LG 47LD500-UA not turning on
  • Bill79
    • Mar 2017
    • 14
    Re: LG 47LD500-UA not turning on
    Originally posted by Davi.p
    But the O.P. don't says "no 5v"... please be clear when you tag along another one's post, if your case was different it was better to open a new thread, if not threads reaches orribile post numbers like here in this forum happens.. who has wish to read 133 post to come to the point?
    Well, this post was started by some one else with the same TV a little bit before I had the problem.
    I Googled the symptoms and found this thread on this site with with the same problem with no solution (that I saw).
    So, I figured add onto this one so the next guy can find this easy in a Google search and not have multiple threads to choose from.
    • Bill79
      • Mar 2017
      • 14
      Originally posted by budm
      OK, so to be sure, if you run the power supply board by itself without having main board connected to it, you do not get any 5vdc, correct?
      Yes, that is correct.
      • Bill79
        • Mar 2017
        • 14
        Check the White rectangular fuse F102 (T4A H 250V).
        First thing I checked.Fuse is good.
        I am looking through your guides right now.
        It will take a minute to go through.
          You have two fuses, so both fuses are good then and you have 160VDc on both ends of that F102 fuse (with ref to the hot side circuit GND) that feeds the B+ to the standby power supply section.
          • Bill79
            • Mar 2017
            • 14
            Yes, I have 162VDC at F102 fuse plugged in. And when I unplug, the voltage drops off.
            What type of fuse is that for F102?
              I cannot tell from the pictures but it is Time Delayed type (Slo-bo) fuse.
              So at this point we know we have 160 Vdc feeding the STBY SMPS IC (the multi-pin to-220 case) mounted on the heatsink.
              What is the P/N of that SMPS IC?
              • Bill79
                • Mar 2017
                • 14
                I am not sure I understand this request.
                I am unclear on the "STBY SMPS IC (the multi-pin to-220 case) mounted on the heatsink" specifically.
                  It is the U101 you indicated in your first post, that is the SMPS (Switched Mode Power Supply) IC that produces the 5VSTBY Voltage.
                  • Bill79
                    • Mar 2017
                    • 14
                    That is what I thought you meant. I guess too I was checking myself there.
                    So I see you saw that reply. Good. Something has been bugging me about U101 this entire time I had this TV open (as per my description).
                    The numbers on that semiconductor are DA23AH (right before that number there appears to be a Foxconn "F" F before it. (Or atleast to me the F reminds me of a Foxconn F).
                    Under that number there is another number. It appears to read Q0465R.
                    I hope this is the info you need.
                    I have always suspected that semiconductor. But wanted to learn if there was a proper way of testing that since it had 6 legs to it into the board.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4541
                      • Italy - Milan
                      #30
                      Foxconn chip?? Naahh...! It is Fairchild maybe..
                      • Bill79
                        • Mar 2017
                        • 14
                        Now that is a possibility!
                          https://www.fairchildsemi.com/produc...FSQ0465RS.html
                          Start checking Voltages at the pins of the IC.
                          BTW, you did test the rectifier diodes on the cold side, the three that are mounted on the heatsinks next to the connector that goes to the main board, right?
                          • cheeky2
                            by cheeky2
                            05-25-2024, 03:27 AM
                          • Dani_2024
                            by Dani_2024
                            10-28-2024, 05:06 PM
                          • Docus
                            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                            by Docus
                            Hi everyone 😀,
                            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                            1. I already own the exact same model, but its plastic chassis is badly damaged.
                            06-10-2025, 04:24 PM
                          • ChristianBr01
                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                            by ChristianBr01
                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                            04-23-2025, 01:48 AM
                            HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                            This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                            09-12-2024, 02:20 PM
