M421VT LED Screen Color Distortion
  • dfang
    • Feb 2013
    • 39
    Re: M421VT LED Screen Color Distortion
    Ok so I jumped 5v to on/off pin and 5v to PS_ON as well ..the results are still no 24v,,, of coarse no LED back lights...This is what I've got for voltages at PS now..
    ON-OFF=4.24vdc
    DIM=3.28vdc
    12v=2.52vdc
    12v=2.53vdc
    GND=0vdc
    GND=0vdc
    GND=0vdc
    24v=0vdc
    24v=0vdc
    PS_ON=4.24vdc
    5.2v=5.14vdc
    5.2v=5.14vdc
    ACD=0vdc
      What range are you using on your meter? Can you test using the 200V range instead? (If it's autoranging, ignore this.)
      • newtothis
        • Mar 2013
        • 1556
        • england
        #43
        I was thinking same as you Tom but the 5v is showing correctly so dismissed it
          Crazy thought, but what if, for example, the left most "1" digit on his meter did not work properly? This would rule this out...
          • newtothis
            • Mar 2013
            • 1556
            • england
            #45
            Hmmm,
            If you cant do as Tom asked and set too 200 range -
            can you confirm 0v on the 24v rails after forcing the backlights on?
            If that is that case tom we should see ~4v otherwise the PSU is indeed at fault
            • dfang
              • Feb 2013
              • 39
              I've got Fluke ET-23 a old one,,but,,it works fine...It's manual ranging..I tried all ranges ..Could the PS power on voltage need to be greater than 4.24 volts ? I looked on the net for a main board and couldn't find one ,,,every one is out of stock...Must be a run on these babies..
              • newtothis
                • Mar 2013
                • 1556
                • england
                #47
                So what exactly does it show on 200 range?
                • dfang
                  • Feb 2013
                  • 39
                  Ok,,first off I guess my Fluke is autoranging...I did a test with jumper resistors and realized that when the set is first plugged in the VIZIO logo will blink bright white 35 times then stop,,it is the back lights blinking...With meter on one of the 24v lines at the PS,,I see the voltage as high as 11.72vdc,,but it happens so fast the meter can't read the full correct voltage..After the 35 blinks and press TV power on backlight gives a very quick flash and that is it until you unplug/plug in and it starts the dance again..So the PS must be capable of lighting the backlights ,,,just will not stay on..
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    #49
                    Ok so that confirms the PSU is shutting down for some reason.
                    Not sure if the PSU will stay on without the backlight load but try disconnecting the backlights from the PSU and forcing it on again
                    • dfang
                      • Feb 2013
                      • 39
                      Humm...disconnected backlights from PSU and forcing it on I get nothing on 24V lines... I reconnected backlights and now not even varying voltage on 24v pins on PS connector when plugged in.. I'm doing harm to this tv..
                      • newtothis
                        • Mar 2013
                        • 1556
                        • england
                        #51
                        Varying voltage? You listed it as 0v every test
                        • truep
                          • Aug 2010
                          • 373
                          Maybe the ac detect is shutting it down??
                          • truep
                            • Aug 2010
                            • 373
                            That's the acd pin
                            • dfang
                              • Feb 2013
                              • 39
                              I'm back to square one,,,I found a bad connection with my resistor jumpers at Main board connector..
                              Now with forced PS operation I get 14.47v at 24v pins...backlights blink off and on rapidly when tv is plugged in..Used DVA adapter on my Fluke to capture the max voltage..Something is shutting down PS...Don't know what else to try ..
                              • dfang
                                • Feb 2013
                                • 39
                                Any more suggestions ? I hate to give up,,but,,looks like the cost of boards to try (if they can be found) are not worth the TV..I do appreciate the help and did learn some things for future repair attempts..
                                • newtothis
                                  • Mar 2013
                                  • 1556
                                  • england
                                  #56
                                  This is with main disconnected correct? And the backlights are flashing with jumping volatges?
                                  Do you have 2 jumpers in place? One for PS_ON and one for backlights?
                                  • dfang
                                    • Feb 2013
                                    • 39
                                    I have jumper for PS_ON and ON-OFF..
                                    • newtothis
                                      • Mar 2013
                                      • 1556
                                      • england
                                      #58
                                      Ok remove jumper to ON/OFF and retest voltages, They should come in spec. Reconnect main and make sure we are back to the original fault
                                      • dfang
                                        • Feb 2013
                                        • 39
                                        Ok,,,disconnected ON/OFF jumper but left 5.2v jumped to PS_ON at main board connector,,,,no voltage on 24v pins at PS connector and no backlights..
                                        • newtothis
                                          • Mar 2013
                                          • 1556
                                          • england
                                          #60
                                          What I expected to see, Reconnect main and make sure we are at the original fault.
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • smic717394
                                            by smic717394
                                            07-25-2024, 10:16 AM
                                          • pabloroggeri
                                            Dell inspiron 3421 that distortion on the screen
                                            by pabloroggeri
                                            Dell inspiron 3421
                                            Mother DNE40-CR MB.
                                            Good guys.
                                            I have this problem with this Dell notebook, it has that distortion on the screen as you can see in the photo. has it ever happened to you?
                                            I present the tests and measurements that I already did:
                                            I tried with another screen and it does the same thing, I also put this screen on another one and it looks perfect.
                                            I checked the LVDS flex that goes to the display and it is perfect
                                            Through HDMI output the image looks perfect
                                            All power lines were measured...
                                            09-29-2023, 06:46 AM
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
                                          • spice_disc
                                            Vizio TV M50-C1 reboot cycle and static on screen
                                            by spice_disc
                                            I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                            The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                            09-08-2024, 02:37 PM
