LG 47LD500-UA not turning on
  • salongaopm
    • Mar 2013
    • 13
    • usa
    I have an LG 47LD500-UA lcd tv that is not turning on, no light on standby led, no sounds or picture.
    Below are what I have done so far:
    1. checked the voltage to +5v pins that leads to main board - I noted that it will read at around 5.+v immediately after the tv is plugged in to an outlet and will gradually goes down up to 0 after several minutes.
    2. After watching a few YouTube videos and reading several post online, I replaced 3 parts that I thought was defective....did not solve the problem.
    3. I checked the small fuses (3) from the main board for continuity and they seem to be okay.
    Any help will be greatly appreciated. DISCLAIMER: I don't have any electronics educational background and not really sure how to use multimeter properly. So please take that in consideration when giving instructions on what to do. I have a descent soldering station (CSI Station 2A) that I can use to solder some electronic parts.
    Attached are pictures of main board, power supply and the multimeter (I got it free) that I am using.
  • salongaopm
    • Mar 2013
    • 13
    • usa
    Re: LG 47LD500-UA not turning on
    more pictures
    • salongaopm
      • Mar 2013
      • 13
      • usa
      bump
      • Bill79
        • Mar 2017
        • 14
        Looks like you had the same issue that I have.
        Your post was a long time ago and atleast here no one helped you.
        Did you learn anything to get you're problem resolved?
        From the looks of your pics, we have the same TV. Mine is apart, going to check that fuse next.
        • heavymachines
          • Mar 2011
          • 1028
          Take straight clear focused pictures of entire back of tv and individual boards . Tell us tests you have done so far and descriptive symptoms... You'll get better results.
          • Bill79
            • Mar 2017
            • 14
            Good Day, Thanks for a response.
            Well, as far as pictures are concerned, I have a problem uploading pictures from phone to PC).
            But my boards look absolutely no different from the topic posters picture for his TV.
            His boards have the same (what I thought were) defects on them.
            One thing I did find (that a camera would not have picked up) was on the back of the power board there was a piece of dust that might have gotten through the back panel, fell (inside the TV) in between the metal case the back of the power board on the (soldered through the board) terminals.
            This speck was as fine as hairs and I saw them under close examination under a 4 tube fluorescent shop light.
            These dust hairs were touching the terminal next to it and also 2 more terminals on the same (object that was soldered to the board) were grounded by a dust fiber.
            On the other side of the board the object that is soldered in identifies itself as U101 on the front of the board.
            I do not have that much solid state knowledge to know what some of the objects are and do on a solid state board.
            These pieces of dust were scattered in a way that looked like they have been static charged toward both other terminals and even the metal back wall.
            This U101 has a heat sink on it, so that tells me it gets hot and needs better cooling.
            But, this was an observation after opening up the back and looking. I am not sure if this is the cause of my problems.
            I have no wiring diagram either.
            I know this board has issues with capacitors, but all those on the low and high voltage side look good (not puckered on top or no oozing).
            But Sunday morning about 5 AM I was watching TV, my cable provider (Comcast) done their daily updates to their X1 platform.
            Normally, the TV goes through power and video feed surges as it loads updates and restarts their gateway. Normally when done the TV will resume what I was watching/channel I was watching.
            This time, there was no resumption. I also had no power (green) or red (standby) light.
            At any time when plugging in the set did I hear (back off) any power engaging, no relay clicks no nothing when plugging in and un-plugging the power cord into the power board.
            I do have a multi meter and the fuse checks good using continuity and resistance.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              What DC voltage do you have on the bridge rectifier "+" & "-" pins. These look like the outer pins. Use you meter set to DC and connect the probes to the legs.
              What AC voltage do you have when you measure to two inner legs "~". Again set meter to AC and carefully use your meter probes on the two inner legs.
              • Bill79
                • Mar 2017
                • 14
                Good Day, Thank you for your reply.
                Okay. I have done what you advised.
                I used alligator clip test leads on the DC (outer pins) and then to my meter like you advised.
                I am getting between 156.9 and 157.0 VDC when board is plugged in and when you unplug it, the DC voltage slowly drops off to zero.
