PHILIPS 40PFL7605/H12 image reversed 180 degrees
  • mexx25
    • Dec 2012
    • 5
    • bih
    Hello
    LED TV
    MANUFACTURER: Philips
    MODEL: 40PFL7605 / H12
    MODEL ADDITIONAL:
    CHASSIS: Q552.1e-LA
    Mainboard: 310432862933
    PANEL: SHARP LK400D3LA93 FSP
    T-CON BOARD: SHARP CPWBX RUNTK4323TP ZT
    SYMPTOMS: The image is upside down 180 degrees
    Fault description and takes actions:
    My tcon was dead and i brought one from store.
    The picture is very good , color size and all others is all good except that the image is turned 180 degrees.
    I tried the service menu to do with option code label and again .Panel display type on the sticker is 295 the same as in the service menu under the option display screen.firmware upgrade from Philps website and again the same.
    Otherwise the TCON module has eeprom but I do not have dump file him so I was not stabbed nothing to do with him.
    I do not know what to try on. If anyone has any idea
    Thanks in advance.
    Kostenloses Bilderhosting
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: PHILIPS 40PFL7605/H12 image reversed 180 degrees
    First off, Have you tried reseating the cables to the tcon? Give the contacts a clean too
    • mexx25
      • Dec 2012
      • 5
      • bih
      Hello
      Yes i have first clean and reseat the 2 tcon flat cables
      • paulstef
        • Dec 2013
        • 724
        I had this problem once but it was the data on the mainboard that was wrong.
        In any case you could try to swap the EEPROMs on the T-Con.
        Is this a TV from somebody else? Could it be that they swapped the mainboard too? (one with the wrong firmware)
        • mexx25
          • Dec 2012
          • 5
          • bih
          Hello
          I have the new firmware from philips.com with usb
          and this troble is again the self.
          Eeprom dupm i cant find it on the web.
          • mexx25
            • Dec 2012
            • 5
            • bih
            Re: PHILIPS 40PFL7605/H12 image reversed 180 degrees "solved"
            Solved
            I have buy a new tcon board and picture is now ok
            • rimwall
              Sony KD-65x7500D - double image - Tcon or Panel?
              by rimwall
              This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
              I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
              11-18-2025, 02:09 AM
            • alro7779
              Philips 32PFL4901/F8 BA5DFGG0201 1 Backlight is present but no image
              by alro7779
              Hello there!
              Have this Philips with no image at all. When I plug it to the outlet, it turns on without pressing the power button, and after a moment, it turns off, then starts again. I checked the 12v and 3.3v voltages on the main board connector that goes to the T-con, but it only has the former (12v). Any clues, guys?...
              08-07-2025, 11:53 AM
            • tuner2000i
              Philips 65PUS8518/12 distorted image after main board replacement
              by tuner2000i
              hello everyone,
              I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
              The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
              07-15-2025, 01:15 PM
            • malekservis
              Philips 58PUS8536/12 Backlight ok, no image
              by malekservis
              the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
              Any information would be appreciated....
              08-07-2024, 07:48 AM
            • jason123
              ASUS PG27V Rolling Image - TCON?
              by jason123
              Hi there,
              My son's gaming monitor started having rolling image (vertical roll - See Video) similar to vertical sync issue, or T-CON problems in TVs. Has anyone see this? is it fixable or a throw away?
              I haven't even opened it up yet. Does it have a T-CON? Help is appreciated.
              It does this even with the monitor not connected to a computer / graphics card....
              11-01-2025, 05:41 PM
