Samsung LN40B500P3 White lines
  • keats11
    • Nov 2012
    • 88
    I have this TV which I picked up, shut off immediately. Found someone had got in there and broke a lamp, so replaced the lamp. Now the TV comes on and stays on, but the panel looks like it has white lines. The lines shift around as I press the menu/input buttons, but no visible intelligence on the screen. Is this a bad panel? The Tcon looks visibly in good condition and I measured the voltages as asymptotically rising /falling from Vgamma1->Vgamma18.
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung LN40B500P3 White lines
    If you unplug half the tcon do you get an image and vice versa.
    It's probably a bad panel, but you could check the AVDD, VONE, VGL, VOFFE voltages.
      I would agree, the panel is bad. Sorry.
      If they broke a lamp maybe they tore a tab bond or chipped the glass.
      • tom thumb
        • Jul 2013
        • 66
        I agree too Bad Panel
        • keats11
          • Nov 2012
          • 88
          I was ready to junk the tv, but noticed there was one red vertical line to the extreme right of the screen. Pressing the tab bond just at that location in a certain way caused the image to come on. I fixed it by seating a small piece of nylon pipe. It must have broken loose during the lamp change. Anyway mystery solved and tv saved.
            09-07-2024, 05:50 AM
          • Falki
            Colorful LCD Vertical Lines on Samsung ue55es8090
            by Falki
            Hello there, ive recently found an older 55inch Samsung SmartTV.
            A similar issue has been posted as well but also with no actual response ...
            08-12-2025, 04:19 AM
          • thstuff
            SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
            by thstuff
            This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
            Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
            1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
            2) Waited 30 seconds, then pressed remote Power button and "Select language"...
            01-30-2023, 05:01 PM
          • Rubenlily
            Samsung QE50Q67TAU - horizontal lines
            by Rubenlily
            First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
            I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
            I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
            I'm no expert but I've done the tape...
            08-16-2023, 01:12 PM
          • jeyoung12
            Samsung QN50Q60t lines on screen
            by jeyoung12
            Hi all
            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
            So....i don't know what end of the C ribbon to work with...
            02-26-2024, 10:38 AM
