Polaroid P32LED13 stuck in standby
    So, this one turned up on the bench. Power light flashes, but the set won't power up. It's stuck in standby. Now, I would have thought that the main board had corrupted firmware. But, somewhat surprisingly that was not the case.
    There are two faults: the main issue is the 17IPS19-4 power supply 24V isn't coming up, which is due to a FET and diode in the boost converter being shorted. Naively testing the commonly failed diodes (on the output) would lead you to suspect the diodes were shorted - but they aren't. Surprisingly, it's the diode on the output of the boost converter which is short. But, this alone wouln't account for the short on the 24V output - it would just prevent the LED strips working, the TV should still otherwise "work".
    What's happened is this diode being short appears to have damaged the main boost FET for the boost stage (this is all on the secondary so no blown fuses or damage to the primary.) The boost stage takes the ~24V and boosts it to about 60-70V for the LED strip. This is shorted, preventing the 24V rail coming up, and the main board detects this fault and shuts down.
    So, removed the FET and diode and sure enough now the TV turns on, and you can see a (non-backlit) image on the screen using a torch. So the set appears to only have a PSU fault. I will replace the FET and diode and see if the problem is fixed.
    The only major concern I have is if that LED driver IC has been damaged (TPS61199); the FET has around 130 ohm gate-drain and gate-source (with 5 ohms drain-source) so I *think* it's going to be OK. I ohmed out the gate drive to Vcc and ground and it's about 2k to each so it doesn't look shorted. The parts are cheap so I'll just try it and see what it does. Worst case, the FET blows up again, but it's not expensive.
    These power supplies, whilst cheaply made with the cheapest off the shelf components, don't look TOO bad, especially when you compare them to a PW25-4.... frankly, I'd take a million of these over a single more PW25-4...!
    It's kinda weird jumping from a 9G KURO to the cheapest of the cheapest Vestel LED models. And the terrible thing is, Pioneer are now whoring their name out to dodgy OEMs... and there's talk of a Pioneer LED set based on a Vestel chassis...
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Polaroid P32LED13 stuck in standby
    I just recapped two 17pw26-4 that had blown samxons and the one on the right had a blown diode that was causing the 24v not to come up, thanks for the info Tom.
    Dont ask why im wasting good caps on these just dont have any cheap caps in stock, caps used panasonic, rubycon, chemicon and nichicon.
      Yeah, for some reason shorted diodes are a real problem with Vestel. Not complaining about an easy fix. But a 2014 TV, man, I feel sorry for the owners, lost the receipt, just a cheap £159 TV from ASDA.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Vestel are great at blowing diodes, the newer led ones are the worst they make the 17pw20 look well built such a shame so many people will have brought these junks becuase of the reduced prices.
          I'll check the PIV on these diodes - but I suspect it's a thermal thing going on here - had a similar fault on some boxes at work (can't talk much about it, but affected thousands due to counterfeit diodes reaching our supply chain.) Hope LED backlight is OK on this panel.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Yeah Im just saving up for a os scope so I can check things like that
              Get a DS1054Z, under £300 now, absolute bargain for what it is.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Alright will look into it cheers mon
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  On the subject of vestel got one on the way to me now, think its a pw26 hoping just caps by the sounds of it.
                    TV is fixed.
                    So, the Vestel schematic is wrong again (wow, what a shock!) They suggest using a 30V MOSFET (STD17NF03)... but after blowing up two FETs I realised that obviously, a 30V FET in a circuit with a 65V OVP threshold would not work. I think it's another case of the Vestel CAD engineer being too lazy to spec in the right FET, publishing the schematic and then changing it before final production.
                    I found a compatible FET on a scrap Sharp inverter (2SK3706) and was able to fix the TV. This FET is 80V rated so should be OK. The LED strip voltage is 56V in this nameless panel (can't find any info on it) and it has four terminations into the TPS61199 IC.
                    Why do people buy these shitty £160 TVs? And then why do they wonder why they die?
                    Video:
                    https://www.youtube.com/watch?v=jzIf...ature=youtu.be
                    • finntricky
                      • Jan 2014
                      • 449
                      just see your video, was you a screw short when puting it back together ? did you see the screw stuck in the speaker, lol.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Just seen your yt video good stuff, the picture does look like crap but people will snatch it up becuase of its smart features lol, you sell that I would say you could get £120-£140 on that if it has stand and remote
                          LOL yeah I saw that afterwards, it isn't causing the terrible sound quality though...
                            I have both but it's not a smart set just a basic 720p LED so I'll try around £110 and see if I get any offers. You can get them new for £150 so I'm asking a lot.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Ahh right people are going crazy for these so called smart tvs, the ones I have had in sold almost with in a day after repair for asking price, but £110 is a good price people will have it for that
                                I don't understand the obsession behind smart TVs. Just buy a Chromecast or other smart TV box. The TV should be dumb, just good at displaying a picture. Keep the TV for as long as the picture quality is good, and upgrade the smart box/stick as necessary if you require better features.
                                A friend recently bought a smart TV (a crap Vestel one at that) because the guy at the store said he needed it to work with a Chromecast. Not sure if genuinely stupid or deliberately dishonest.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Its because people simply dont understand and see the words smart and led and fall for the trap of modern life tech that really isn't remarkable a all.
                                  • finntricky
                                    • Jan 2014
                                    • 449
                                    TOM, i wish you luck asking £110, all my 32's i try and knock out at around £70 to £80, depends what make, but never get what im asking, but as long as i can make £25 or more im happy,
                                      I expect £100 tbh. I can still sell Samsung 32" for £120 even if 5 years old. But I sell with a warranty which might help.
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Why do you doubt that he cant get £110 its an ultra slim led tv people as I said before snatch them up, I bet that he can get over £100
                                        I normally sell fully working 32" ranging from £80 lowest to £130 highest no offers.
                                        • lepak06
                                          TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                          by lepak06
                                          Hello
                                          I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                          The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                          Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                          All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                          But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                          01-12-2023, 01:43 AM
                                        • toty79
                                          Hisense LTDN50K220WSEU stuck in standby
                                          by toty79
                                          Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                          As per Hisense tv title LTDN50K220WSEU stuck in standby
                                          PSU rsag.820.5687 HLL 4855WF
                                          Main rsag 7.820.5842
                                          I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                          05-01-2022, 04:39 PM
                                        • lego1234567
                                          LG 32LB1R - stuck in standby mode
                                          by lego1234567
                                          Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                          What could be the problem ? Thanks...
                                          01-21-2024, 03:39 AM
                                        • Stunt
                                          Hp Laptop Stuck on Hp protected by hp sure start screen
                                          by Stunt
                                          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                          screen that's it and stuck there. I left it until the following day and i still...
                                          09-02-2025, 01:51 PM
                                        • Rusenga
                                          Samsung UA39EH5003R Stuck on standby
                                          by Rusenga
                                          Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                          Connector CNM803:
                                          TV ON
                                          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                          TV OFF
                                          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                          09-18-2021, 11:51 AM
