Finlux 50F8090S-T STANDBY FLASHING WONT TURN ON
    Re: Finlux 50F8090S-T STANDBY FLASHING WONT TURN ON
    Right... so this set uses an external inverter (or LED driver in this case.) The PSU appears to be working as it has 12V/24V.
    Unless the main board is connected to the LED driver somehow, there is no way for the main board to detect a fault with it. It could be that the LED driver is faulty, or that it requires a special DIM waveform that you cannot generate with just resistors...
    Either way, it means it's still the main board that is the root of the fault, IMHO.
    • sordids999
      • May 2013
      • 2160
      • uk
      #42
      ok thanks m8 for your help
      • PNI E.
        Samsung ue55tu7170u not turn on and no standby led main bn9650990e
        by PNI E.
        Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
        03-17-2025, 04:23 AM
      • madsox
        Harman Kardon AVR 171S - standby led lights up, does not turn on
        by madsox
        Greetings!
        Thank you in advance for your understanding, I am writing to you through a translator.
        A Harman Kardon AVR171S amplifier was given.
        The history of the machine is as follows:
        It was faulty when I bought it, I want to fix it.
        I replaced the HDMI switch and one of the DAC ICs in it.
        After that it worked without a problem.
        I watched a movie using the amplifier, and at the end the amplifier got really hot.
        The cooling was faulty, I will fix this later.
        I switched it to standby mode, waited for...
        09-24-2022, 10:46 AM
      • catnapped
        Dead Vizio D40u-D1
        by catnapped
        Recently had my bedroom Vizio D40u-D1 apparently die while it wasn't being used. Noticed the power LED flashing, figuring maybe a software upgrade, but attempting to turn it on proved that wasn't the case. When powered on, the power LED will flash a bunch of times after about 2 minutes then turn off again. Definitely is no picture even with a flashlight on the screen. Had the opportunity to open it up over the weekend. Doesn't apper to be anything out of the ordinary visibly inside, nor any odd smells of escaped magic smoke. Readings from the connector in the corner of the power supply board...
        04-02-2024, 08:55 AM
      • Willem01
        TV not powering on - with standby red –led flashing
        by Willem01
        Error – TV not powering on - with standby red –led flashing
        Model- LEDTV – 39T3500
        Power boarD - shg3206a-101h
        I have read through the Basic LCD TV and Monitor troubleshooting guides.
        https://www.badcaps.net/forum/showthr...956#post305956, I am no ELEC engineer but can use a multi meter and soldering iron
        In the meantime I could not see any damage to any caps on the cold side of the power board, so I have replaced all of them.
        Unplugged the power connector on the board, I plugged the power cable in waited...
        02-27-2021, 08:23 AM
      • Scoff
        LG55UB850V no picture or audio - flashing LED's help please?
        by Scoff
        Hi, I'm looking for some help with attempting to troubleshoot and hopefully repair my trusty LG55" TV.
        I'm reasonably comfortable working with electronics, but far from expert level! I have more experience with auto-electrics than anything.
        We recently had a power cut while the TV was on, and since then, when the TV is switched on at the wall, the red standby light comes on like normal. Then. when you press the power button on the remote or the TV to switch it on from standby, the standby light flashes 3 times and then goes out. There is no audio or video at...
        01-26-2022, 06:13 AM
