32PFL3606 Fuse blow invert mosfet shorted
  • rpater
    • Jan 2015
    • 26
    • Nederland
    Problem with Philips LCD, fuse is out and one of the inverter mosfets is shorted.
    Is this a case of poor power supply design allowing the fet to fail do to use of the lcd or is more that I have to check?
    Type fet this http://pdf1.alldatasheet.com/datashe...D...F8N60.html
    Re: 32PFL3606 Fuse blow invert mosfet shorted
    The board looks a little brown under the inverter transformer, should remove and inspect the transformer, this can be due to worn out lamps or just worn out or under rated transformer.
    • rpater
      • Jan 2015
      • 26
      • Nederland
      Mosfets are replaced and fuse is ok now, only the back-lights will not lights up.
      There is no 12v and 24v is come on and dropping to 0v, S/B is make just one swing to 3,3v. 5v standby is steady, ENA pin is also makes just one swing to 3,3v and the bake to 0v. So i think the PSU is turned in a protection.
      I have removed the UBA ic no luck all is stay the same, also look for short on the main-pcb and disconnected the 12v and 24v no luck also. So I running out of option, maybe there is some one that can give me the golden tip.
      • CapLeaker
        Leaking Member
        • 8212
        If the mosfet blows, usually there is more shorted or bad. Check the gate resistors etc, maybe IC801 is bad.
        • rpater
          • Jan 2015
          • 26
          • Nederland
          Gate resistor is replaced for a new one, IC801 is not sorted. Because when i remove IC801 the 12v and 24v are doing just the same.
          • CapLeaker
            Leaking Member
            • 8212
            Does the PFC work? In other words, do you get more than 360v on the main filter cap? Does it come up at all?
            • rpater
              • Jan 2015
              • 26
              • Nederland
              Yes 313V, but on the vcc pin from the FAN6991 is there only 0.3V also on the vcc of the NCP1271D65R2G
              • CapLeaker
                Leaking Member
                • 8212
                So the PFC isn't working then. If the PFC works there should be more than 360V on the 450V filter cap. 300 and some change won't cut it. Also I think Vdd-S is missing or pulled to GND. That is on 3 IC's. See what you get at Q806 and the Zener ZD801. Read the VDD pin on IC801. Check ZD909 and Q903 for piece of mind.
                • rpater
                  • Jan 2015
                  • 26
                  • Nederland
                  Q806
                  B = 0.38V
                  C = 0.38V
                  E = 0.00V
                  ZD801
                  A = 0.00V
                  C = 0.38V
                  IC801
                  VDD PIN = 0.00V
                  ZD909 Not shorted
                  A = 0.00V
                  C = 0.38V
                  Q903 Not shorted
                  B = 9.86V
                  C = 0.38V
                  E = 9.86V
                  Maybe you have so more information, thanks a lot for your support.
                    Can I get the list of the pin names of that white connector of that power supply/inverter board?
                    It sounds to me the signals from the main were present to turn on the power supply but then go away.
                    • rpater
                      • Jan 2015
                      • 26
                      • Nederland
                      Yes of course you can get them, here you go. But I have enable the supply with 5V to the ENA, and also tested with 5V to the S/B pin. Same low voltages, on the components.
                      • jetadm123
                        • 2169
                        So, if you jumper 5V to the ENA pin, the 12V and 24V output stays constant? If yes, then it sounds like the problem is in the mainboard?
                        • rpater
                          • Jan 2015
                          • 26
                          • Nederland
                          Nope if I jump the ENA the 12v and 24v is not present. And only the above values are present, ant the 5v standby of the supply is steady.
                            OK, per diagram of the connector pin out, the ENA pin is BL-ON (Backlights on) command pin.
                            The S/B pin is the PS-ON pin. And when you force on you must remove the cable for that command wire going back to the main board first otherwise you can damage the switched transistor on the main board, and always use the resistor for current limiter.
                            • rpater
                              • Jan 2015
                              • 26
                              • Nederland
                              Yes okay I will get to it tomorrow, thanks for the support so far.
