Samsung ue32f5000 sound but no picture
  • Homer79
    • 13
    • england
    I've opened it up and I can see the backlight is coming on, but there us no picture.
    I've checked the caps, they are sam young, but none are bulging.
    seems to be a common problem, but I can't seem to narrow it down. Has anyone
    got any pointers as what's wrong with it?
    Regards
  • sordids999
    • May 2013
    • 2151
    Re: Samsung ue32f5000 sound but no picture
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • Homer79
      • 13
      • england
      As you can see the backlight is present when it's turned on.
        Check voltage at T-con fuse.
        Try with just one ribbon attached to T-con at a time (bottom of the T-con board, the orange ribbons.) See if just left or just right attached change the fault.
        • Homer79
          • 13
          • england
          Ive checked it with either tab disconnected, it doesnt make change the fault. I cant find any information on the smd marked up rr.
          • compcycle
            • Aug 2013
            • 32
            did anyone nail this down? I have the same problem, voltage on Tconn fuse is 12.8 both sides. Suspect Tcon board but not sure. Backlights are on ok
            • flocko
              • Nov 2012
              • 1121
              This is a known T.con fault Sharp RUNTK5351TP are failing all over. I have done 3 myself ,fitted to a lot of models and screen sizes, hard to find and premium price Flocko
              • ralphup
                • Aug 2011
                • 38
                Hi Homer79, do you still have the backlights for this TV?
                I have Picture (flahlight test) but no backlight... just thought we could do a deal and at least one of us get a working unit!
                Cheers
                R
                • MICROTECHSERVICE
                  • Jun 2016
                  • 36
                  • United Kingdom
                  hi i do repair service for this t.con done over 400 units in 8 month replacing the qfn chip and modifying the feed resistor official samsung mod.
                  • gbaicu51
                    • Feb 2015
                    • 29
                    [QUOTE=Homer79;560431]Hi,
                    got any pointers as what's wr?
                    hi. same problem here. any option please?
                    • vcolaon
                      • Sep 2014
                      • 10
                      • Croatia
                      What resistor do you change?
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • Mgiffune
                        by Mgiffune
                        06-09-2024, 10:28 AM
                      • Ierwin
                        by Ierwin
                        05-13-2025, 03:31 PM
                      • jchang
                        Samsung UN70NU6900F no picture and no sound
                        by jchang
                        Hi all
                        I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                        Symptom:
                        No picture no sound.
                        When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                        No sound at all.
                        What I tried:
                        1. I tried unplugging the left or right ribbon...
                        01-09-2023, 06:28 PM
                      • Dodgethis
                        Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                        by Dodgethis
                        Hello all,
                        This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                        09-11-2024, 07:39 AM
