Vizio E470VL tv problems
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • howardc64
    Vizio M557-G0 1/2 panel VGHD LC1 (and maybe XON VSSQ LC2) Problems
    by howardc64
    Failure Symptom
    No Display. Just random blocks of grouped vertical red lines.
    Disconnect right 1/2 panel (rear view), left 1/2 displays properly
    Masking T-Con Signal Diagnostic
    Reduced masking to 5 signals on right 1/2 panel and get perfect picture
    Pins are
    1 GND
    2 VGHD
    3 XON
    4 VSSQ
    5 LC2
    6 LC1
    VGHD and LC1 masking is absolutely necessary to get working panel. Didn't unmask 3-5 individually.
    Pictures and Schematic
    XON, LC2, LC1 are on AUO s302-21 32pin QFN...
    10-14-2024, 01:30 PM
  • Bugman1400
    Vizio E470VL got +5VSB, but no 12V
    by Bugman1400
    EDITED: I thought my Vizio E470VL has +5VSB and no 12v on the PS board, but after plugging the cable back in and testing the pins on the Main board I realized that I do have 12V. I assume the 12V is turned on when the ON/OFF switch is pressed. The Vizio light in front does go from Standby Orange to White when ON. But, I still have no picture or sound. Test values of PS board are below.
    +5VSB= +5.09
    12V= +12.18
    PS_ON= +2.25
    I_ON/OFF= +3.27
    LAMP= +3.18
    DIM= +2.97
    Any more testing I can do on Main board or is it just a replacement?...
    09-04-2022, 09:19 AM
  • SS454
    vizio e650i-a2 backlight flashes then turns off
    by SS454
    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
    panel: au optronics T650HVN05.4
    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
    https://www.shopjimmy.com/vizio-56-0...-power-supply/
    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
    08-20-2020, 03:57 PM
  • dholley
    Vizio TV E470VL SMPS Flucuation Output Voltage
    by dholley
    Would someone please help troubleshoot a Vizio 47" TV Switch Mode Power Supply with 5 volt output fluctuating voltage. The voltage fluctuates at 5 the volt output and at the Pulse Switch Modulating IC at VCC. I have the following notes:
    1. The 3 main filter caps all have approximately 167 volts steady
    2. I have replaced 4 mosfets next to what I think is called the inventor transformer (big black transformer) pictures attached
    3. I have replaced Fuse F102 with an equivalent
    4. I have check all diodes and caps and they seem to be ok
    5. I replaced the 431...
    01-20-2022, 03:12 PM
