sharp lc46sb54u Troubleshoot.
  • kkswim2616
    • Oct 2013
    • 13
    Hello!
    I recently acquired this sharp lc46sb54u for little to nothing so I figured I would take it in and attempt to fix it. I am attempting to trouble shoot it and find myself lost. I replaced the power board as I originally thought it was that. I am left with the same issue as first started.
    Upon pressing power there is an audible click, no picture or audio. The power and opc light blink twice together, then the opc blinks once by itself. I can force the tv on by using channel down volume up and power but i am left with no picture or audio again, just a steady green light. I have taken some voltages from the power board with the tv forced on and all the voltages seem to be cut in half of what they are supposed to be. PSON is 0, but when power is pressed it jumps to 1.5 and goes back to 0.
    I will include in the post the service manual and if any pictures are needed i will upload them ASAP.
    If someone could give me some direction in what voltages to test it would be greatly appreciated.
    Thanks!
    Ken
    EDIT: Tried to upload service manual but kept freezing. Here is link
  • kkswim2616
    • Oct 2013
    • 13
    Re: sharp lc46sb54u Troubleshoot.
    https://drive.google.com/file/d/0B1L...ew?usp=sharing
    Heres pictures of the boards. sorry the attachment things would still not work.
    • newtothis
      • Mar 2013
      • 1556
      • england
      Could do with clearer pics please, Need to be able to see and read what is on the boards
      • kkswim2616
        • Oct 2013
        • 13
        it'll be nearly impossible to the get whole board with legible writing. so ill start with the power board and upload those pics.
        • newtothis
          • Mar 2013
          • 1556
          • england
          Yes each of the boards is preferable
          • kkswim2616
            • Oct 2013
            • 13
            Power Board
            Main Board
            • kkswim2616
              • Oct 2013
              • 13
              with the tv forced on.
              Power Board to Main Board Voltages
              PSON- 1.3v
              acDET-1.5v
              PNL- 0v
              bus5v- 3.0V
              UR15v- 9.8v
              UR15v- 8.9V
              • kkswim2616
                • Oct 2013
                • 13
                the small cylinder fuse on the small power board is only reading 195 V it should be 240V. would that have anything to do with it?
                  "PNL- 0v
                  bus5v- 3.0V
                  UR15v- 9.8v
                  UR15v- 8.9V"
                  The 5V is not right, same for the PNL power, UR15V.
                  "the small cylinder fuse on the small power board is only reading 195 V it should be 240V. would that have anything to do with it?" You use the chassis for your meter black lead, right? The incoming AC should be 120VAC between HOT (BLACK) and Neutral (WHITE). That small board is just an AC line filter board.
                  Are you sure your meter battery is good or it is to the correct mode since ALL you readings are way off. There is no way you can get 195V at the main AC fuse when the incoming is only 120VAC.
                  • kkswim2616
                    • Oct 2013
                    • 13
                    The only way i was able to get any reading besides zero was setting it to DC, 200m Volts for the power board to main board plug.
                    for the ac supply I had it set to AC 200m Volts as well as thats the only setting I could get actual numbers. Maybe the batteries in it are bad. ill pick up some new ones and try again.
                    • kkswim2616
                      • Oct 2013
                      • 13
                      SO my multimeter was definitely shot. readings are quite different on a different multimeter.
                      PSON- 3v
                      ac_det- 3 v
                      pnl_pwr- 0v
                      sgnd- 0v
                      bus5v- 4.9v
                      sgnd- 0v
                      sgnd-0v
                      ur15v- 15v
                      ur15v- 15v
                        So you do have problem with pnl_pwr problem. Need to find out why next.
                        • kkswim2616
                          • Oct 2013
                          • 13
                          How would I go about finding out why i have nothing at pnl_pwr. There is a noise coming from the main board under the main cpu in the middle. is there anything I can jump to pnl_pwr.
                          Also the inverter board is receiving the necessary voltages from plug coming from the power supply, but the plug coming from the mainboard shows no voltages whatsoever.
                          • kkswim2616
                            • Oct 2013
                            • 13
                            bump
                              Per service manual page 49 5-4 block diagram, the power supply board gets the PNL_ON (>2.5VDC = ON) from CPU of the main board, then the power supply will put out 12VDC for the PNL-12V.
                              So if the command signal is there but no 12v PNL, then you need to do more troubleshoot of the power supply board, the service manual does not provide the diagram for the power supply because it is made by other OEM.
                              • kkswim2616
                                • Oct 2013
                                • 13
                                took a shot and replaced main board and it was successful. thanks!
                                  Great and thanks for the follow-up. Was the replacement board expensive.
                                  • kkswim2616
                                    • Oct 2013
                                    • 13
                                    80 dollars on ebay! luckily it worked. wasn't too bad. i only paid 50 for the tv.
                                    • rootboy
                                      • Oct 2017
                                      • 6
                                      Same thing for me, and it fixed it up as well.
                                      Thanks!!
                                      • Capacitorial
                                        Powersupply has all the voltages - Monitor still no power
                                        by Capacitorial
                                        Hello guys,
                                        I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                        I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                        On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                        The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                        The weird thing is, that the Power LED is powered over the TCON board.
                                        On The TCON...
                                        12-28-2024, 02:12 PM
                                      • organman
                                        Sharp LC-60LE633U Inverter output voltages
                                        by organman
                                        Greetings, I have a Sharp LC-60LE633U when powered up only the V light comes on. I have checked the LED strips and they all light up. When the LED's are plugged into the PS board I get an output voltage of 74v DC. If I unplug the LED's the output voltage on the PS is 184v DC. Does this indicate a weak PS?
                                        Thanks...
                                        03-22-2023, 06:47 PM
                                      • organman
                                        Sharp LV-60LE633U inverter output voltages
                                        by organman
                                        03-13-2023, 06:48 PM
                                      • Joekhoe
                                        Sharp Aquos Quattron LC-52LE835X Totally Dead, no output voltages
                                        by Joekhoe
                                        Hello all, I'm Joekhoe, a newbie here and ask your masters permissions and solutions for the problem i'm facing at the present.
                                        I am in the middle of working on a SHARP Smart TV model LC-52LE835X from my customer, which totally dead and there's no output voltages at all at the output pins even though i have replace some of the components the output voltages remain the same with 0 volt.
                                        The replacement as follows:
                                        1. IC7905 : TNY264PN (first found exploded)
                                        2. Q7915 : BT169D (exploded too)
                                        3. IC7901 : 1608B (controller ic)
                                        4. IC7601 :...
                                        09-17-2020, 05:52 AM
                                      • Superbee_dad
                                        Sharp 80” long short flash backlight error - Help
                                        by Superbee_dad
                                        Hello Sharp TV experts
                                        Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                        > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                        > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                        01-24-2025, 11:51 PM
