Im buying a busted panel Sony Bravia KDL-32S5100 And have a Sony bravia KDL-32L5000 panel are they compatible? Help please?
Is a Sony bravia KDL-32L5000 panel compatible with KDL-32s5100?
Tags: None
Re: Is a Sony bravia KDL-32L5000 panel compatible with KDL-32s5100?
According to SJ:
32S5100 uses this panel:
http://www.shopjimmy.com/sony-a-1727...dl-32s5100.htm
32L5000:
http://www.shopjimmy.com/sony-1-857-322-31-a-board.htm
Best thing to do is to actually look at the both units and get the spec sheets of both panels for verification.Last edited by budm; 02-19-2015, 09:32 PM.Never stop learning
by guidodroidHello all,
I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
The issue is not as bad as others that I've seen around, but is indeed noticeable... -
by m4a2t0tAfter changing out the backlights I have a single green vertical line on the left side of the screen. Is there any way to fix it? I tried putting pressure on all the tabs and on the top of the panel but neither helped.
Does Sony epoxy all their panels or just the expensive ones?1 Photo -
by swrb898What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
Problem:
Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
My troubleshooting got me this far:
With the left-hand TCON to bottom-board ribbon cable... -
by PopsCapsI have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
I do not hear any sound and I cannot see any backlight.
I have tried disconnecting every cable on each board one at a time to see if anything changes.
The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
My friend ordered another used power supply board but it is also doing the red indicator flash 3 times... -
by r3vsEngIT65x900h with the panel from a 65x930d.
900H: model yr 2020, Samsung panel
930D: model yr 2016, Innolux panel
spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...07-11-2023, 11:11 AM - Loading...
