32 inch samsung with new tcon now got split screen
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Hi, I was recently given a tv by a friend, the original fault was it wouldn't turn on and just flashed the red led on the front, I unplugged the tcon and the set fired up so i ordered a new tcon, When it arrived it had a different connector than the the original board so i used another cable i had lyin about to connect the tcon to the main board, Now the set works but has a slight offset split down the middle and another line down the right hand side, Its going to be used as a security monitor so it might be ok as it is but just asking here first incase its an easy fix via the service menu, Heres a video of the fault.
    http://tinypic.com/r/308zgc3/8
  • vinceroger69
    • Mar 2012
    • 6714
    Re: 32 inch samsung with new tcon now got split screen
    maybe the new cable you used had a different pin out so wiring is now wrong? can you get the correct tcon to use the origianal wire/lead.
      I have neck pain after trying to watch that sideways video played horizontally... It is very hard to see what you mean... that pixel line is probably a panel fault, but luckily its on the edge so fairly minor, I can't see anything else?
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
      • Chrissygizmo
        samsung galaxy ao2s very temperamental after screen replaced
        by Chrissygizmo
        Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
        Ive eventually managed to get it on and working but it's very temperamental...
        The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
        05-26-2024, 12:05 AM
      • JunkmanJimbo
        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
        by JunkmanJimbo
        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
        No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
        Please help. Thanks in advance!
        08-12-2025, 11:45 AM
      • Kiberge
        Samsung LH82QENELGC/EN Help needed - Static line on screen
        by Kiberge
        HI guys!
        I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
        I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
        the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
        This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
        04-22-2024, 11:28 AM
