Sony Trinitron KD-28DL10U red, green, red, green OCP fault
  • PCS_
    • Mar 2015
    • 25
    • England
    Hi guys,
    I've been given this Trinitron, it was working fine 2 months back, has just been sitting in a spare bedroom since.
    I powered it on yesterday to find that it won't come on, just gives the OCP error on the LED.
    Any advice on where to start? Someone has said that the jungle chip could be the cause but I want to rule out bad caps and transistors before I go down that route
    I will obviously ensure I discharge the high voltage to tube
    • 31192
    Re: Sony Trinitron KD-28DL10U red, green, red, green OCP fault
    have you got a schematic?
    • PCS_
      • Mar 2015
      • 25
      • England
      Thanks for your reply stj, Yes I've got the service manual with schematic
      I've linked to it below for your reference,
      • PCS_
        • Mar 2015
        • 25
        • England
        http://www.maisiemanuals.com/sony/so...l-p-17519.html
          • 31192
          so explain in detail what happens.
          on page 41, is the neck board.
          there are 3 testpoints: TP4-6
          with the tv off and unplugged, check to see if any of these testpoints are shorted to any other pins on the tube socket.
          • PCS_
            • Mar 2015
            • 25
            • England
            I press the power button, tube sounds like it is energised. Ie the noise a CRT usually makes when you turn it on but no picture it just goes off and gives blink code
              • 31192
              well those testpoints should not show any low resistance to the other pins on the socket.
              if one does, unplug the board from the tube neck and check again.
              • PCS_
                • Mar 2015
                • 25
                • England
                Yes I see, TP 4-6 of J701 thanks
                • PCS_
                  • Mar 2015
                  • 25
                  • England
                  So this will give an indication of the troublesome circuit I presume? I need to clear space on my bench for this as its a fairly chunky set, once I do I'll post back my findings from the continuity test.
                  Is this the point to always start at with CRT's with this problem? Reason I ask Is to understand how you've pointed towards the C board. Sorry for all the questions but Im keen to learn.
                  Thx
                    • 31192
                    i'v never worked a sony wide,
                    but ocp on philips and thompson is common - unfortunatly there is a reliability problem with the tube.
                    it is very common for the blue gun to short and shut the tv down.
                    if you find one gun is shorted, there is a way to double-check,
                    you lift the resistor and spark-gap for the shorted gun and the tv should run with a coloured field.
                    now hopefully none of the guns will be shorted.
                    the problem is these fucking narrow necks on the modern crt's have much less space between all the parts - yes, they use less current to drive the heater and they start faster,
                    but at the expense of reliability.
                    • R_J
                      • Jun 2012
                      • 9588
                      You could also check and see if you have the 200 volts to ic701, I have replaced these ic's in the past for being shorted. If the 200 volts is low or missing, disconnect pin 6 of ic701 and see if the voltage comes back up.
                      • PCS_
                        • Mar 2015
                        • 25
                        • England
                        I'm going to have to keep my fingers crossed it's not a shorted gun then. I always thought the Sony trinitrons were supposed to be an all round decent set that's what people have been telling me but then none of them have had them on a bench
                        • PCS_
                          • Mar 2015
                          • 25
                          • England
                          It's going on my bench later today so I'll check, thanks for that
                            • 31192
                            btw, i'm pretty sure it's not really a trinitron - those tubes need 2 focus lines from the transformer.
                            • PCS_
                              • Mar 2015
                              • 25
                              • England
                              Now I'm confused. Why have they marked it as a Trinitron if it's not a true Trinitron?
                                • 31192
                                marketing?
                                they pulled the same shit with "vega"
                                it was a flat-faced tube they licensed from russia - i have an original russian one.
                                but now they slap the "vega" label on lcd's - sony are scum.
                                • PCS_
                                  • Mar 2015
                                  • 25
                                  • England
                                  That's absolutely discusting. the only reason I picked this set up is because I read that trinitrons are the best sets image wise for retro computers.
                                  • PCS_
                                    • Mar 2015
                                    • 25
                                    • England
                                    Right, I've got the set on bench. Checked for continuity from KR, KG and KB to the rest of the pins and none are of low resistance
                                      • 31192
                                      good,
                                      while your on the C board, check none of the diodes are shorted, then check the driver chip 701 as RJ says.
                                      i'd isolate it by lifting L704 rather than trying to lift a chip pin btw.
                                        • 31192
                                        what computers???
                                        • sickboy
                                          Strange CRT Fault (Sony Trinitron M1410U)
                                          by sickboy
                                          This is a CRT I sold a few months ago and it's came back with this weird issue. It's intermittent, but not a thermal fault, or tap sensitive - just completely random. The right side of the picture completely blanks out (picture is not shifted). The on screen display is unaffected though, so not a fault in the line section. Anyone seen anything like before in a CRT?
                                          11-10-2024, 05:02 AM
                                        • shahnld
                                          Sony kdl 65xg9505 green amber blinking
                                          by shahnld
                                          Good Day.
                                          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                          01-03-2024, 03:05 PM
                                        • cmonkey
                                          Sony Trinitron KV32FV27 Suddenly Dimmed
                                          by cmonkey
                                          A couple of days ago I finally got my hands on a locally sourced Trinitron and after lugging all 175 LBS home I gave it a good cleaning inside and out. The guy said it had been in a shed for 2 years, but the outside wasn't too bad. The inside was another story and while there was no evidence of mouse, it had certainly been kept in a VERY dirty home.
                                          I cleaned it to an acceptable level of grime, at least clean enough to where nothing would heat up from the dust insulation. I then tried it out and it worked!
                                          I'd say I had it on for about 15 minutes or so and then lugged...
                                          04-28-2023, 06:25 PM
                                        • motorahead
                                          Sony Trinitron (KV-20FV12) Vertical Deflection Stopped
                                          by motorahead
                                          Hi everyone, I've been troubleshooting my 20" Sony Trinitron (KV-20FV12) CRT after it failed to show a picture. The standby LED is blinking 4 times, which according to the service manual is a failed vertical deflection via the self-diagnostic check during power up.
                                          After getting the TV checked out by a technician and doing research on my own. The most obvious first step was to replace the IC502. I've done so with an exact NOS replacement with no luck. I've read a few suggestions to make sure the 12V supply to pin 2, but that voltage check would seem misleading? It seems if the...
                                          10-21-2023, 03:50 PM
                                        • jimjoe123
                                          LCD TV Green/Pink screen problem
                                          by jimjoe123
                                          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                          Then each time...
                                          02-23-2020, 01:29 AM
