picture but turning the contrast down to 5 'fixes' it but then the tv is too dim which is hard to tell in the pictures.
              This tv has a main board, scaler board, and a tcon.
              I tore it down so I could probe the tcon which is nicely labelled. I've also included a pic of it.Here are the voltages I got:
              VGH 32V
              VGL -6V
              GAM1 14.6V
              GAM18 185mV
              VLS 14.67V
              3V 3.01V
              RESET 2.95V
              TCLK 0V
              SCC_VDD...
              01-30-2021, 05:21 PM
