Does unplugging half the T-Con really prove bad panel?
  • Truncatedhose
    • Oct 2014
    • 343
    In general, when you have an LCD with backlight but no video and you can unplug half the T-CON going into the panel and then you get that SAME HALF of the screen that you just unplugged in white with black smeary shadow creeping away from the center of the screen and the other half of the screen is still just blank, what does this really prove? It does the same thing with either half of the T-CON unplugged. Does this mean a bad panel? I thought it would show video on the opposite half that you unplug...? But it's still just blank. I don't want to jump to a bad panel conclusion without certainty. This is on an LG37LG50, by the way. Will provide pictures if you want, but my question really applies to this same scenario that I've seen on many models with same symptoms.
    Help! Thanks!
  • Truncatedhose
    • Oct 2014
    • 343
    Re: Does unplugging half the T-Con really prove bad panel?
    Bump
      If you get half a good picture with one half unplugged usually it means there is a short on one side of the panel (i.e. bad panel.)
      If you get a distorted image, it's hard to tell, as sometimes you could be missing some signals by removing that connector.
        Originally posted by tom66
        if you get half a good picture with one half unplugged usually it means there is a short on one side of the panel (i.e. Bad panel.)
        if you get a distorted image, it's hard to tell, as sometimes you could be missing some signals by removing that connector.
        +1
        • freakaftr8
          • Oct 2012
          • 3743
          I would say possibly not. Its rare that a bad panel would not show anything on either side. Sounds more like a tcon issue possibly. Are you getting voltages to the tcon?
          but Tom is right on a part of his post where he mentioned that if you unplug one cable you could have an issue on the other side as well as some panels use a jumper ribbon in series between both halves of the top driver boards on the panel itself and therefore no you will not receive a proper picture on either side as they both have to coincide with each other to jive with the signal generated coming from the tcon board
          • Truncatedhose
            • Oct 2014
            • 343
            Thank you Tom and Freakaftr8. I am getting voltage to the T-Con (13.0v approx) and the fuse is GOOD, but the chips and things on the T-CON never get even warm. I agree, I think it may be the T-CON. Thank you again! I will order one and let you know!
            • Truncatedhose
              • Oct 2014
              • 343
              Well, I got one T-CON a few days ago and with it I still got the blank raster on one side, but now I had distorted, orange lines running vertically on parts of the left side. I checked my cables and connections and all was good. I sent the T-CON back for another one and with the 2nd one installed, I got the same symptom as originally: just a blank screen (backlights running, but no video). I guess either the panel is bad or it's the Main board.
              Can anyone help me solve this one? Maybe someone can tell me exactly how to scope the video signal from the Main board? I have a scope (Tektronix TDS 210), but haven't used it in a while and never was the expert with scopes.
              Thanks!
              • Truncatedhose
                • Oct 2014
                • 343
                Someone, please? Thank you!
                  Yes, you can use a scope to check LVDS. A TDS210 is a little limited, in this respect an analog scope would be better (because the update rate and graduation on the Tek is very limited) but it might be possible to make use of it as a basic test.
                  • Truncatedhose
                    • Oct 2014
                    • 343
                    Thanks, Tom. Do you need me to take some pictures of the boards and plugs (what area specifically?) and also, could you help me make sure I have the scope set up correctly and walk me through this?
                      Yes, a picture of the LVDS connector on the board (showing traces) will help, also one of the probe and scope. I think I've used a TDS210 before but a long time ago.
                      • Truncatedhose
                        • Oct 2014
                        • 343
                        Well, good news! I had a Main board on the way for this (just in case that was the problem) and I just got it in and that fixed it! So it was the Main board after all. Thanks, Tom for being prepared to help and so kind!
                          Nice to hear. You can use this as a learning opportunity to check the LVDS signals with your scope as you know the main board is working.
                          • Truncatedhose
                            • Oct 2014
                            • 343
                            Ahh, yes, thank you, I should have done that, but I already wrapped it all up.
                            • Fly_Among_Stars
                              VIZIO E70-E3 Half picture with half TCON
                              by Fly_Among_Stars
                              I have a VIZIO E70-E3.
                              Symptoms: Black screen, no picture, but LED backlights are working.
                              I probed the power board and voltages are as listed on the board.
                              Main board appears fine, too.
                              I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                              There are two separate ribbon cables feeding the LCD.
                              If both are connected, the screen is black.
                              If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                              04-24-2023, 08:20 PM
                            • advant
                              by advant
                              02-03-2020, 12:25 AM
                            • Hakuu
                              by Hakuu
                              Hi There,
                              More Details
                              TV Model - LG OLED77G1PUA
                              07-12-2023, 02:37 PM
                            • netgearnetgear
                              TCL 43S423 TCON OR PANEL FAULTY???
                              by netgearnetgear
                              Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                              Yesterday, 06:04 PM
                            • Daren87
                              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                              by Daren87
                              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                              08-13-2023, 03:25 PM
