32PFL3606 Fuse blow invert mosfet shorted
  • rpater
    • Jan 2015
    • 26
    • Nederland
    Re: 32PFL3606 Fuse blow invert mosfet shorted
    I will check it tomorrow thanks for the help.
    • CapLeaker
      Leaking Member
      • 8214
      Originally posted by rpater
      10v when s/b is foreced on and with the ic801 removed otherwise with ic801 in places is the voltages 0.8V
      shorted all right... no wonder nothing goes.
      • rpater
        • Jan 2015
        • 26
        • Nederland
        What has to be the DC voltage for this IC.
        • rpater
          • Jan 2015
          • 26
          • Nederland
          Stil no luck, whit every IC and other thing removed om the VCC line still only 11,70V So i have gain 1,70V not eghough i think. So I think the supply is still in protection.
          I have pull the S/B with 5V from his on standby because this is working just fine. There is 1k resistor in between. On the VCC line for the IC there is also no short.
          So I think I am in a circle, and I have no clue to get out of this circle. Please take a look at the pictures I have in this state only 11,70V on the supply line for the IC.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Why not Look Up on Google--That chip, and see whats the min and max VCC it is designed to run at!
            IF there's supposed to be 12V and you have only 11V then it should still run correctly. Many of these chips will run from say 10V to 25V VCC....
            A Volt or two Low VCC on one of these inverter chips isn't always a problem....
            TELEFIX
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              #26
              From the PDF of the chip--
              This is the positive supply of the device. The operating range is between 10 V (min) and
              20 V (max) with a UVLO start threshold 12.6 V (typ).
              TELEFIX
              • rpater
                • Jan 2015
                • 26
                • Nederland
                #27
                I think i have found the problem I think the IC801 (UBA2071AT) is damaged inside, therefor the supply won't start. Because when i solder the pins 9,10,14,15 to the PCB the resistances between VDD en GND of this IC drops to 44.5ohm.
                When I lift this pins the resistances between VDD and GND of the IC is 1K, and when I power up the supply the voltage drops to 6V on the VDD line so i think the IC is a big damaged inside. Can any one please confirm my thought, because this is not a easy IC to get.
                  The startup Voltage has to reach first, 12.6V, once it is running then the running Voltage range can be as low as 10V.
                  • rpater
                    • Jan 2015
                    • 26
                    • Nederland
                    #29
                    Still no luck just received and replaced the UBA IC, still only 9,6V on the supply line.
                    Just discovered something other strange thing, the marked resistor in the attached picture are measure in circuit 0ohm and of the pcb just 27ohm.
                    • rpater
                      • Jan 2015
                      • 26
                      • Nederland
                      #30
                      How is the Vdd-s made on the supply?
                        That is because the resistor is connected in parallel with the transformer winding which has DCR of <1 Ohm.
                          See the arrows.
                          https://www.badcaps.net/forum/attach...8&d=1427488949
                          • rpater
                            • Jan 2015
                            • 26
                            • Nederland
                            #33
                            Okay thanks for the support budm but I don't get the treshold of 12,6V, and i don't know why look at the pictures this what I get on the Vdd-s line.
                            • rpater
                              • Jan 2015
                              • 26
                              • Nederland
                              #34
                              A other strange thing there are components on the supply that is standing in schematic as NC please see picture.
                                NC = not installed on the board, the schematic covers more than one version of the PCBA (Printed Circuit Board Assembly), the blank circuit board can be used in more than one PCBA, they just stuff the board with needed parts for the particular model of the TV as needed.
                                This makes it confusing because you need to see if the version of the PCBA you have has those parts installed or not.
                                • siviigi
                                  • Sep 2019
                                  • Bosnia & Herzegovina
                                  #36
                                  Hello people
                                  Did you solve the problem. I have absolutely the same problem?
                                  Any solution found?
                                  Sivi
                                  • Nooy
                                    VGA MOSfet permanently shorted and loss of MOSfet pad
                                    by Nooy
                                    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                    02-14-2024, 02:26 AM
                                  • chestercc
                                    Alienware M18x Shorted CPU Mosfet
                                    by chestercc
                                    I've got an old Alienware M18x R1 which shorted out the charger whenever it was connected. Tracked down the short to two shorted caps and burned CPU power controller caused by a shorted mosfet on the CPU's graphic power supply.
                                    I've replaced the faulty mosfet, two shorted caps and the CPU Power controller (NCP6151S52MNR2G).
                                    Issue is now whilst there is no short if I attempt to power the system on the fans spin for a couple seconds there are no lights and no further action - the PCH is heating up but there is no CPU power coming out but there is an enable signal...
                                    07-16-2022, 06:05 AM
                                  • socketa
                                    Bestec ATX0300F5WA - fast,or slow blow, fuse?
                                    by socketa
                                    I bought a dead motherboard, and connected it to this PSU,
                                    Was checking the standby voltages on the motherboard, and, whilst doing so, the PSU made a loud bang with a flash of light.
                                    So now i truly got a bang for my bucks, and something else to try and fix.
                                    The fuse was blowen, and the top was blowen off of a TNY276PN chip
                                    The glass fuse didn't have any marking to say if it was fast or slow blow
                                    So i checked the marking on the PCB thinking that that would tell me,
                                    but it 's got a T/F8A printed on the board
                                    So should i get a fast blow fuse, or should...
                                    05-17-2022, 01:22 AM
                                  • daemon123
                                    MSI GTX-980ti shorted MOSFET on memory rail
                                    by daemon123
                                    Hi All,
                                    I have this MSI GTX-980ti Gaming Golden Edition. It had shorted mosfet on memory. Replaced the shorted i.e. Q47 PK616BA with 4C09N and the card ran fine for a month. Then suddenly again the same problem. This time when i replace it 4C09N or with replacement PK616BA (Aliexpress) it gets shorted. As soon as turn on the PC the PSU shuts down and the same mosfet Q47 gets short.
                                    What should be the next step. Kindly guide.
                                    The board view files for this gpu is available and attached. https://www.badcaps.net/forum/showthread.php?p=1237952...
                                    05-10-2023, 11:05 AM
                                  • Jane
                                    How do you test MOSFET in laptops ?
                                    by Jane
                                    I tried to use this method:
                                    Testing an N-channel MOSFET:
                                    Step 1: Discharge the Gate (turn off the MOSFET)
                                    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                    Step 2: Charge the Gate (turn on the MOSFET)
                                    Now, place the red probe on the Gate (G) and the black probe on the
                                    09-27-2024, 03:31 AM
