Sony KDL-40hx723 5 blinking lights.
  • Cryogen
    • Jan 2015
    • 91
    • United Kingdom
    Hello
    I was repairing my tv double image fault and I almost fix it if I had not accidentally misplaced the panel's ribbon cable to the Tcon header.
    I heard an electric noise (like a short) and the panel went blank. Now , every-time I try to turn on the tv the green light comes on for a fraction of a second and then the red standby light flashes 5 times then goes off for a couple of seconds and then it does 5 times again then 2 seconds off... It repeats those 2 steps indefinitely.
    Now, do you think I fried the Tcon, psu , mainboard or the led lcd panel?
    If I fried the latter, then I am in a lot of trouble.
    Re: Sony KDL-40hx723 5 blinking lights.
    Check the SMD fuse on the T-CON board first, then check and see if you have 12VDC on both ends of the fuse.
    • Cryogen
      • Jan 2015
      • 91
      • United Kingdom
      Where does the SMD fuse is?
        Show us good clear pictures of the T-CON board then we can point it out to you.
        • Cryogen
          • Jan 2015
          • 91
          • United Kingdom
          Here
            I can see at least two in your picture, picture is kind of dark.
            • Cryogen
              • Jan 2015
              • 91
              • United Kingdom
              I see. To check the 12volts do I have to reconnect and turn the tv on?
                You can check the resistance first, it should show as short (same resistance reading as when your meter probes shorted together).
                Then check the DCV when TV is turned on, just do not let the probes slip on you (Black probe on the chassis).
                • Cryogen
                  • Jan 2015
                  • 91
                  • United Kingdom
                  Now it turns on but the panel displays white screen with fainted images on background.
                  maaaan...
                    maaaan...
                    So what did you do? Can you show us the screen shot of what the images look like on the screen?
                    • Cryogen
                      • Jan 2015
                      • 91
                      • United Kingdom
                      This is the picture.
                        That looks like the GAMMA Voltages are bad.
                        https://www.badcaps.net/forum/showth...563#post454563
                        • Cryogen
                          • Jan 2015
                          • 91
                          • United Kingdom
                          What the hell...
                          So, which IC should I replace with my soldering iron?
                            This board does not use the AS15 Gamma chip, it also does not give any test points to test the Gamma Voltages so I cannot really give you any suggestion as to what part and where to test the Voltages.
                            You may look to see if the good replacement board can be had for reasonable price and have good return policy.
                            • Cryogen
                              • Jan 2015
                              • 91
                              • United Kingdom
                              Mate, you are a veteran. You cannot leave me like that. I need someone who can tell me which part I should replace.
                              Do you think I can bake it in the oven as a last shot?
                                Well I cannot tell by the pictures of what is/are damaged, there are no labels test points, no designator for the components (I.E. the fuses, it does not even have the label like F1 ,F2 for the fuses) with label. They just do not want you to be able to do even testing Voltages.
                                Sorry.
                                • Cryogen
                                  • Jan 2015
                                  • 91
                                  • United Kingdom
                                  Sorry.
                                  What about stewing it without water?
                                  • DRBENSONS
                                    • Sep 2019
                                    • 6
                                    • Zambia
                                    My Sony kdl-40hx723 is not powering on, red light blinks 5 times. After leaving it on power for few minutes and then press the power button the TV powers on to a completely white screen for about 3 seconds and then off again and it starts blinking 5 times. What could be the problem please
                                      • 12206
                                      • U.S.
                                      Try a t-con board replacement.
                                      • DRBENSONS
                                        • Sep 2019
                                        • 6
                                        • Zambia
                                        So far I have replaced the t-con and the main board but nothing has changed
                                        • Audeze
                                          Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                          by Audeze
                                          I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                          Does...
                                          10-06-2024, 08:54 PM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • Watson306
                                          6 Red Blinking lights (left side darker) on Sony KD-49XE8396
                                          by Watson306
                                          I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
                                          I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
                                          I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
                                          Many Thanks in advance.
                                          11-01-2022, 05:33 AM
                                        • YasaCh
                                          Sony kdl 40p5500 red light keeps blinking 3 times
                                          by YasaCh
                                          Hello...
                                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                          i opened the back cover no sign of damage on the powery suply or motherboard
                                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                          07-07-2025, 11:53 AM
                                        • thelankanguy
                                          Sony KD-55X9000F TCON Issue
                                          by thelankanguy
                                          The TV shows a black screen with no image.
                                          TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                          Later both ribbons were disconnected and TCON voltages were tested.
                                          12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                          There is also a short to ground in this circled inductor.
                                          Is this a TCON issue or something else ?...
                                          12-13-2024, 12:27 AM
