Interesting E60-E3 (Vizio) issue
  • bscottjohnston
    • Aug 2023
    • 52
    Good morning BadCappers,
    I picked up a Vizio E60-E3 yesterday. The donator claimed that it never powered on and that he checked Voltages at the power supply. I checked a handful of Voltages and then laughed when I realized I was trying to turn it on via the menu button on the back of the TV when its upside down on my TV repair bed (literally my guest bedroom).
    Okay so I took out the mainboard and decided to flux up the BGA and heat it up. Upon reinstall of the mainboard the TV does indeed power up but all of the screens have a blue hue AND the video displayed fails about 10 seconds after it starts displaying on all of the HDMI ports I tried. If I don't place a video source on HDMI then it will sit there in menu for quite a while. The remote it came with is super lame as it doesn't have most of the buttons (seemed odd). So, waiting on a real replacement from Amazon today.
    Anyone seen this issue before? Can I go into service mode and do some sort of full reset? Does this sound like a heat issue? I did put brand new paste on the sink. Maybe I'll try a small cooling fan from USB...
    Thoughts from the experts who like to reply to these threads?
    TIA
  • nomoresonys
    • 12330
    • U.S.
    Re: Interesting E60-E3 (Vizio) issue
    When you see the backlights thru the little holes from the back, do any look blue instead of white?
    • bscottjohnston
      • Aug 2023
      • 52
      Yes - they do look blue. That fact hadn't occurred to me... Not sure why that would be other than a powering problem with the strips.
      UGH - a quick web search for Vizio blue LEDs yields a bunch of sites talking about bad LED strips. At this stage with the odd shutdown problem I'm not sure if this TV is worth investing any time in. The strips are CHEAP on eBay but not sure about the mainboard problem.
      • nomoresonys
        • 12330
        • U.S.
        Can you hook it up to rca or just a tv antenna and see if it works ok that way?
        • bscottjohnston
          • Aug 2023
          • 52
          Once i get my new remote that actually has a menu button I can...
          • nomoresonys
            • 12330
            • U.S.
            Wonder if a universal remote would work.
            • bscottjohnston
              • Aug 2023
              • 52
              I don't have one anymore. For $6 it was worth a gamble on Amazon. Besides I still have that 70" I fixed last month that I don't have a remote for. I mean I have Comcast remotes for power-on and volume but I do need one for menus etc...
              • bscottjohnston
                • Aug 2023
                • 52
                So, with the new remote in hand I made a discovery. The mainboard has some sort of thermal limit. Even though I put new paste on the heat sink after I cooked the BGA last night, it still doesn't cool enough to stay on. With a house fan on high hitting the back directly it stays on for as long as the fan is running. Fan off, it fails in about 3-4 minutes. Going to look at active cooling unless anyone else has any suggestions?
                LED strips are still blue but I'm not buying/doing the LEDs until I can get the TV to stay on for 12 hours at a time.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  I'm guessing your "flux up the BGA and heat it up" reflow was not very good.
                  • bscottjohnston
                    • Aug 2023
                    • 52
                    Pretty sure you're right. I've done it before and it worked perfectly. This time not so much. Waiting to see if I can get a board for a decent price on eBay but have lots of other real-life things to do until then.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      A cheap thermometer with probe is less than $10, I'd get one and give the reflow another try.
                      • bscottjohnston
                        • Aug 2023
                        • 52
                        Can the solder under the BGA survive three cookings? I apply flux each time around the edges. I have cleaned it from the outside but have not been able to clean it underneath of course.
                        If I did buy the thermometer where would I be focusing?
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          You put the thermometer probe tip as close to the IC with the BGA as possible.
                          There is no cooking, you are melting solder balls, i suspect it's not been hot enough for long enough but your thermometer should help you with that.
                          • Nairolf
                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                            by Nairolf
                            I have a Samsung DM32D display.
                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                            Here’s what I have tried so far:
                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                            08-24-2025, 03:47 AM
                          • Devonavar
                            Vizio M43-C1 - How closely do I need to match the mainboard number?
                            by Devonavar
                            I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                            I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                            Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                            So, I've ruled out the PSU for now.
                            The reboot loop...
                            08-14-2022, 08:46 PM
                          • harshana
                            DA0ZPVMBAD0 rev d Mainboard - blank screen issue
                            by harshana
                            I have the DA0ZPVMBAD0 rev d logic board and it doesn't boot up. I see all the voltages are okay. So I suspect the issue is bios.
                            When I power on with fn+ esc the blue light start blinking on mainboard.
                            I guess its a good sign. As all the voltages are okay and also charging indicates orange light when battery connected, I think it confirm that the EC bios is okay. So I ignored the ec and flashed main bios with 32mb bin file provided in the link below. But the condition is same.
                            https://www.badcaps.net/forum/troubl...and-electronic...
                            08-16-2025, 02:16 PM
                          • Mectronik
                            Vizio m601d-a3 backlight issue
                            by Mectronik
                            Hello, I'm working on a Vizio m601d-a3 with a backlight issue that I am having a difficulty diagnosing it. As it sits, the tv powers on, displays the Vizio symbol and with nothing hooked up it will then display no signal but you can only see half of the screen. I know it's a back light issue because the picture is there without light behind it, as I can see it by doing a light test. I've taken off the paneling and done a visual inspection. If I disconnect the tcon ribbon cable to the affected side then the entire half of the screen goes away. I've checked voltages at the LED driver from the main...
                            11-05-2023, 10:20 PM
                          • maricm
                            Vizio P65 with P55 mainboard
                            by maricm
                            IH all, Got this vizio tv P65-E1 from FB marketplace hoping to be able to reflow mainboard as selerrstated that it was diagnosed with bad mainboard. However they must have tried to repair tv by putting another board in and they put P55 board in .
                            Tv starts and responds to remote but screen does not look right , It looks like low resolution with some image ghosting. Now not having original board I dont know what to order ? Any advice how to figure out what exact board fits this tv ?
                            And another question Would it be possible to adopt this board to this tiv by chagning eeprom or tcon...
                            04-23-2024, 08:25 AM
