I have this TV which I picked up, shut off immediately. Found someone had got in there and broke a lamp, so replaced the lamp. Now the TV comes on and stays on, but the panel looks like it has white lines. The lines shift around as I press the menu/input buttons, but no visible intelligence on the screen. Is this a bad panel? The Tcon looks visibly in good condition and I measured the voltages as asymptotically rising /falling from Vgamma1->Vgamma18.
Samsung LN40B500P3 White lines
Re: Samsung LN40B500P3 White lines
I would agree, the panel is bad. Sorry.
If they broke a lamp maybe they tore a tab bond or chipped the glass.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I was ready to junk the tv, but noticed there was one red vertical line to the extreme right of the screen. Pressing the tab bond just at that location in a certain way caused the image to come on. I fixed it by seating a small piece of nylon pipe. It must have broken loose during the lamp change. Anyway mystery solved and tv saved.
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by FalkiHello there, ive recently found an older 55inch Samsung SmartTV.
A similar issue has been posted as well but also with no actual response ...6 Photos -
by thstuffThis "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
2) Waited 30 seconds, then pressed remote Power button and "Select language"...01-30-2023, 05:01 PM -
by RubenlilyHello,
First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
I'm no expert but I've done the tape... -
by jeyoung12Hi all
I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
So....i don't know what end of the C ribbon to work with... - Loading...
