Insignia 39" led tv, NS-39D240A13 - no video
Re: Insignia 39" led tv, NS-39D240A13 - no video
You need to find out if there is 12VDC feeding the integrated T-CON board or not, the LVDS cable on the main board to goes to the T-CON should have 12Vdc on at least one of the pin.
There is also SMD fuse on the T-CON board and a bunch of switching power supplies on the T-CON board.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
I got this TV ( Insignia NS-39D240A13 ) and it works but the screen flashes through these colors. Like a color test pattern. Pushing exit on the remote fixes it sometimes for 5 seconds and sometimes for 10 minutes, so annoying. I am guessing the EEPROM is bad but I can not find any where to buy one.
Cycling Colors
Does anyone have any idea how to fix this? I have even thought of replacing the board from another TV that will fit. If I replace it with an original used part it will only do it again. I have read online about this TV and it seems everyone has the same problem and there seems to be no way to fix it.
I am hoping someone knows how to hack this or bypass this problem.
Please help me save this TV, Thank you.Last edited by Shane711; 05-05-2015, 09:49 AM.Comment
Update: I have purchased an EEPROM for a 32L121A13 hoping that it will work because it is of the same board but it did not work. I can turn the TV on and off but nothing displays on the screen, it just lights up. So my next step is to buy a main board for the 32L121A13 and change the panel connector. If this does not work then the TV seems to be unfixable. Or if there is someone out there that can read and reprogram an EEPROM that may work as well. The color test would have to be disabled.Comment
Hi Budm
I finally got a chance to check the cable coming out of the main board to the integrated tcon and there is 12v coming from the main board. If the main board seems to be working, how do I go about checking the fuses and power switches on the tcon board?
Another weird thing is that, as soon as I plug the a/c cord to the outlet, the tv panel will turn on by itself (I don't need to press power at all). However, once it is on, I can turn the tv off and on with the power button. Could this be a symptom of the problem?Comment
You will have to remove the metal frame of the LCD panel to get to the circuit board so yo can locate the fuse.Never stop learning
It has been awhile but I am finally trying to tackle this tv again. I checked the ps board and pins 10 and 11 have a voltage of 13.5v coming out of them (it is supposed to be 12v)....is that too high or within specs? The rest of the pins have good reading.
I am trying to first figure out if the turning on by itself issue (when first plugged into the electrical outlet) is the root of the problem. What would cause the tv to turn on by itself when plugged in?Last edited by jackal68; 11-30-2015, 12:33 PM.Comment
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by Aimbitvideo: https://www.youtube.com/watch?v=S-xBu7m6SwE
Hi all. I was given this JBL Flip Essential speaker that 'fell from about 8 feet' and then the bluetooth would no longer function. It seems to power on normally and responds to button presses, but it will not showup on bluetooth for any device I try to connect to it.
The bluetooth daughter board has a 26mhz oscillator that I could not get to read the proper frequency so I tried replacing that to no avail. Thought maybe something was wrong with the bluetooth IC it's connected to, so I tried replacing that as well. None...10-28-2024, 09:29 PM - Loading...
