how to test lcd led backlight?
  • pnv
    • Apr 2013
    • 11
    please post test methods you use
    thanks!
  • Hamie
    • Apr 2014
    • 1383
    Re: how to test lcd led backlight?
    Jump with a low ohm resitor between ps-on and 5v stby, and 5vstby and bl-on (inverter on off)
      OK, are you asking how to test individual LED mounted on the circuit board that form LED string?
      You can use 3V battery with 100 Ohms resistor to limit the current for testing individual LED.
      Or you already verify that the LED driver circuits are OK but the LED still does not light up?
      Test LED string current draw using DCA.
      https://www.badcaps.net/forum/showpo...4&postcount=95
      Or used indicator:
      https://www.badcaps.net/forum/showpo...&postcount=107
      • pnv
        • Apr 2013
        • 11
        Yes, something like an adjustable voltage source with constant current
        • pnv
          • Apr 2013
          • 11
          his would be a constant current source would be the voltage regulator.
          What do you think?
            That will be correct if all the LED int he string are good, but if one goes open circuit then nothing will happen, but you need to know how many LEDs are in the string to determine what the power supply voltage needs to be, some string you will need more than 100VDC, Vf of each LED is between 3~3.6V.
            • pnv
              • Apr 2013
              • 11
              Please, if not asking too much to draw scheme Led string indicator to find out which string is dead.
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                LED's are wired like christmas-tree lights....
                One dead--all out.
                You just have to test each one in turn. No schematics, just a meter.....
                TELEFIX
                • pnv
                  • Apr 2013
                  • 11
                  I think it is exciting and dynamic method of insertion of an indicator Lord budm
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    It would be nice if these led strings had standards for each size of screen then one could build a test circuit just to plug in and see if the individual strings worked or not, but that would be to easy.
                      See picture, the diodes will get hot so do not run it too long.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8352
                        Now that is a neat testing device I hafta make! Thanks budm!
                        • keeney123
                          Lauren
                          • Sep 2014
                          • 2536
                          Bud M don't laugh at me, but I was hoping to unplug all the LED strings and plug them into a separate power source that would eliminate any feed back circuit from turning the the LED driver chip off.
                            If you want to use external constant current power source to drive the LED string then the strings are no longer connected to the LED driver board) so there is need to have any power to the TV at all since you are just testing LEDs.
                            The harder part is to figure out how the strings are connected together and which wire is the Anode and which wire is the Cathode if the panel is not open up to see the LED string, or you can trace the connector on the driver board to see how it is done.
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              Yes that is where standards would work.
                              • Peter Chiu
                                Banned
                                • Dec 2012
                                • 145
                                ? Auto-recovery LED screen ? Resettable Fuse ? Auto-bypass LED?
                                ST has LBP01 part can bypass any defected LEDs
                                Benefits
                                ■ Keep LED strings on in case of LED open mode failure
                                ■ Reduced maintenance cost
                                ■ Increase lifetime of the lighting system
                                https://cdn.badcaps-static.com/pdfs/...34696944c0.pdf
                                But, new LED TV used 2000 LEDs to make more brighter LED screen. I predict ( Auto-bypass LEDs will be use to build Auto recovery LED screen) in the future !
                                (I mean, LED will build in bypass circuit in the chip which just two more diodes. )
                                Tips: So next time don't put a cooper wire cross the defect LED put a diode.This allows the right amount current to flow through the other LEDs.
                                • Peter Chiu
                                  Banned
                                  • Dec 2012
                                  • 145
                                  Constant Current Driver for LED Backlights Tester
                                  https://cdn.badcaps-static.com/pdfs/...eeae3f24ee.pdf
                                    Benefits
                                    Problem is, who's paying for this? Manufacturers won't care too much unless it lowers cost of production or reduces in-warranty failures.
                                    • Peter Chiu
                                      Banned
                                      • Dec 2012
                                      • 145
                                      LED is a diode too, when manufacture do the masking, it wont cost them not too much to do it.
                                      Basically just a P-N junction.
                                        Not as simple as that. Introduces yield issues, LEDs are made from different types of semiconductor (GaAs is quite common), GaAs doesn't make good transistors.
                                        One possible solution would be a zener diode across the LED, the zener would conduct, heat up then anti-fuse shorted if the LED went open.
                                        • thetonywarren
                                          TCL 43S435 NO BACKLIGHT ISSUE, LEDS TEST OK
                                          by thetonywarren
                                          I have a TCL 43S435 with no backlights. I contacted ShopJimmy and they said power supply. I got replacement power supply, but still doesnt work. I have confirmed that there is an image with flashlight test. I have also verified that the led strips work when I probe them with LED tester. Any ideas would be helpful. I am also geting a double blink on the status led when trying to turn it on......Nothing on the power supply looks suspect, and caps look ok. Where should I start to test......Thanks!...
                                          04-23-2025, 10:48 AM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • DanPoka
                                          by DanPoka
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • gabrielA7
                                          Macbook pro A1706 / Backlight flex cable compatibility
                                          by gabrielA7
                                          Hey guys!!
                                          I’ve got a question here!
                                          I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
                                          Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
                                          Here’s what the bot told me:
                                          I said to him: “I’m going to install the 821-01229-A.”
                                          ChatGPT replied:
                                          Understood — but before you solder or install the 821-01229-A,
                                          11-11-2025, 03:26 PM