                On the AC side (inner) I had to use just the leads on my meter and I got 122.6 volts.
                AC side atleast sounds good to me.
                What is the DC out put "supposed to" be? 157 volts sounds high.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  The AC side is 122.6V but I thought the AC voltage was 115V for the USA which would give 1.414 * 115V = 162V DC at the bridge rectifier.
                  If it was 122.6V then it should come out as 173V?
                  What is the voltage written on the side of C809, and the other two large capacitors alongside it and what DC voltage do they read between the two legs of each of them.
                  There's also a fuse marked F102 alongside. With the power off and plug removed from the mains supply can you check that it has continuity using your meter on ohms.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4544
                    • Italy - Milan
                    The method to begin tests on a tv like this is always the same, you procured some high wattage resistors as a dummy load, for the 5v a pair of 3,3ohm 10W can go well, for the 3,3v the same 3,3ohm 10W is ok, for the 12-13v use a 12v lamp like the ones for rooms (halogen) or car lights. Then attach to the mains current only the psu with loads, for the standby voltages like the ones marked +5vsb you better put 2 3,3ohms in series, if the psu works ok you read the right voltage on outputs and after half a minute resistors goes hot.
                    The lamps will glow..
                    • Bill79
                      • Mar 2017
                      • 14
                      Good Day,
                      I am assuming when you said "voltage on the side of C809 and the other tow large caps alongside", I assumed you meant C609.
                      NOTE in a new reply below I will post brand new close up pics of (my actual board) to help in referencing circuits.
                      Assuming you meant C609, all 3 are marked 450V and all three check in at 162.2/3VDC when tested with board plugged in and out of TV on a dielectric mat.
                      The fuse tests at 2-3 ohms, same reading as if I touched the two terminals together on my meter.
                      • Bill79
                        • Mar 2017
                        • 14
                        I had removed and taken much better pictures of my actual board.
                        I had noticed after you wanted me to test C809 after looking and realizing there was no C809, I looked at the topic posters pics and his were a little blurry when it came to close ups.
                        So I will post better, detailed pics.
                        And again, this IS MY ACTUAL power board.
                        Hope this helps us in future relating to this circuitry.
                          https://www.badcaps.net/forum/attach...5&d=1491077827
                          So to be clear, right now you do not have any DCV at all on any pin of that white connector, correct?
                            BTW, your board is
                            Vizio/LG 0500-0412-1000 (PLHH-A945A) Power Supply / Backlight Inverter
                            Pictures provided by shojimmy.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4544
                              • Italy - Milan
                              from post #1:
                              "1. checked the voltage to +5v pins that leads to main board - I noted that it will read at around 5.+v immediately after the tv is plugged in to an outlet and will gradually goes down up to 0 after several minutes. "
                              this is maybe a mainboard fault, but without test the psu by itself who can say? I don't know why the need to test voltage on primary side..
                              • Bill79
                                • Mar 2017
                                • 14
                                Originally posted by budm
                                BTW, your board is
                                Yes Sir, that is the correct board.
                                I did see that on Jimmy's website, but I think they were out of stock on it to buy a new one.
                                But yes, that is the correct one.
                                • Bill79
                                  • Mar 2017
                                  • 14
                                  Originally posted by Davi.p
                                  from post #1:
                                  Yes, I am getting no voltage at the +5 pins at the out put to the main board.
                                  Dick Barton and I went through some checks already.
                                  I replied to him this morning with relevant information.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4544
                                    • Italy - Milan
                                    But the O.P. don't says "no 5v"... please be clear when you tag along another one's post, if your case was different it was better to open a new thread, if not threads reaches orribile post numbers like here in this forum happens.. who has wish to read 133 post to come to the point?
                                      OK, so to be sure, if you run the power supply board by itself without having main board connected to it, you do not get any 5vdc, correct?
                                        Check the White rectangular fuse F102 (T4A H 250V).
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • Docus
                                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                          by Docus
                                          Hi everyone 😀,
                                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                                          06-10-2025, 04:24 PM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                          HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-12-2024, 02:20 PM
