I have a Westinghouse W4207 that a guy brought me after he tried to fix it. The story is that the TV was dead totally and he replaced some caps on the power board that were bulged. The set now gets the green light on front when the power button is pushed and I see LED's light up on the main board and I also get 400volts on the main cap but the screen remains black. No flash of the back lights no menu or anything. Not sure what to check next.
Westinghouse Black screen W4207
Re: Westinghouse Black screen W4207
The wiring harness in your third photo has a number of cut wires. What did those connect to?
Post a photo of the inverter assemblies (covered by metal plate on each side of TV). Are they getting any voltage from the power supply? You should see something like 24V.Last edited by jetadm123; 03-31-2015, 02:41 PM. -
I seen those cut wires and the guy swears he did not cut anything and I don't see anyplace they may have gone. The harnesses all look ok and I do not se anything that may have taken a plug. I am getting 24volts at the inverters by the fuse when It's turned on.Attached Filesif you find these attachements useful please consider making a small donation to the site
Are those the original mosfets on each inverter board? Looks like they were re-soldered/replaced?
Try checking the secondary winding resistance of each inverter transformer & compare values.
Also, are any of the pins on the wiring harnesses marked something like BL_ON (also look underneath each board) on the inverter or mainboard?Last edited by jetadm123; 03-31-2015, 04:03 PM.Comment
Readings for the windings are about the same. I had a spare bulb and un-pluged each one and tried it. Still no luck but on a couple I got a very short flash on the bulb but only an inch or so coming from the Master side.Comment
ON/OFF pin on the left of the large white connector.
https://www.badcaps.net/forum/attach...8&d=1427835294Never stop learning
It needs 24V + BL-ON command signal, and sometime may also need the DIM command signal.
The MASTER/SLAVE Inverter boards setup as push-pull, if the Slave is bad, the lamps will light up half way instead of the whole length of the tube. If the MASTER is bad but the PWM circuits is still function and still send the PWM signals to the Slave, then the lamps will also light up but not at full length.
Right now the lamps did not even try to fire up for the error detection circuit to detect the fault, so you need to find out if you have BL-ON signal or not first, then if the PWM IC is getting the VCC to run.Never stop learning
Sounds like it's getting the BL_ON command. Long shot, but try re-seating the wiring harness connectors on both inverters. Also, even though the fuses on both inverters check good, try checking the 4 mosfets on each inverter for shorts.Comment
I also had corrosion/oxidation on the... -
by VcemPzdHello everyone !
My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared
I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
by alro7779Hello, guys!
I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
Alex.... -
by DaniKHi everyone,
I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
Laptop came in for a SSD upgrade, took everything apart to install the SSD.
Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
Symptoms are:
- random black screen after displaying Acer logo... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... - Loading...
