Sanyo DP26648 Only Backlight
  • CraigR
    • Dec 2013
    • 959
    I have a Sony DP26648 that works with the remote and power button on the side and turns on but only the backlight. I don't get any video or the menu or vol up/down graphic just the backlight only. Has anyone run into this?
  • nuala
    • Aug 2013
    • 37
    Re: Sanyo DP26648 Only Backlight
    Replace ribbon cable connecting panel to the t-con board # n6ce ffc. Common problem with this set.
    • CraigR
      • Dec 2013
      • 959
      Is there anyplace to get new ones? I can't located any used.
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • DanPoka
        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
        by DanPoka
        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
        02-15-2025, 05:05 AM
      • Comp_Pro
        No Backlight Macbook A1990 820-01041
        by Comp_Pro
        Hello all,
        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
        Tests performed:
        There is no backlight even with a good screen.
        Backlight IC is receiving the correct support voltages.
        Fuse F8400 ok
        Current sense resistor R8400 ok
        Backlight IC is receiving 3.3V on enable pin.
        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
        Backlight IC receiving 5V from PP5V_G3S
        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
        05-06-2024, 10:23 PM
      • cheebster
        iPad Pro 12.9 5th Gen Backlight Issue
        by cheebster
        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
        Anyone...
        05-20-2025, 09:17 AM
      • canadaboy25
        LG Flatron 24EN33TA No Backlight When Cold
        by canadaboy25
        I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
        I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
        03-07-2023, 12:23 AM
