STB3.3v = 0.4V on Panasonic p42v10
  • rvanpruissen
    replied
    Re: STB3.3v = 0.4V on Panasonic p42v10
    "Fires up" indeed, sorry habit from laptop repairs This was indeed a recycled board from a seller who claims it's working. Maybe it isn't...
  • tw2005
    replied
    Originally posted by rvanpruissen
    Hey guys, in the meantime I've bought a new signal board. Unfortunately it still doesn't work, but some things have changed. Now when I turn on the TV I hear the relays clicking and the backlight turns on. However, theres nothing on the screen (no OSD), I have 13 blinks and the TV shuts itself down.
    I've had some time to cool down and gather some courage to start over again. Any ideas where to start? Cheers. Rick.
    13 blinks sounds like another bad A board. New board or recycled/ might be better to send back
    So the panel fires up? it's plasma so no backlight.
  • rvanpruissen
    replied
  • Agent24
    replied
    There are some good video tutorials on the internet. Hot air is the easiest way if you have the tools and don't want to destroy the IC. Chipquick is also quite good.
    Without either you can cut the leads off with a knife, clean the pads with iron and wick, but then the IC is done. That method is only good when the IC is known bad and you are replacing it.
  • rvanpruissen
    replied
    Thanks guys. I might try removing the IC in the weekend. I guess the worst that could happen is that I gain some experience in removing IC's
  • CapLeaker
    replied
    I guess you went as far as you can go, unless you have a very sensitive Ohm meter or a Leakseeker 89. You could cut the little traces of interest and find out that way if the short disappears. However since it seems the IVDD pins are shorted to GND, this is a lost cause and either the chip or the board needs to be replaced.
  • Agent24
    replied
    I don't think there is anywhere else to check. If the problem is between L1100 and IC1100 and you have disconnected the capacitors it is very likely IC1100 showing that 4.2 Ohms.
    It seems it's just a microcontroller, so as far as I can tell there should be no low resistance paths between its power pins and anything else, it's not like it's doing any heavy current switching or anything.
    It seems odd that a microcontroller would go shorted, so it's also possible the PCB itself has the short (can happen if there's been physical damage), or there's a solder ball under the IC or such.
    If you have the tools (hot air etc) and can remove that IC, check for solder balls\bridges\whiskers. See if that 4.2 Ohms is still on the IC out of circuit. See if it's still on the board with the IC removed.
    If the IC seems OK out of circuit and there is no 4.2 Ohm short on the board, it may have been a solder bridge. Resolder the IC and see if it is fixed.
    Otherwise, try to find a new IC or replace the whole board I guess... unless someone else has any other clever ideas.
  • rvanpruissen
    replied
    Could the short also be on one of the 100 connection of IC1100 I didn't 'disconnect'? Or is it unlikely there's an internal connection between the 4 IVDD STB3.3V connections and the rest of the connections.
    Any suggestions on where to check next? IC1100 is indeed difficult (impossible?) to find (and replace).
  • Agent24
    replied
    If there is nothing else connected to the STB3.3V rail, you have removed all the capacitors, then logically it would point to IC1100 being bad. But you must be sure there is nothing else you have missed, because it doesn't look like that IC will be easy to get if it is bad.
  • rvanpruissen
    replied
    Ok guys. So after removing L1100 I've isolated the problem to the STB3.3V supply to IC1100, see attached image. The caps indicated in yellow are the ones I've removed so far and still there's only 4.2ohm resistance between this part of the STB3.3V line and ground.
    Any brilliant ideas for the next step or should I assume IC1100 is shorted? I'm thinking maybe the crystal's capacitors on the right, or even further down the lines coming from IC1100.
