Bush (Vestel) led40127fhdcntd - turns off and on repeatedly
  • tn245
    • Oct 2013
    • 530
    Re: Bush (Vestel) led40127fhdcntd - turns off and on repeatedly
    Stj, thanks for getting involved. Regulators was one of my first thoughts. Have tested the ones I could spot and they seem to be ok. I will give it another look though.
      • 31285
      solder a few wires onto points for 3v3 and 1v8 and bring them out to your meter(s)
      then see what happens when it resets.
      • tn245
        • Oct 2013
        • 530
        Both of them drop to 0V pretty much instantly after the screen goes off, then come back up when it turns back on, though 1.8V starts at 3.2V then drops down to 1.8 after a few secs.
          Are you sure about 3.2V? Your meter may be overshooting - try locking it in the closest range instead of using autoranging.
          • tn245
            • Oct 2013
            • 530
            tom66 You mean the 3.2V dropping to 1.8V? Yes I'm sure. That's the pin that connects to the brightness control pin of the LED driver ic. There is a change in backlight brightness when it drops. Have checked it with two different meters and not on autoranging.
              Thought you were talking about the main board voltage regulators then.
                • 31285
                yes, i meant tapping the outputs from the regulators on the mainboard.
                or tapping power at the ram or cpu or eeprom - look for a ceramic cap nearby for an easy solder point.
                • tn245
                  • Oct 2013
                  • 530
                  Yes of course, I've got you.
                  There are three regulators in the attached pic. I have looked them up on the schematic for 17mb95s-2.
                  U5 (2v5_vcc) is giving 0V in standby and a constant 2.49V when cycling.
                  U9 (5v_STBY) is giving 5.45V output in standby and when cycling on and off.
                  U21 (3v3_STBY) is giving a constant 3.3V in all states.
                  I haven't found any reg for 1v8. On the schematic U14 is drawn outputting 1v8_vcc_tuner but U14 is not installed on this board.
                  Is U9 ok at 5.45V or is that a little high?
                    • 31285
                    sounds high to me.
                    • tn245
                      • Oct 2013
                      • 530
                      Actually according to the datasheet for the 54528 regulator the output should be 5.5V so I think the regulators check out ok.
                      https://cdn.badcaps-static.com/pdfs/...00675324b1.pdf
                      Going to try the firmware route I guess.
                        Output voltage will vary depending on the feed-back resistors. Can be anything. 5.5V may be too high.
                        • tn245
                          • Oct 2013
                          • 530
                          Sorry, I was measuring the wrong pin of U9. Was probing the VREG5 pin which should be 5.5V. Still not too good at reading datasheets obviously.
                          So the correct reading of 5V_STBY/5V_VCC is 5.22V. That is the output of U9 regulator circuit as measured at the input pin of U21.
                            • 31285
                            well i'd prefer it to be 5.1 or under, but i'm not sure 5.22 is going to be a problem - atleast not in the short term.
                              5.2V is within tolerance for a 5V rail, up to about 5.25-5.3V would generally be OK.
                              • tn245
                                • Oct 2013
                                • 530
                                So the plan to flash the SPI chip with Toshiba firmware has hit a snag. The chip is 16Mbit, but the .bin files from similar Toshiba models range from about 60MB to over 100MB - way too large to program onto the chip. I pulled just over 2MB of data from the existing chip. What is with all the extra data in the Toshiba .bin files?
                                  16Mbit is tiny. Are you sure you are using the right flash? The 16Mbit is probably the mboot, bootloader. The main system code will fit on a bigger, separate chip. Usually a large NAND or eMMC managed NAND device. Looks like the "SKhynix" device is the NAND, the bootloader is on the small 8 pin chip.
                                  mboot is more or less common for all models in MB95 so you just need to find MB95 bootloader.
                                  Note, if mboot is bad the TV will usually act dead or flash LED only.
                                  If main flash is bad, TV may actually power on and do something (it could also flash the LED, depends where it's corrupted)
                                  • tn245
                                    • Oct 2013
                                    • 530
                                    Ah.. yet again this forum makes me feel like an idiot.
                                    I was evidently using the bootloader flash chip. There is a H27U2G8F2CTR nand ic which must then be the system code flash. Looks like I need a more serious piece of kit to flash that one so I will probably have to look out for a replacement main board I guess.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      #38
                                      Lol they are very hard to find and you have to match all the bar code numbers.
                                        • 31285
                                        the bootloader should be able to reflash the main chip from usb / serial port.
                                        the vestel serial port is interesting, it runs a shell at 115,000baud if i remember right.
                                        • tn245
                                          • Oct 2013
                                          • 530
                                          stj, interesting. Do you know how I can get it to do that?
                                          • FlailingEngineer
                                            Help with Bush Tv (Vestel 17mb95m Mainboard)
                                            by FlailingEngineer
                                            Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                            Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                            05-31-2023, 06:52 AM
                                          • Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                            by Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                            03-15-2024, 09:37 AM
                                          • Jaime Morillo
                                            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                            by Jaime Morillo
                                            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                            The TV was stuck on the logo and I couldn't access the update menu.
                                            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                            The image result was good, but the image is inverted.
                                            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                            08-18-2025, 11:38 AM
                                          • www
                                            LG L192WS-BN backlight turns off after 1 second
                                            by www
                                            I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                            I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                            03-24-2024, 05:26 PM
                                          • Chrissygizmo
                                            Bush led40127fhdcntd possile firmware issue?
                                            by Chrissygizmo
                                            I've picked up a bush led40127fhdcntd & the standby led is constantly flashing .. It flashes around 10 seconds then the backlights come on with a blank screen, led continues to flash for about 20 - 30 seconds & then the backlights go off , this is a continuous cycle..
                                            I will upload photos of the mb ,...
                                            11-03-2021, 08:28 PM
