Panasonic TC-P55VT30 7 Blink Troubleshoot log!
  • Shinju
    • Mar 2014
    • 1239
    Hey all!
    I was able to get a readyy nice deal from a private party on this VT30. I am stoked to see this get back up and running. I got everything for it including the breakaway inputs for Composite and Component ect, 3D glasses and Wifi USB Dongle.
    Anyway, the seller told me he was watching the Superbowl and right as the Seahawks were at the infamous 1yrd line he said the TV did a BZZZZZ POP and that was that. (True Story, even the TV knew the bad play that netted an interception was coming!)
    Fast forward, I picked it up and he told me Geek Squad told him it needed a new SC board due to 7 blink and sure enough yes it does blink 7 times.
    Anyway so I got a little bit of time and broke it down to start my debug process. Holy moly this thing is THIN!
    So I disconnected the upper and lower Ydrive boards and jumped SC50 pin to see if infact the SC board was toast and sure enough 7 blink happend with the buffers disconnected.
    Next step I disconnected P2 and P11 (SC and SS power plugs) and then I disconnected plug 35 on the power supply (this feeds power to the bottom C buffer boards)
    Then I proceeded to disconnect the 3 white flat ribbon cables being fed to the mainboard.
    This test is to determine SMPS and Mainboard functionality. The TV was able to power on and the red LED stayed solid. (This is good)
    Then I took out the Upper and Lower buffers to check their stability and they did not yield any shorts ( I hear the Buffers are the weak point of these VT series panels and are quite spendy to replace and or repair)
    This panel uses all SMD IGBT's ect. And reading on others who have ruined their SC boards by trying to DIY replace them I opted to have ModusLink tackle the repair (yeah yeah i know I know).
    Also ordered the replacement screw upgrade kit from SJ!
    Anyway I will update once the repaired SC board comes back to me in a couple of weeks!
    I am looking forward to seeing the very last generation of Panasonic plasma panel up and running, this was supposed to keep up with the Kuro from what I have read on various sites.
    Re: Panasonic TC-P55VT30 7 Blink Troubleshoot log!
    VT30 is a good panel but it's 2011 generation; Panasonic's last models were the VT60 and ZT60 which actually exceeded Kuro picture quality on many levels. VT30 is an excellent set though! Would love to see this fixed, keep us updated.
    • Shinju
      • Mar 2014
      • 1239
      Right on, I must have miss understood when I read last gen. lol it was 2am!
      Yeah this is defiantly the thinnest plasma I have seen to date.
      Cool thing is, the 3D glasses worked on my TC-P42GT25 so I got to test the 3D functionality on that, Looked fantastic!
      • Shinju
        • Mar 2014
        • 1239
        I am honestly thinking of putting this in place of the UN55ES7100F upstairs.
          I would replace a Samsung LED with a Panny plasma in a heartbeat.
          • Shinju
            • Mar 2014
            • 1239
            Heh somehow I knew you would say that I almost got a deal on a working F8500 with a Power supply that was failing I almost convinced the wife to let me drop the coin on it but by the time I had her convinced the ad expired and I forgot to jot down the number.
            Before I order the screws, it seems the 55VT30 parts on SJ only sells the Screws with the SC repair kit (they will not sell them seperatly Grrr) There is a screw kit for the 55GT30 here http://www.shopjimmy.com/panasonic-x...-screw-kit.htm
            Will these work on the 55VT30?
              Should do - only concern is if there will be enough of them.
              • Shinju
                • Mar 2014
                • 1239
                Kit comes with 18, there is 7 on the SC board + the 3 that hold the SU and SD and 4 mayb3 5 on the SS.
                Eh its like 8 bucks shipped, if anything I have em for the next panel and I could always take the originals to Tacoma Screw (Nuts and Bolts place) and have them match me up with a suggestible equivalent with washer and lock washer.
                • Shinju
                  • Mar 2014
                  • 1239
                  Part was shipped today! Will be here Thursday, super excited to see this one up and running.
                  I need to lay it flat on my table and make sure I set those buffer ribbons correctly, not a lot of room to move those suckers on that bad boy.
                  • electronicsurplus
                    • Jun 2012
                    • 210
                    We have often wondered whether the suffix on a Panasonic SC was critical? Or, will they interchange?
                    We have always used only the proper suffix (ie BK, BJ, etc)
                    Has anyone ever had any luck using a different suffix?
                    Thank you
                    Aimee
                    This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
                    Help keep these from the landfills
                    • tw2005
                      • Oct 2011
                      • 6458
                      Thank you
                      Aimee
                      I think at a glance the TNPA5335 is only used on 50/55" models so probably not a lot in it. I don't think it would be too hard to compare the components on one to the other. capacitors and coils may be the only difference to match the panels.