    Please help this electronics noob on his epic journey
  • rvanpruissen
    replied
    Thanks budm. A bit out of my league though I have no reason to think this diode is bad, so I'll focus on the STB3.3v line first.
    replied
    The Diode is the back to back snubber diode network to clamp down the back EMF, you cannot use Ohm mode or Diode mode to test it, you have to supply enough voltage to reach the breakdown Voltage.
    https://cdn.badcaps-static.com/pdfs/...386e62dcd7.pdf
    page 4
  • Neelix
    replied
    For D503, have a look at this thread - https://www.badcaps.net/forum/showthread.php?t=17969
  • ReeceyBurger123
    replied
    Originally posted by TVRepairNoobie
    rvanpruissen, I am a newbie (4 x TV fixed) working on a similar TV (TC-P42S1). The D503 is shorted when in circuit mine measures exactly the same. But I don't think it should be open thus, I suspect D503 might be faulty.
    Hopefully, the experts here can shine some light in this matter.
    If the diode on D503 is bad, I cannot find replacement for it anywhere. Diode has the follow label: T3D 97 or T 3D 97
    There should be more numbers like 50n60 or something similar.
  • ReeceyBurger123
    replied
    If the diode tests open both ways its shorted, desolder and test it out of circuit.
  • TVRepairNoobie
    replied
  • rvanpruissen
    replied
    Crap. Just took a look at the schematic and D503 is parallel to a transformer, so thats what I'm measuring. Any particular reason to believe it's D503 TVRepairNoobie? Otherwise I won't try to get it out of the board. Thanks again!
  • rvanpruissen
    replied
    Thanks guys! I'm baffled to see that D503 measures open both ways, using the diode tester on my multimeter. Could this be the source of the problems? Or am I doing something wrong (sorry, sometimes I'm missing some basic electronics skills )
    To fix the A-board, I think I'll go with Neelix' plan to remove L5480 first and test whether IC5480 itself is shorted to ground, or the short is somewhere in the rail. Not sure about when though, bit busy now.
    Keep em coming please!
  • TVRepairNoobie
    replied
    When A-Board is not connected, you will not be able to power on the TV. At least this is my case with TC-P42S1 model. (no LED indication at all).
  • TVRepairNoobie
    replied
    Hi rvanpruissen,
    Test D503 on the P board to see if its open or closed. It is shaded green at the lower center.
  • Nagy Daniel
    Lowest possible resistance on laptop motherboard rail - Guide Table request
    by Nagy Daniel
    Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
    I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
    I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
    So, I generated a table with AI so I can...
    03-04-2025, 08:24 AM
  • jaroslav.psenicka
    Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
    by jaroslav.psenicka
    I have a Lenovo Yoga 13 Panasonic here, when powered
    • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
    • most voltage rails seem OK (see image below, red labels)
    • resistnace to ground mostly seem OK as well (blue labels)
    the only suspicious is the 0.0V rail (2nd from left, top row)
    • the resistance to ground is rather low (1.9ohm)
    • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
    also tried new BIOS, no change
    I can't find a schematics for the board - can some of you gurus look at the voltages?...
    05-02-2024, 05:59 AM
  • Victor Moreira Silva
    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
    by Victor Moreira Silva
    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
    Well, my decice specs are the following:
    Model: Acer Nitro 5 AN517-54-55T5
    CPU: Intel Core i5-11400H
    GPU: NVIDIA GeForce GTX 1650
    Motherboard: GH51G LA-L181P Rev:1c
    The symptom:
    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
    05-26-2025, 10:49 AM
  • lefetylorant
    Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
    by lefetylorant
    Hello Everyone,
    Long story short, I got this unit for very cheap.
    I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
    I've performed some measurements:
    - 20V rail perfectly...
    09-14-2023, 05:05 AM
  • bimole
    Weird behavior on 3.3V rail of a CORSAIR CX600
    by bimole
    A colleague gave me an apparently ill CORSAIR CX600.
    He told me that he heard a banging noise, and smelt the magic smoke.
    After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
    I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
    It's another story on the 3.3V rail...
    I have some devices to test deeply PSUs (scope, AC source, electronic load)...
    02-13-2025, 04:49 AM
