Toshiba 40D1333B no back light.
    Re: Toshiba 40D1333B no back light.
    Pictures are TOO BLURR for me to trace out the circuit of the LED driver section.
    Need straight clear shot pictures of the whole bottom side of this power supply/LED driver board.
    • riget
      • Sep 2011
      • 66
      Hope these are better?
      • riget
        • Sep 2011
        • 66
        Found this,
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          #44
          So you are 101% sure its not the leds ? Have you checked the diode for the 24V rail and the mosfet that switches the voltage for the leds ?
          • riget
            • Sep 2011
            • 66
            It's not the leds, I've got 24v going to the main board, don't know what diode/mosfet you mean.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #46
              Right so you have 24v going to the mainboard so guess that the 24v is working. What about going to the leds ?
                OK, so do you have the 24-80VDC at the two legs of the C316?
                Did you verify that you do have BL-ON signal?
                • riget
                  • Sep 2011
                  • 66
                  In standby I have 0v at the led connector, 1.4v at c505 and 1.7v at c316
                  when turned on I get 2v at led, 2v at c505 and 2.3v at c316
                  Thanks.
                  • speedypro
                    • Feb 2013
                    • 561
                    • United Kingdom
                    #49
                    Hi all. I have the same board as riget and I get 2v going to the panel. I have pulled the panel a part and saw only strips. No led driver so I assume it's on the psu? Where?
                    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
                    • speedypro
                      • Feb 2013
                      • 561
                      • United Kingdom
                      #50
                      I have 2v at mine.
                      • riget
                        • Sep 2011
                        • 66
                        Hi, I managed to fix mine, it was a cap that took a transistor out, I can look up the numbers if you want to give it a go.
                        • speedypro
                          • Feb 2013
                          • 561
                          • United Kingdom
                          #52
                          Yes please! My hands are already dirty. Or a picture of what you have replaced is perfect. Either.
                          • riget
                            • Sep 2011
                            • 66
                            Ok sorry it's late, the transistor is the one on the first pic of the top, top right hand side next to the heatsink, the smd cap is underneath near to it c525.
                            Thanks.
                            • speedypro
                              • Feb 2013
                              • 561
                              • United Kingdom
                              #54
                              Thanks.
                              is the transistor q216 or the mosfet q301? im lost, sorry.
                              • riget
                                • Sep 2011
                                • 66
                                yes q216
                                • cossiejay
                                  • Nov 2010
                                  • 83
                                  #56
                                  do you have the part numbers please I have same fault only 0 volts going to leds
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    #57
                                    Look at the mosfets lol they have the PN on them.
                                    • michael dranfield
                                      • Jan 2016
                                      • 232
                                      • England
                                      #58
                                      You see inside the panel there are two strips connected together in the middle by a plug and socket, look at the ones that have gone brown , there are dry Jointed, link each one together with a bit of wire.
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        #59
                                        Michael he has no volts going to the Leds meaning that the driver is dead. If he has 24v going to them (not boosted) the Leds would be bad.
                                        • michael dranfield
                                          • Jan 2016
                                          • 232
                                          • England
                                          #60
                                          The driver is in the screen itself, there is a fuse on this board .
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            09-06-2024, 05:27 AM
                                            09-06-2024, 05:59 AM
