My problem is no picture no sound, after reading several different threads it appears that this is a common problem usually caused by a faulty voltage regulator, U33. However, the U33 on mine appears to be an amplifier of some sort, this is my guess since it's an 8 peg. Could someone tell me what the equivalent to U33 would be on mine? If needed I can try to post some pics of my main board tomorrow.
Vizio VW46L FHDTV20A
Re: Vizio VW46L FHDTV20A
"If needed I can try to post some pics of my main board tomorrow." Definitely the minimum requirement.
http://www.shopjimmy.com/catalogsear...VW46L+FHDTV20A
Which one is your main board? There are more than one version.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Sorry it took so long to respond, work has been hectic. I couldn't get a good picture with my phone but this is it.
http://www.shopjimmy.com/vizio-3646-...6lfhdtv20a.htmComment
What are the numbers on the IC? That looks like it could be a DC/DC converter.
You really need to check PSU first to make sure all voltages are working before suspecting mainboard.Comment
You need to start at the power supply board first by finding out if it has good STBY Voltage, then find out if you do have PS-ON command signal from the main board to run on the main power supply section.
If you do have PS-ON, then find out if the DCV on the main cap is >360VDC (if the power supply has PFC Voltage booster circuit).Never stop learning
Assuming...7 Photos -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... -
by howardc64Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot.... - Loading...