                      Repairing the boards is another option.
                      • Shinju
                        • Mar 2014
                        • 1239
                        So I got the board in and she is up and running and looking gorgeous!
                        I would call this a complete win but I do have a question. When I ran the scrolling bar after I had it on for about 10 min I saw in the white bar at the top pink/blue and reddish looking maldischarge, it seems the longer I left the scrolling bar on it would get less and less and less and less each pass the white bar made.
                        I do not see this issue with the TV running at all, not one pixle is out of place or any maldischarge of any sorts. I have put it on a solid white screen no issues, bright pictures fast motion scenes anything to see if I cannot see this strange maldischarge at all.
                        Is the panel fine? Is the top buffer going to blow? I would be more concerned with this if I was seeing this issue while the TV is displaying a feed. This panel looks crystal clear outside of the scrolling bar. IF I let the panel play and go back to the scrolling bar the maldischarge comes back but not as bad and again the longer I let it run it goes away.
                        Super strange!
                        Oh and yes, I replaced every screw on the SC, SU, SD, SS and the SS buffer. HV screws and the new screws are tightened down super good.
                        TV is currently running the Disney WoW disc on retailers loop. Looks fantastic!
                        • Shinju
                          • Mar 2014
                          • 1239
                          Also I didn't take any voltage readings because there wasn't any sticker voltages to verify against so I've no idea what they're supposed to be.
                            Measure VSUS and see what you read. Maybe it's a little low. Can cause pink tints on white. Maybe try test patterns on full white and see if they have problems too.
                            • tw2005
                              • Oct 2011
                              • 6458
                              there is a low and High setting in the service menu you could try that but as Tom says, check vsus. There's been a few instances now that after a repair it's needed a tweak. It is preset on the P board so try that A board setting first as it will adjust it
                              • Shinju
                                • Mar 2014
                                • 1239
                                How does one enter the service menu? Never had the need to enter it on a Panasonic!
                                • Shinju
                                  • Mar 2014
                                  • 1239
                                  So I managed to find a way into the service menu holding volume down on the panel and pressing info three times.
                                  I saw that the VSUS SETTING was set to low I put it on high and I'm not playing the TV and I see no difference with the scrolling bar maldischarge I did notice when the panel is in vivid mode there is no maldischarge on scrolling bar.
                                  I ran the test patterns in both VSUS high and low and I saw no maldischarge on any pattern except scrolling bar.
                                  However in standard picture mode with CATS enabled I did see some strange shit. (Photos to come later)
                                  What exactly does VSUS high and Low do?
                                  Photo below is the solid white test screen no Maldischarge
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    It literally adjusts the vsus, listed in the schematics it tells you . On a 55vt30 204v , 209v
                                    If it displays ok under normal use , I'd not get too bothered
                                    • Shinju
                                      • Mar 2014
                                      • 1239
                                      I don't kno what to make of it. Picture looks beautiful, maybe there is a firmware issue or fix for this scrolling bar or some sort of fix.
                                      • RJARRRPCGP
                                        • Jul 2004
                                        • 6304
                                        Definitely don't look like the TC-xxxxxxxxxx models.
                                        And most of the TC-xxxxxxxxxx models are probably made in China, which is likely a sign of being cheap!
                                        Bad sign for Panasonic! And they were reportedly inferior to a Vestel!
                                        ASRock B550 PG Velocita
                                        Ryzen 9 "Vermeer" 5900X
                                        Arc A770 16 GB
                                        eVGA Supernova G3 750W
                                        Alienware AW3423DWF OLED
                                        "Β‘Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -MΓ­ mismo
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • Vebririon
                                          panasonic TX-P50V10E 6 blink led problem
                                          by Vebririon
                                          I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                          Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible β€” so please forgive any odd phrasing.
                                          I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                          05-17-2025, 10:16 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                          Having said that I come to the gist of my post on the forum as the title suggests.
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • nervx
                                          Panasonic TH-42PZ800 8-blink error mystery
                                          by nervx
                                          Years ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
                                          Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a...
                                          04-08-2022, 05:19 AM
                                        • SentraDude
                                          (Another) 7 BLINK TC-P60VT60 Panasonic - NEWBIE
                                          by SentraDude
                                          Greetings from SoCal I am new to this forum but not new to forum world. I come from Automotive end of side which is my main passion in life. Give the automotive nature, I love fixing and restoring things and I have in the past fixed many simple electronics, soldering, etc.. but this is a bit more involved so I found this forum, and I am very glad I did.
                                          I picked up a Panasonic TC-P60VT60 with the 7 BLINK error.
                                          Upon removing the back plate I found spider webs, dead spiders, and an amazing amount of dust. I did my best to clean the surface of the boards with a portable vacuum...
                                          04-04-2023, 04:24 PM