                              • rpater
                                • Jan 2015
                                • 26
                                • Nederland
                                Just some things i have found the IC 801 UBA IC measured 35ohm if the IC is on the board. The strange thing when the IC is of the board the VDD en GND pin are very normal. So there have to be a short circuit behind this IC or is there possibility that the IC is short inside?
                                And the above voltage are also higher when the IC is removed, only 313v is still there sometimes it is higher but drops then, maybe this is a protections that see that the IC801 is removed. All voltage are a normal 10V on the other IC in the same circuit.
                                • rpater
                                  • Jan 2015
                                  • 26
                                  • Nederland
                                  A other strange thing is on the feedback lines of IC909 is there also a voltage of 2.0V by a disable supply and by enable supply is there 0.9V.
                                  And IC902 has a voltage of 3,6v on the FB line by a enable supply, I don't kwone of this normal, but the main cap is still 313v so PFC is not working. Can this have to do with the FB lines?
                                  Only when i unplug and plug the maincord the main cap whil give 400v and the drops to 313v.
                                    What DC Voltage do you have between the IC902 VCC (PIN 6) and GND (PIN 4) when S/B is forced on?
                                    • rpater
                                      • Jan 2015
                                      • 26
                                      • Nederland
                                      10v when s/b is foreced on and with the ic801 removed otherwise with ic801 in places is the voltages 0.8V
                                        10V is way too low for the ICs to run.
                                        Check the resistance between VCC pin and GND PIN.
                                        Some thing is loading down, it can be the IC, the zener, or bad filter caps.
                                        See the parts I circled.
                                        • Nooy
                                          VGA MOSfet permanently shorted and loss of MOSfet pad
                                          by Nooy
                                          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                          02-14-2024, 02:26 AM
                                        • chestercc
                                          Alienware M18x Shorted CPU Mosfet
                                          by chestercc
                                          I've got an old Alienware M18x R1 which shorted out the charger whenever it was connected. Tracked down the short to two shorted caps and burned CPU power controller caused by a shorted mosfet on the CPU's graphic power supply.
                                          I've replaced the faulty mosfet, two shorted caps and the CPU Power controller (NCP6151S52MNR2G).
                                          Issue is now whilst there is no short if I attempt to power the system on the fans spin for a couple seconds there are no lights and no further action - the PCH is heating up but there is no CPU power coming out but there is an enable signal...
                                          07-16-2022, 06:05 AM
                                        • socketa
                                          Bestec ATX0300F5WA - fast,or slow blow, fuse?
                                          by socketa
                                          I bought a dead motherboard, and connected it to this PSU,
                                          Was checking the standby voltages on the motherboard, and, whilst doing so, the PSU made a loud bang with a flash of light.
                                          So now i truly got a bang for my bucks, and something else to try and fix.
                                          The fuse was blowen, and the top was blowen off of a TNY276PN chip
                                          The glass fuse didn't have any marking to say if it was fast or slow blow
                                          So i checked the marking on the PCB thinking that that would tell me,
                                          but it 's got a T/F8A printed on the board
                                          So should i get a fast blow fuse, or should...
                                          05-17-2022, 01:22 AM
                                        • daemon123
                                          MSI GTX-980ti shorted MOSFET on memory rail
                                          by daemon123
                                          Hi All,
                                          I have this MSI GTX-980ti Gaming Golden Edition. It had shorted mosfet on memory. Replaced the shorted i.e. Q47 PK616BA with 4C09N and the card ran fine for a month. Then suddenly again the same problem. This time when i replace it 4C09N or with replacement PK616BA (Aliexpress) it gets shorted. As soon as turn on the PC the PSU shuts down and the same mosfet Q47 gets short.
                                          What should be the next step. Kindly guide.
                                          The board view files for this gpu is available and attached. https://www.badcaps.net/forum/showthread.php?p=1237952...
                                          05-10-2023, 11:05 AM
                                        • Jane
                                          How do you test MOSFET in laptops ?
                                          by Jane
                                          I tried to use this method:
                                          Testing an N-channel MOSFET:
                                          Step 1: Discharge the Gate (turn off the MOSFET)
                                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                          Step 2: Charge the Gate (turn on the MOSFET)
                                          Now, place the red probe on the Gate (G) and the black probe on the
                                          09-27-2024, 03:31 AM
