Sony KDL-40BX400
  • wwanderer
    • Jan 2012
    • 8
    Sony KDL-40BX400
    Hi to all
    I am going to replace the TCON board .Does anyone had the same problem?
    Sound: ok
    Inverter backlights:ok
    Picture: small flashing screen raster colored pattern rolling horizontally on the
    upper part of the screen
    (See the attached picture)
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Sony KDL-40BX400
    If you search for this on badcaps it will tell you all you should need for this problem
    LCD TV and Monitor basic troubleshooting guides
    by BudM
    • wwanderer
      • Jan 2012
      • 8
      I read the pdf files you mentioned.
      I tried to test he TCON board, with the removal trick of the flat cable board between Main board and TCON board.
      Now, the standby led flashes 5x times and the TV stops.
      No sound
      No picture
      No light from inverter.
      Panel problem?
      I removed the TCON board but the TV produces the same 5x led standby protection mode.
      Any advice?
      Thank you.
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        I'm not an expert like some of these guys are, but to me it looked like a panel problem. Of course the correct way to go about a problem is don't assume anything. If you step through that basic guide. First with the voltage etc. and then with the other procedures. The problem with the panels is that they have gate drivers that run down the side of the panel. These are built-in to the panel. If one of them screws up than it will screw up the rest of the picture and there is nothing that can be done. Perhaps one of these other guys who work on this stuff everyday will help you.
        • newtothis
          • Mar 2013
          • 1556
          • england
          Looks like a panel failure to me I'm afraid
          • wwanderer
            • Jan 2012
            • 8
            Thank you all for your answers.
            Now the questions are:
            1.Is it possible to test or the panel in order to be certain that this is the problem?
            (When I made the removal trcick of the LVDS cable some pins were damaged and maybe for this reason the mainboard failed too.Wishful thinking..)
            2.If I change the mainboard, the TCON and the damaged LVDS flatcable between the TCON and the mainboard and the panel has problem will these two boards be ruined?
            I can't measure any voltages in these two boards because the TV shuts down in 3 seconds and then there is the 5 blinking code.
            Any more suggestions?
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              I am sure there must be a way to disconnect the cables to the power supply board to find out if the power supply is good. The power supply I believe has to be forced on by jumpering some connector to PSON. Even thou the picture shuts down you may also be able to read some voltage on the regulators. Also, do you have a cable going from the TCon board to the panel? What the TV guys are going to want from you is close up pictures of your boards and how they are laid out. Perhaps if you did that you would get more responses. I just do not repair these on a regular basis and I do not keep all that stuff in my head. If you are going to be repairing these on a regular basis than it would benefit you to post the pictures and be guided by some of these guys that are experts at doing this. Even if it is the panel the value you will gain from stepping through the procedures would be of great be benefit. I would say only if your going to use this knowledge more than three times.
                I would at least check to see if the SMD fuse on the T-CON board is still good.
                • wwanderer
                  • Jan 2012
                  • 8
                  The smd fuse on the TCON is ok.
                  I have disconnected the TCON cable from the main board.The TV shuts down with the 5 led blinking code.
                  Can I force on the power supply unit?
                  Can I make any oher test in order to be certain that this is a panel problem?
                  Thank you
                    Are you getting 12VDC at both end of the fuse with ref to the chassis?
                    There are Voltage regulator ICs and 3 switching power supplies on that T-CON board, also test points for Voltages that should be tested.
                    • wwanderer
                      • Jan 2012
                      • 8
                      Thank you budm for your answer.
                      Finally I am back to my first post.(The LF7 in position PS6401 on Power Supply Unit was open circuited).
                      Now:
                      TV turns on.
                      Sound ok.
                      Picture: see the attachment in my first post
                      I am getting 12.7 VDC at both end of the fuse on the TCON ,with ref to the chassis.
                      1.What test points for Voltages should I test on the TCON board?Any schematic?
                      2.In general, this model of Sony (Bravia) has problematic lcd panels?
                      So as I understand we can't check the panel.For this reason, we check the other parts.
                      3.If they are ok then it is a panel issue and we can't do anything?
                        Try disconnecting the ribbon cables between the T-CON and the LCD panel to see if the 5-blink error code goes away if you have not done that yet.
                        • wwanderer
                          • Jan 2012
                          • 8
                          I disconnected the ribbon cables between the T-CON and the LCD panel.
                          There is no 5-blink error code.
                          Sound:ok
                          Inverter board:ok
                          TCON or lcd panel problem?
                          Any schematic for TCON board with test points?
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • gersrt
                            Ordered Wrong TCON Board For Sony TV, Can I flash Epprom
                            by gersrt
                            HI
                            Made a mistake and ordered the wrong TCON board to replace in my KDL-46HX823, the board I ordered was Sony PLY 1-883-893-11 which is sort of correct.
                            But later realized this board is used in 4 or 5 models, any way the one i got sent was for KDL-55HX820.
                            Physically these boards are identical, everything on the board is the same. I havent put this board into the TV yet, but am I right in saying all i would have to do is copy the Epprom from my faulty board and transfere it on to the new board, or is there still something else that may stop this working....
                            01-27-2021, 05:49 PM
                          • TerraPhantm
                            Sony A8H to A80J mainboard upgrade possible?
                            by TerraPhantm
                            I have a Sony 65A8H. Always bothered me that it doesn't have HDMI 2.1. I noticed the A80J board appears quite similar. And comparing some wiring diagrams in the service manuals (albeit A9G vs A90J since I couldn't find the A8/80 manuals), things appeared quite similar. And my understanding is the panels between the two TVs are more or less the same.
                            So I decided I'd experiment a little bit.
                            I bought an A80J board. Left the speaker connection unplugged because it doesn't fit. Changed the power connector to fit the new board. Plugged in everything else.
                            When...
                            08-15-2023, 08:10 AM
                          • huj3r
                            Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
                            by huj3r
                            Hi there!
                            I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
                            Photo of the situation after the black shadow dissipates:
                            After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
                            I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
                            > This indicates HFR Communication error. [ HFR Communication...
                            08-15-2023, 10:55 AM
