M421VT LED Screen Color Distortion
  • dfang
    • Feb 2013
    • 39
    Re: M421VT LED Screen Color Distortion
    Originally posted by newtothis
    What I expected to see, Reconnect main and make sure we are at the original fault.
    Well,,,we are not back to original fault because something happened between then and now..After my heat/cool procedure I lost the display all together..
    With the main board connected,,the only voltage is the two 5.2vdc pins...no 24v and no 12v at PS connector..
    Btw,,I reinstalled the shield on the main..
    • newtothis
      • Mar 2013
      • 1556
      • england
      #62
      Best guess is the heat took out the poor BGA connection.
      It is either attempt to reflow the BGA device or get a new main. With PSU jumpered it gives you the 12v, You won't see the 24v as the PSU wouldn't getting a signal to turn on the backlights. The main being faulty stops you getting the 12v as its not switching the PSU on.
      Want to attempt a reflow?
      Going to need flux and heatgun (tho if you have a HA station it would be preferable)
      • dfang
        • Feb 2013
        • 39
        I've got paste tinning flux and heat gun..
        • newtothis
          • Mar 2013
          • 1556
          • england
          #64
          Needs to be a no clean flux, otherwise it will eat the connections over time
          • dfang
            • Feb 2013
            • 39
            Ok,,I'll have to get some next week..
            Thanks NTT...
            • newtothis
              • Mar 2013
              • 1556
              • england
              #66
              Remember this is no sure fire method of 100% reliability of working though, I use proper equipment for BGA work and I tell people not to try repairs on boards without it as a rule... But... as you won't have £1000 worth of equipment just to fix this board you may aswell try, If it doesn't work you are at square one still anyway and will need a new board, If it does work awesome you have your TV back
              • dfang
                • Feb 2013
                • 39
                Ah Ha...well,,I'm a gambler,,so,,no problem..What exactly does BGA look like on main board ? Btw I have reflowed computer Nvidia graphics cards before with mixed results..
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  #68
                  Same principle as a GPU.
                  BGA stands for Ball Grid Array... Just the way they are soldered... You know its a BGA as you can't see any solder leads.
                  • dfang
                    • Feb 2013
                    • 39
                    Does heat shield need to come off ? Please say NO..
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      #70
                      HeHe... yes
                      • dfang
                        • Feb 2013
                        • 39
                        HeHe... yes
                        Grrrr! Well,,I am a expert at that..
                        • dfang
                          • Feb 2013
                          • 39
                          Ok NTT,,got some flux,,,what is your recommended procedure for doing the Ball Grind flow with the equipment I have ? Do I need to remove heat sink ? Do I need to protect other components with aluminum foil ? I have a thermometer with probe..
                          • newtothis
                            • Mar 2013
                            • 1556
                            • england
                            #73
                            Ok right...
                            1) cover top area on the board leaving the BGA cut out, don't let the foil touch any Electrolytic Caps.. Aluminium is a really good conductor of heat and most people press it against the board which isn't clever... (Yes no heatsink)
                            2) You will want to hang as much if the board over the edge of a worktop weighting the one end down to keep it stable... You need to be able to see as much of the bottom of the board as possible.
                            3) Flux all around the BGA
                            4) With heat gun in hand warm the bottom of the board all over checking with your thermo probe right next to the BGA, You want to get the board to around 180c
                            5) From around 10cm away heat the BGA trying to gently get it to around 200c and hold it there for 60 seconds (This allows any moisture to escape slowly avoiding popcorning)
                            6) Keep transferring heat to bottom of board to maintain even temps... bottom heat is more important than top heat
                            7) from 5cm away from BGA heat gun it checking the temp every 30 seconds.... Solder needs to hit 217c to reflow. When you get close to that temp you are going to want to either A) tap on top of the BGA every 10 seconds or B) nudge it from the side... This has to be done ever so lightly.... You will see the chip bounce or move when done if the solder is molten.... As expected don't want to push it hard... The solder surface tension will hold it in place though.
                            8) When you see it has moved remove heat and leave it to cool for some time so you can handle it.
                            Good Luck
                            • dfang
                              • Feb 2013
                              • 39
                              Ok right...
                              Good Luck
                              Hello NTT,
                              I finally got around to attempting the BGA on the VIZIO main board...Unfortunately I failed. I followed your instructions (which are very good) but,,the problem came at the point of the last hi temp application (217c).
                              my assistant had the temp probe on the chip monitoring the temp and when the probe was removed it lifted the chip from the board and little balls went rolling,,lol..
                              So,,,I'm trying to find a TXACB5K05302 main board,,they are hard to find right now,,got a request in at SJ...
                              Thanks again for your help..
                              I did learn a lot..
                              • newtothis
                                • Mar 2013
                                • 1556
                                • england
                                #75
                                Hello NTT,
                                I did learn a lot..
                                Oh no!
                                Should of had the probe against the board next to the BGA and not on the BGA itself... Though you managed to get the reflow which is good You know how to do it now but next time (if ever) don't lift the chip LOL
                                Sorry it didn't work out for you but it was at least worth attempting first
                                • Ryan.man
                                  by Ryan.man
                                  02-04-2025, 12:23 PM
                                • smic717394
                                  by smic717394
                                  07-25-2024, 10:16 AM
                                • pabloroggeri
                                  Dell inspiron 3421 that distortion on the screen
                                  by pabloroggeri
                                  Dell inspiron 3421
                                  Mother DNE40-CR MB.
                                  Good guys.
                                  I have this problem with this Dell notebook, it has that distortion on the screen as you can see in the photo. has it ever happened to you?
                                  I present the tests and measurements that I already did:
                                  I tried with another screen and it does the same thing, I also put this screen on another one and it looks perfect.
                                  I checked the LVDS flex that goes to the display and it is perfect
                                  Through HDMI output the image looks perfect
                                  All power lines were measured...
                                  09-29-2023, 06:46 AM
                                • Chrissygizmo
                                  by Chrissygizmo
                                  02-10-2025, 12:33 AM
                                • spice_disc
                                  Vizio TV M50-C1 reboot cycle and static on screen
                                  by spice_disc
                                  I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                  The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                  09-08-2024, 02:37 PM
