Vizio issue
  • vbrad511
    • Feb 2015
    • 70
    Vizio issue
    Just picked up this VOJ320F1A today, in hopes of fixing it and replacing my mom's 20 year old tube set. It powers on fine, sound is good, but the picture is , for lack of a better description, washed out. I haven't opened it up yet, but was hoping somebody point me the right direction to look towards for when I do tomorrow.
    Thanks..
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Vizio issue
    Check the gamma voltages on the T-con.
    • vbrad511
      • Feb 2015
      • 70
      Re: Vizio issue
      There's no visible t-con board on the tv. The main board is under the metal shroud, and there is a connector with several wires running underneath it, into the framework. Do I need to dig deeper? And if I pull it further apart how do I test it..in pieces?
      • CapLeaker
        Leaking Member
        • 8220
        Re: Vizio issue
        follow the LVDS cable...
        there is a repair kit available for this issue:
        http://www.shopjimmy.com/vizio-0940-...repair-kit.htm
          Re: Vizio issue
          The T-CON is under the big metal plate, you need to remove the metal shield for the main board first so you can disconnect the LVDS cable to the T-CON otherwise you will rip up the LVDS cable when you lift up that metal plate assembly. This chassis in not made to be repair because you cannot get to the test points on the T-CON when you gave all the boards connected together.
          http://www.shopjimmy.com/catalogsear...t/?q=VOJ320F1A
          There are more one maker of the LCD panels (looks like 4 panels) for this model, if it uses AUO T-CON, then it will be likely to have have bad AS15 Gamma cip.
          • vbrad511
            • Feb 2015
            • 70
            Re: Vizio issue
            Thanks for the links and the info...gives me a bit of hope. ALthough I'm ok with my soldering iron I'm not sure I can install that chip with all of those pins. Is there a trick to it? Would I better off buying a used board?
            • CapLeaker
              Leaking Member
              • 8220
              Re: Vizio issue
              Up to you to decide...
              • JeffJ
                • Apr 2012
                • 189
                Re: Vizio issue
                Removing and replacing a chip like that can be done by soldering iron, and i have done so. Doing that takes some experience, tools and some courage under your belt. If you lack in any of these areas, no offense. You will be much happier and more successful spending the extra $10 on the full tcon rather then the repair kit. Hell Id get the tcon for$28 bux rather then the $14 repair kit just because, well its easier and cheaper then my time mucking around.
                • vbrad511
                  • Feb 2015
                  • 70
                  Re: Vizio issue
                  Thanks Jeff, I found a seller on Ebay that's got 4 of them, and good feedback. I'll just do it that way.
                  Thanks again everybody for the time and tips.
                    Re: Vizio issue
                    So did you find out which version of the T-CON board you have in your TV before ordering the replacement?
                    • vbrad511
                      • Feb 2015
                      • 70
                      Re: Vizio issue
                      Setback. The boards I'm finding on ebay are listed for my model, but the part numbers on the boards and the pics are wrong.
                      I need
                      31T05-c02 T315HW01
                      Any other sources you can point me towards?
                      • JeffJ
                        • Apr 2012
                        • 189
                        Re: Vizio issue
                        Is this the correct board? http://www.shopjimmy.com/auo-55-31t0...-con-board.htm
                        Unfortunately its out of stick but shopjimmy lists its actual part number as AUO 55.31T05.C01
                        • vbrad511
                          • Feb 2015
                          • 70
                          Re: Vizio issue
                          Close. mine's
                          55.31T05.C02
                          Don't know if that last digit makes a difference. I found a couple international seller on ebay that have them, but they're upwards of $100. I can't justify that.
                            Re: Vizio issue
                            According to SJ, that is the correct one.
                            They are not cheap.
                            • vbrad511
                              • Feb 2015
                              • 70
                              Re: Vizio issue
                              There's an Ebayer in France that advertises a repair service for about $33. I'll sit on the set for a bit and see if somebody else posts one up on Ebay. If not, I may send it over. I'll only have about $60 in the tv at that point. Be a good for for the step-mom...
                              • Mectronik
                                Vizio m601d-a3 backlight issue
                                by Mectronik
                                Hello, I'm working on a Vizio m601d-a3 with a backlight issue that I am having a difficulty diagnosing it. As it sits, the tv powers on, displays the Vizio symbol and with nothing hooked up it will then display no signal but you can only see half of the screen. I know it's a back light issue because the picture is there without light behind it, as I can see it by doing a light test. I've taken off the paneling and done a visual inspection. If I disconnect the tcon ribbon cable to the affected side then the entire half of the screen goes away. I've checked voltages at the LED driver from the main...
                                11-05-2023, 10:20 PM
                              • EazyBone
                                Vizio P759-G1, Tcon issue?
                                by EazyBone
                                Got this TV free. Guy said it tries to turn on and doesn't. I haven't seen this specific issue before but shown in video. Any way to test the screen to rule it out on these Vizio? Or anyone seen this issue before?
                                Any help appreciated
                                https://youtu.be/tPeV2Q7TXIQ?feature=shared
                                03-22-2024, 03:25 PM
                              • remmurdmd
                                Vizio E65-E1 strange image issue
                                by remmurdmd
                                Hi everyone. First new thread here. I picked up a TV on the side of the road. It appears to function correctly with the exception of an image issue I'm unable to describe. I've searched for “double picture” and “double image” all over the web and all I get is repair videos for when the picture is blurry and the connections are getting interference between the display panels and the t-con board. I believe this is a t-con board issue, but I haven't found anything telling me conclusively that this is where my issue is. I'd appreciate any assistance you can provide. I live a pretty busy life...
                                10-02-2022, 09:12 PM
                              • derrickcaputo
                                Issue with 42 Vizio TV
                                by derrickcaputo
                                I have a 42" Vizio TV. I hooked my tablet to the HDMI inputs. Everything was fine until the screen went black and now the only input that works on the TV is coax. No hdmi, no component, no rca. I tried hooking up a laptop to the Hdmi port and the computer
                                detected the TV model but no image.
                                Is there anyone having the same issue? Did you find any solution?
                                08-20-2024, 12:21 AM
                              • bscottjohnston
                                Interesting E60-E3 (Vizio) issue
                                by bscottjohnston
                                Good morning BadCappers,
                                I picked up a Vizio E60-E3 yesterday. The donator claimed that it never powered on and that he checked Voltages at the power supply. I checked a handful of Voltages and then laughed when I realized I was trying to turn it on via the menu button on the back of the TV when its upside down on my TV repair bed (literally my guest bedroom).
                                Okay so I took out the mainboard and decided to flux up the BGA and heat it up. Upon reinstall of the mainboard the TV does indeed power up but all of the screens have a blue hue AND the video displayed fails...
                                08-31-2023, 07:41 AM
