Westinghouse Black screen W4207
  • CraigR
    • Dec 2013
    • 959
    I have a Westinghouse W4207 that a guy brought me after he tried to fix it. The story is that the TV was dead totally and he replaced some caps on the power board that were bulged. The set now gets the green light on front when the power button is pushed and I see LED's light up on the main board and I also get 400volts on the main cap but the screen remains black. No flash of the back lights no menu or anything. Not sure what to check next.
  • jetadm123
    • 2169
    Re: Westinghouse Black screen W4207
    The wiring harness in your third photo has a number of cut wires. What did those connect to?
    Post a photo of the inverter assemblies (covered by metal plate on each side of TV). Are they getting any voltage from the power supply? You should see something like 24V.
    • CraigR
      • Dec 2013
      • 959
      I seen those cut wires and the guy swears he did not cut anything and I don't see anyplace they may have gone. The harnesses all look ok and I do not se anything that may have taken a plug. I am getting 24volts at the inverters by the fuse when It's turned on.
      • jetadm123
        • 2169
        Looks like they have been worked on. Check fuse on both inverters. If blown, then check the 4 large mosfets for shorts.
        • CraigR
          • Dec 2013
          • 959
          Already checked fuses and are ok.
          • jetadm123
            • 2169
            Are those the original mosfets on each inverter board? Looks like they were re-soldered/replaced?
            Try checking the secondary winding resistance of each inverter transformer & compare values.
            Also, are any of the pins on the wiring harnesses marked something like BL_ON (also look underneath each board) on the inverter or mainboard?
            • CraigR
              • Dec 2013
              • 959
              It kind of looks like someone tried to touchup the solder on the tops of the mosfets but the connector part looks normal.
              • CraigR
                • Dec 2013
                • 959
                Readings for the windings are about the same. I had a spare bulb and un-pluged each one and tried it. Still no luck but on a couple I got a very short flash on the bulb but only an inch or so coming from the Master side.
                  ON/OFF pin on the left of the large white connector.
                  https://www.badcaps.net/forum/attach...8&d=1427835294
                  • CraigR
                    • Dec 2013
                    • 959
                    Am I correct in thinking that if I get a steady 24volts at the inverters they should fire up unless one or both are bad?
                      It needs 24V + BL-ON command signal, and sometime may also need the DIM command signal.
                      The MASTER/SLAVE Inverter boards setup as push-pull, if the Slave is bad, the lamps will light up half way instead of the whole length of the tube. If the MASTER is bad but the PWM circuits is still function and still send the PWM signals to the Slave, then the lamps will also light up but not at full length.
                      Right now the lamps did not even try to fire up for the error detection circuit to detect the fault, so you need to find out if you have BL-ON signal or not first, then if the PWM IC is getting the VCC to run.
                      • CraigR
                        • Dec 2013
                        • 959
                        I am getting 5volts at the connection you pointed out earlier for back light on.
                        • jetadm123
                          • 2169
                          Sounds like it's getting the BL_ON command. Long shot, but try re-seating the wiring harness connectors on both inverters. Also, even though the fuses on both inverters check good, try checking the 4 mosfets on each inverter for shorts.
                          • CraigR
                            • Dec 2013
                            • 959
                            The mosfets checked ok already. I ordered the slave inverter first to try and will report back when it comes in.
                            • CraigR
                              • Dec 2013
                              • 959
                              Well got that board and installed and same thing so I guess I will get the master then.
                              • HTR-Informatique
                                by HTR-Informatique
                                02-09-2025, 06:51 AM
                              • VcemPzd
                                Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                by VcemPzd
                                Hello everyone !
                                My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                04-28-2025, 10:14 AM
                              • DaniK
                                Acer Aspire E5-574-52RH - black screen
                                by DaniK
                                I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                Symptoms are:
                                - random black screen after displaying Acer logo...
                                02-21-2024, 06:27 AM
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • Francesco Valsecchi
                                r9 290 "black screen"
                                by Francesco Valsecchi
                                hello i bought a faulty radeon r9 290 (black screen) to learn to fix gpu's, when it arrived i mesured resistances on 3.3 v and 12v both on the pcie connector and cables i have no idea on how to recognize 1.8v pex and 5v but i checked all inductors and none had a dead short only one was 55 or 140 ohms i don't really remember and i assumed it was memory i installed it on the pc and it delivered no image, not even a backlight so i installed it as a secondary graphics card using the igpu as primary, both device manager and gpu-z only showed the igpu so i assumed it was acutally a no detect even tough...
                                08-18-2025, 06:44 AM
