BUSH LC39GL12L - Stuck on standby light
  • speedypro
    • Feb 2013
    • 561
    Can anyone point me in the right direction? This tv is stuck in standby mode as in a solid red light. No physical damaged seen on the power board. Whatnirmally causes a red standby light?
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: BUSH LC39GL12L - Stuck on standby light
    umm... no pics, nothing to look at. I'd measure if the main board sends PSon to the PSU.
    • sordids999
      • May 2013
      • 2161
      • uk
      Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
      • newtothis
        • Mar 2013
        • 1556
        • england
        Darlaston?
        You live in same town as me! Small World.
        • speedypro
          • Feb 2013
          • 561
          Sorry. No good camera to take pictures but as i have said, no visual damage etc. I do get voltage to main board. But it wont turn on, just stays on red light. W have tried another board bought on ebay and same issue but not sure if board is 100% working. We assume main board.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            what are the board numbers on each boards.
            • speedypro
              • Feb 2013
              • 561
              Power Board: mip390hw rev. 1.0
              Main: t.msd306.68a 12023
              • newtothis
                • Mar 2013
                • 1556
                • england
                speedypro,
                PM me as I can help you directly
                • speedypro
                  • Feb 2013
                  • 561
                  Im getting all output dc voltages when I short the PSon pins. But when I attached the main board, no dc voltages. Again I have ordered a used main board off ebay and I no idea if that works or not. But why when the main board is connected to the power board I get no dc voltage? Or should I say I get dc output but just for few seconds.
                  Is it normal for the Bridge Rectifier to make a buzzing noise?
                  • steviewonder
                    • Dec 2013
                    • 183
                    • england
                    a common issue on the t.msd306 pcb's for this is corruption of the flash ic (the 8 pin one)
                    7 out of 10 ten times that's your issue.
                    The buzzing noise is quite normal,provided you can only just hear it.
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      Main Bd 3.3V Regulator probably has a short causing the Pwr Bd voltages to drop off. I think your used board off e-bay will work. I have acquired many 'used' Bds from e-bay and ALL have worked so far...Good luck
                      • melonslug
                        • Aug 2016
                        • 19
                        Hello, I am new to Badcaps and I have to say there are some great helpful chaps on here. I was hoping I can continue this thread a bit further and ask for some help. I also have the BUSH LC39GL12L and have the same problem, stuck on standby (blue light wont come on, only red). Just like Speedypro I have all the right voltages at the output of the power supply board mip390hw and am happy that is fine. So I presume the problem is in the main board t.msd306.68a . Now I see newtothis has ask the guy to pm him, could you help me too please newtothis? Also I see steviewonder has stated a problem with the flash ic, could you tell me where this is on the board please?Also AndrewF.Ali mentions the 3.3 regulater shorting, could you point out where this is too please. Many thanks in advance to any replies.
                        • ChristianBr01
                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                          by ChristianBr01
                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                          04-23-2025, 01:48 AM
                        • Ady2017
                          LG 42LD490 stuck in standby with flashing red light
                          by Ady2017
                          The problem with my TV is very similar to an earlier post but there was no final solution posted.
                          When the TV is first turned on from cold it will not turn on. The red standby light begins pulsing and a high pitch whine is heard. The back light remains off. If the TV is left trying to boot like this and then turned off and on again a few times then eventually it will turn on and sit there working all day long.
                          I initially suspected the PSU after spotting this kit for sale,
                          http://www.ohmsupplies.co.uk/epages/...ops/62027733/P...
                          11-16-2021, 11:10 AM
                        • brithepi2k
                          Sony KD-65XE8596 no standby light
                          by brithepi2k
                          I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                          cheers...
                          09-06-2025, 02:22 PM
                        • Kaar3l
                          Samsung QLED QE65Q7FNAT only standby light
                          by Kaar3l
                          TV: Samsung QLED QE65Q7FNAT
                          PSU: BN4400940A
                          MB: BN94-12832K
                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                          09-24-2024, 01:35 PM
                        • jasonbay13
                          Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                          by jasonbay13
                          picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                          am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                          12-01-2023, 09:55 PM
